Question about Dishwashers
Tablets fail to desolve,dishes still dirty - Dishwashers
    Sergeant:
    Champion:
  • 333 Answers
Sounds like it's not getting enough water call a repair man
Posted on May 16, 2010
Tablet not desolving after quick wash cycle
Find out whether your quick cycle is a wash cycle or a rinse only. If it is a wash it's obviously too short, and the tablet is not dissolving. You do not want undissolved tablets because they will contaminate your rinse water and u end up with soap on the dishes. You can switch to powder if a tablet isn't going to dissolve quick enough on your quick cycle.
Jun 03, 2011 | Bosch Dishwashers
Smeg DI 409CA Dishwasher - Doesn't wash properly, tablet doesn't desolve and cycle lasted all night
The first thing is have a look at the instruction manual from HERE
If the dishwasher is not washing properly then please follow these steps:
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
As you said that the water builds up at the bottom see If it comes out 'foamy' then liquid dish soap is getting introduced into the dishwasher. Liquid dish soap is different than automatic dishwasher detergent. liquid dish soap needs to be COMPLETELY rinsed from anything that has been pre-soaked prior to putting in the dishwasher. after a couple of regular cycles the foam will go away. Nowadays liquid dish soap is also 'concentrated' or 'ultra concentrated' which doesn't help.
If further this does not solve your problem the the only solution is to get it repaired.
Goodluck..
Feb 23, 2008 | Dishwashers
I have a Dishlex Global 300 and sometimes the detergent was not empying out when i did a wash cycle (seems that the top rack would prevent the door of the detergent holder to open fully) I just purchased...
it could be your water preasure or the water is hard,,,but like with most dish washers the tablets dont desolve all the way,,,you need more of a liquid soap type of a cleaner
Feb 19, 2011 | Dishwashers
Dish washer tablet does not desolve in cycle so dishes are not cleaned
You haven't stated the make and model, but what you describe is typical of a dishwasher which is no longer heating the water.
This can be most typically a failed heating element, a failed thermostat or a circuit board failure. You'll need to get a repair technician to diagnose and repair the fault.
Oct 05, 2010 | Dishwashers
The tablet will not desolve and there is a white hard residue in the cups after the wash cycle. What is the solution?
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
May 21, 2010 | Bosch 24 in. SGS66E02 Exxcel Built-in...
Tablet doesn't desolve properly
Same problem here. Try greasing the tablet 'drawer' flap with olive oil.
If no good just put the tablet on the cutlery rack.
Nov 10, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Will not desolve the tablet
is it heating if so check spray arm and filters are clean it is washing i take it.....
Sep 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Not rinsing soap still on dishes
try washing the dish washer out with a good drain unblocker the system gets cloated up with grease, then use a dishwasher salt with the washes this will help to remove the suds ets, most dishwashes have a compartment to put either liquid or solid dishwash aid in try a different aid, also if you use tablet form i desolve it first in hot water in a small container
then place that into the dishwaser on the lower shelf, that helps
Aug 16, 2009 | Dishwashers
Hotpoint BF1620
What you will find is that the plastic nut fixed on the back panel that the top drawer pushes into has lost the rubber inner layer. Replace and your problem is solved
Kamal
Apr 15, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Washing tablet not desolving, dishes still dirty, have opened machine when been on 5 ninutes and only cold water pouring in, what is the problem please?
test your hot water over your sink and see how long it takes to get hot. if it takes 30 to 40 seconds just run your hot water until it gets hot then run dishwasher. or if water not hot enough yo can turn up your water heater temp. also check your heat element
Feb 03, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Dishwashers Logo
153 people viewed this question
Top Dishwashers Experts
Owen Barnes
