Question about RCA Televison & Video
Tv rca model x25144gs
Have rca tv model x25144gs try to cut on but sensor blinks green a few seconds and never comes on
  • 1030 Answers
SOURCE: rca model d52w19
blinking light indcate a processor shutdown.. the processor has detected a problem in safety circuits and shut down the set. common problem are flyback and horizotal ouptut transistor. the processor has a error log file. technicians can plug a specail computer and read those to determine problem
Posted on Dec 07, 2007
Slinteriors
  • 8617 Answers
SOURCE: RCA hd50lpw62a green power light
That set is famous for faulty flybacks. But its an easy inexspensive fix that takes under 30 mintues to do. You can get a new flyback at the following link for around 50 dollars and they provide free online tech support so you can do the repair yourself. You would need flyback number 259296 heres the link.
http://servicemanuals.vstore.ca/
Posted on May 15, 2008
  • 84 Answers
SOURCE: Tv cuts off and green light flashes
Change the lamp
Posted on Jul 05, 2008
  • 18 Answers
SOURCE: rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Posted on Feb 25, 2009
Slinteriors
  • 8617 Answers
SOURCE: we have a rca d52w20b chasis itc222 green led
The CP150, CP114 and CP120 repair kit available from www.tvrepairworld.com should repair that issue. The kit contains the parts and the CD with instructions. Its 24.95
Posted on Oct 19, 2009
I have a 60" RCA D56W02B rear projection TV. I've
Yes,the power supply board,where the actual power a/c cord plug into it,are most of the causes of power LED light blinking problems.
Feb 17, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Push power button and lold it in green light blinks one time and then nine times fast and then cuts off light try a few seconds later and green light comes on for a few seconds and off it does this three...
Hi:
You are in HV shutdown mode, Have the Horizontal output transistor replaced as well as the Horizontal output transformer. These are the most common failure for this problem, The three blinks indicates Delfection problem, and these parts are part of the main High Voltage Deflection circuits.
Dec 27, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red blinking light on tv?
unplug tv overnight. if that doesnt work the powersupply is probably bad.
Aug 18, 2009 | Philips 50PFP5332D 50 in. Plasma...
Rca big screen
Does the power led blink, when you press power? Please respond to this post and I will try to assist you with the problem. Please respond to this same post when replying
Jul 31, 2008 | RCA D52W19 52" Rear Projection Television
RCA HD 44"
replaced bulb green light continues to blink screen fails to light
Jul 27, 2008 | LG RU-44SZ51D 44" Rear Projection...
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
RCA TV Will Not Power On - Powered Off Suddenly
I have the same problem. Just Monday it started, Green light blinks but nothing comes on. Any suggestions?
May 31, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD61W66 Turns on then cuts off I NEED SOME HELP
Ive had a similar model since 2002 and it had the same problem. Factory power supply to weak for the model. Mine was replaced twice before the upgrade came out. Sorry, I dont think it is a $.50 solution.
May 25, 2008 | RCA HD61W66 61" Projection HDTV
Televison & Video Logo
73 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
