Question about Garden
Fuel to oil ratio on a powercraft pc40-38 chainsaw
  • 12 Answers
40 to 50:1.
Posted on Jun 13, 2010
What is the fuel oil ratio per litre for a husqvarna 535rxt strimmer
If it is 2 stroke, take petrol /fuel and mix it with preferably synthetic2 stroke oil.
Ratio is usually 10L petrol mixed with 200 ml or 2 stroke oil, that is the best result, used it on my chainsaw, strimmer, moped, working for years without a glitch.
Jul 20, 2015 | Husqvarna Garden
What is the fuel mix ratio?
Hi David:
Chainsaws are 2 cycle engines and must have the oil mixed into the gas. Modern chainsaws use a ratio of 50:1
Tat is, 50 parts gas, 1 part oil.
Make sure that you use oil that is specially intended for this purpose. The container will usually have a chart that shows how many litres of gas for how many cc of oil.
Jun 18, 2015 | Garden
Fuel mix
The oil ratio is 50:1
Here is the website: http://homeguides.sfgate.com/oil-fuel-mixture-farm-tough-husqvarna-chainsaw-83933.html What Is the Oil Fuel Mixture for Farm Tough Husqvarna Chainsaw
Aug 19, 2014 | Husqvarna Chain Saw Handle Models 362 365...
I have a Homelite UT 10846 chainsaw and need to know the oil to fuel ratio
50:1 fuel to oil ratio will work fine if the oil is a modern synthetic saw oil. Be sure to premix in it's own container and be sure to shake the container thoroughly each time just before filling the tank to prevent oil starvation. Hope this helps!
Jan 15, 2011 | Garden
What is the proper fuel mixture for a husqvarna chain saw ?
The Correct Fuel Mixture Ratio
All two stroke engine will use a 50 to 1 ratio using today's two stroke oils. I once used an old chainsaw probably from the 1960s, that had a sticker on it that said to use a 25 to 1 fuel/oil ratio, but that would have been using two stroke oils of the time period the chainsaw was manufactured. In that chainsaw I used 50 to 1 ratio with no problems. Today's two stroke oils compared to yesteryears are more efficient at lubricating. It is like comparing today's synthetic motor oil to motor oils of decades ago. All the equipment I use in landscaping, anything from a weed eater, leaf blower, chainsaw, hedge trimmer, use 50 to 1 ratio, and I use all types of makes and models, Stihl, Homelite, Husqvarna, Shindaiwa, and Echo, Sears. I mix up a 5 liter fuel can and use it in all of the equipment for my customers and for my landscaping. To calculate the ratio is simple. For instance , if you have 1 gallon of fuel it is best to break it down into smaller units, like ounces. One gallon = 128 oz. You then divide this amount by the ratio of the mixture which is 50 to 1 (50 parts fuel, 1 part oil). So therefore 128 oz of divided by 50 = 2.56 oz (you would just measure out 2.5 oz ) of two stroke oil. If using metric, say a 5L gas can, you would break this down to smaller units, which would be milliliters. 5L = 5000 ml. 5000 ml of fuel divided by 50 = 100 ml of two stoke oil.
Jul 25, 2009 | Garden
I need to know the gas mixture ratio for a craftsman weedwacker
Hello mcguilmd:
>>All Two Stroke Engines will use a 50 to 1 Ratio using Today's Two Stroke Oils. I once had an Old Chainsaw probably from the 1950s, maybe Earlier 70s that had a sticker on it that said to use a 25 to 1 Fuel/Oil Ratio, but that would have been using Two Stroke Oils of the Time Period the Chainsaw was Manufactured. I was having a Problem with Oil Coming Out of the Muffler and Started Decreasing the Oil in the Gas. I Reduced the Oil Until it was a t a 45:1 Ratio and Decided to be Safe, I would Use a 40:1 Ratio Mix. In that Chainsaw I used 50 to 1 Ratio with no problems. Today's Two Stroke Oils compared to Yesteryears are more Efficient at Lubricating. It is like comparing Today's Synthetic Motor Oil to Motor Oils of Decades ago. All the Equipment I use in Landscaping, anything from a Weed Eater, Leaf Blower, Chainsaw, Hedge Trimmer, use 40 to 1 ratio, and I use all types of makes and models, Stihl, Homelite, Husqvarna, Shindaiwa, and Echo, Sears. I mix up a 5 Gallon Fuel can and use it in all of the Equipment for my Customers and for my Landscaping. I like my Fuel/Oil Ratio a Little Heavy, so I use a 40:1 Ratio. The Following was Copied and Pasted here from and MTD E-mail to me when I Asked for the OEMs Suggested Mixture for this Unit. The mixture, as described by the engine manufacturer, is a 50:1 ratio when using the approved types of 2-cycle engine oils.
50:1 ratio is a mix consisting of 2.5 ounces of 2-cycle oil per 1 gallon of gasoline.
The 2-cycle oil used should be approved and have one or more of the following specification titles: NMMA TC-WII, TC-W3, JASO FB, or JASO FC. NOTE: If unsure of the 2-cycle oil specifications, or the oil is not approved, use a 32:1 fuel to oil ratio. This ratio consists of 4 ounces of oil per one gallon of fuel.
NOTE: Always mix 2-cycle fuel oil and fuel in an approved gasoline safe container prior to filling the engine. Make sure to use a separate gas can for this 2-cycle fuel mixture and label it accordingly. Keep in mind that the fuel capacity of these engines normally is less than a gallon, therefore you will have to use this extra oil mixture for multiple fuel fills. Adding a fuel stabilizer will also help to increase the shelf life of fuel.
>>I Suggest Using a 40:1 Ratio and if Oil Starts Coming Out the Muffler then go to a 50:1 Ratio.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 13, 2009 | Craftsman Garden
Need fuel mix ratio & plug gap 4 husky 154 sg chainsaw
Hi there, No problem.
Recommended fuel mix ration if using Husqvarna brand premium Two-Stroke Oil is 50:1. If using another two-stroke air cooled engine oil, you should use 25:1 fuel:oil ratio.
Regading the spark plug, the recommended plug is a Champion RCJ7Y with a plug gap of 0.5mm (or 0.020 inches).
Mar 14, 2009 | Husqvarna Garden
I have a powercraft chainsaw, do you know the petrol / oil ratio ?
Hi, Most chainsaws use three mixes, which are 32:1, 40:1 or 50:1. Most are labeled somewhere on the saw. If you are unsure, use the 40:1 and watch the smoke, too much smoke use less mix, but don't run with too little, it is supposed to smoke some. If you see any oil coming from the exhaust it is too much and can't burn it all. Good Luck, hope this Fixsya!
Mar 05, 2009 | Garden
Garden Logo
245 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
