Question about Uniden Cordless Phone
My uniden cordless phone fades out while I am talking. They can hear me but I cant hear them. It happens on both incoming and out going calls.It will fade out and then come back ok but it happens repeatedly.I have just replaced the battery.
JannEd
SOURCE: 2 uniden cordless phones aren't working
I don't know if this helps, but perhaps the problem is using two or more phones. On a whim, I charged a Uniden EXP 970 that my daughter gave me a few years ago. Charged right up and it has been working for about two days. I didn't think it would charge at all but to have it actually work, I was amazed!! Will post if it quits anytime soon.
FYI I bought two phones from AT&T, each around $200 and neither of them worked after a week. I was not happy! These less expensive phones seem to do a much better job!
Jann
Posted on Mar 06, 2008
SOURCE: Uniden Cordless Phone Model DSS7855.
The handset/base keeps a record of who it’s registered to. The base also keeps a record of how many handsets are registered to it.
Using the de-register function on the handset deletes the handset from the base (decrements the count) and deletes the base info from the handset. All this requires that the base and handset can communicate with each other.
To remove the base data from a handset when out of range of the base, press and hold the ‘end’ button and the ‘#’ button simultaneously until the phone beeps. It will now be de-registered from the base.
However, the base will still have this handset in it’s record.
To de-register all handsets from the base, remove power and the base handset. Press and hold the ‘flash/find hs’ button while applying power. Wait for the beep and release the button. The charge light will now flash. Sit any handset in the cradle. When the flashing stops, all handsets are inhibited from connecting.
However, the handset still appears to be connected to the base unit. Pressing talk will give an ‘Unable to connect’ message. To re-register the handsets to the base, you have to de-register the handset first with the two button method.
Of interest, pressing ‘*’ and ‘#’ on the handset while reconnecting the battery is suppose to reset the handset. Doing the same on the base unit puts you in some sort of diagnostic mode. Press speaker to exit.
Posted on Mar 03, 2009
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
  • 37 Answers
SOURCE: Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
Posted on Apr 29, 2009
SOURCE: CALLER ID ONLY SHOWS "INCOMING CALL"
I was using this site while trouble shooting this in the US...
If the customer has DSL with filters in the same system go back to the NID and Isolate the DSL,
test the caller id and call waiting caller id. If this works you have Data Bleed coming from the DSL.
Make sure there are not two sets of filters on the line. Tjis customer had a filter with the DSL modem.
Doing this we just fixed an on going problem for a field tech who was the second callout on a customer issue.
Posted on May 11, 2009
Our incoming calls are not ringing?
wen i receive incoming calls there is no ring or message alert
Dec 10, 2009 | Uniden Cordless Phone
Uniden phone constantly ringing
Hello, it sounds to me like you have a dying battery which may cause the phone to ring constantly.
ryan44z
www.cobaltsys.net
Nov 09, 2009 | Uniden Cordless Phone
No dial tone ,gets incoming, but cant hear anything, they cant hear me
Generic answer
You MUST get dial tone to talk or listen. Your base may ring but this may be unrelated to the telephone signal.
Check all wires and all settings. Are yoju certain your hand set is a member of your telephone group?
Sep 23, 2009 | Uniden DECT 6.0 Cordless Telephone...
I need help with my cordless handset
Replace the condenser mic on the handset.
May 23, 2009 | Uniden Cordless Phone
Apr 29, 2009 | Uniden DECT 6.0 Cordless Telephone...
Can't dial out or receive calls
constant dial tone and cant dial out or receive calls
Feb 24, 2009 | Uniden Cordless Phone
Mute is turned on cannot hear phone ring. How to turn mute off Mute is turned on . Have no dial tone can't call any one and can't answer the Phone How do you turn mute off?
I can't talk or hear outta my phone. I can dial people but i cant hear them and they cant hear. My phone model Cordless 5.8GHz Edge Dual Handset Phone System with Caller ID:
Jun 08, 2008 | Uniden Cordless Phone
Cannot hear incoming calls,or people talking
for people hit talk button then hit the top key this should be volume up thats indented and has 4 functions on its round
when phone is off hit that same key you should hear ringer go up
Apr 23, 2008 | Uniden Cordless Phone
Use phone as a room monitor
You can. Go off-hook on both the phones you want to use and this is what will happen. You may may get a recorded message from your central office or just a off-hook reminder tone that will last about 30 seconds and then you will hear the talk path between the two handsets. Keep in mind when you do this you can't receive any incomming calls because your line will appear busy to the callers. Thank You. Jerry
Feb 11, 2008 | Uniden Cordless Phone
Uniden Cordless Phone Logo
284 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
