Question about RCA WHP140 Consumer Headphones
The antenna will not power up - RCA WHP140 Consumer Headphones
    Problem Solver:
  • 5 Answers
I have the same model as you.
Plug in the transmitting unit into a good working power outlet. Make sure you have the audio connected to a loud source. Turn on the source device producing the loud audio to be transmitted to your headphones. Now see if the transmitting unit's LED light is on. Check headphones for audio. (May have to tune in the headphones and adjust its volume as well).
I recommend that the source of your audio have its built-in speakers off, while still providing audio out to your transmitting unit, via an external audio output. Check your source manual or look for audio jacks on the front or back. There may be a setting to turn this on and for the main built-in speakers to be turned off as well.
If this does not work, unplug the transmitting unit, and then plug it back in again, after waiting for about 10 seconds - all while audio is being provided to the unit. It should come on.
Remember that if the audio to the transmitting unit is quiet OR off for about one minute, the transmitting unit will turn off and you will hear FM noise, loudly, on your headphones. This is due to the "lack of audio" timer built-in to the transmitting unit.
Posted on Sep 05, 2010
Trying to check which fuse is for the power antenna
What fuse disables the Automatic Antennae? - Toyota ...
www.toyota-4runner.org/.../70614-what-fuse-disables-automatic-antenna...
Aug 25, 2010 - Is there a fuse that disables the automatic antenna? ... For the price of 1 toyota power mast you get a whole assembly and it won't break again.
power antenna fuse location? - Corvette Forum
Nov 28, 2015 | Cars & Trucks
What does fuse called radio-b do?
If your unit has digital display as most do now, RADIO-B will supply constant power to power the units memory so it can remember the preset channels, starting volume etc. The power antenna is usually controlled by a separate wire from the unit (normally blue) this wire supplies a low voltage signal to the antenna, The antenna will also have its own power supply and earth at the base of the antenna, the problem could be there. depending on the antenna, some have a controlling relay that is separate, again another possible source. there will also be a fuse in the main fuse box. These will all need to be checked, along with connecting a power source to the antenna to ensure the antenna does actually work.
Feb 23, 2013 | Cars & Trucks
On 2000 monte carlo is the stereo antenna powered?
when you turn on the radio or the key with the radio on if the antenna goes up its a power antenna,if this is not what you mean then the antenna is not powered as we think of power.it collects radio air waves and sends then to the radio and there is a ground on the antenna were the antenna plugs into the back of the radio.you could have a poor connection were the antenna plugs into the radio.
Apr 21, 2011 | 2000 Chevrolet Monte Carlo
I replaced a standard antenna with an electric antenna in a 199 Ford Contour. All the mounting brackets were there, but the wiring harness was not. I need to know how to wire the electric antenna (wire...
If it is a three wire electric antenna. The Ground wire is usually black. To find out which is the trigger wire simply connect the black wire to ground and then power one of the other wires, if you here the clicking of the relay you know this one is the trigger wire and the other wire is the power wire.
Sep 04, 2009 | Car Audio & Video
Power antenna motor will not shut off
I assume that the power antenna unit is an original equipment unit, if so.
1. Does it run for about a minute then stop? If this is the case, your antenna shaft needs to be replaced. This is a very simple procedure that your local radio install shop can do for you in about 20 minutes.
2. If the motor never shuts off as long as the key is on, you probably have a defective relay on the antenna motor. At this point you need to replace the entire unit. A job that can be a bit pricey because of the price of the unit itself. A cheeper fix is to replace the power antenna with a manually telescopic unit, (no motor), or a fixed unit, (doesn't go down). If you opt for the latter, remember to unscrew or lower the antenna in automatic car washes!
Jul 07, 2009 | 1984 Cadillac Eldorado
Power antenna slippage...
This is not a screw correcting problem. The antenna rod is connected to the motor by a rubber-like chain pully. The more you use the more it weakens which means it is designed to spoil.
You have to change it (the antenna). It would not cost much because its about $10 in my country Nigerria.
Rate this fixya
Apr 04, 2009 | 1990 Toyota Celica
Replace power antenna
its held in by the bracket on the botom of it and also the chrome nut arount the top of it... remove the nut from the top and the bolts from the base support bracket and then remove the antenna and power wires.. when installing replacement antenna secure the top nut first. then bolt base and reconnect antenna wire and power plug
Feb 24, 2009 | 1998 Cadillac DeVille
2004 power antenna
You dont actually have to take the antenna out of the car fender or where it sits, if you can remove the radio out of its deck and locate the power antenna wire just unplug it or cut it and tape it up and u should be ok. In most cases the color is blue, but if possible you want to test it to make sure. Also if u can get to the power antenna cables in the antenna location itself you can also cut or unplug the Antenna remote turn on wire, which should be blue as well. If u have any more questions just email me.
Good luck.
Jun 12, 2008 | 2004 Mitsubishi Montero
Antenna Power supply
First order of business is to check and see if the antenna is operating properly. If the wire in your harness is intended to power the antenna, connect 12 volts to this lead, and the antenna should go up (this needs to be done with the key in the ON or ACCY position). If the antenna does not go up, check the fusebox for a blown fuse. If the antenna does indeed go up, then you can scratch that off the list of possible problems and move on to the next step.
The Clarion should have a power input wire to keep the clock alive, and a power wire (normally of heavier guage) to actually power the radio. Make sure the radio operates when the key is in the ON or ACCY position. If the radio is operating, so far so good.
I'm kind of confused when you say there are two wires on the clarion... "power antenna turn-on" and "auto antenna". Are these both on the clarion? There should be a wire that constantly feeds the antenna with power (I would cal this one auto antenna). It should always be powered to 12 volts. The antenna should operate when the "antenna turn on" lead becomes 12 volts. Normally this ONLY happens when the clarion RADIO is on (ie: if you're listening to a CD, the antenna probably won't get activated).
After checking all this, if you're still having problems and if you haven't already done so, grab a DC volt meter and verify that the clarion power antenna turn on lead goes to 12 volts when you turn on the radio. If it does not, then there is an internal problem within the radio. If this lead IS going to 12 volts when it is supposed to and the antenna still isn't working, then my guess is that the antenna is malfunctioning.
Let me know what you find out... I'll keep looking at stuff from this end. Good luck.
Apr 19, 2008 | Clarion DB175MP CD Player
RCA WHP140 Consumer Headphones Logo
180 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
