Question about GE WJSR4160DWW Top Load Washer
WASHING MACHINE IS OVER FLOWING. THE LOAD SIZE IS
WASHING MACHINE IS OVER FLOWING. THE LOAD SIZE IS NOT WORKING
    President:
  • 1,430 Answers
The problem is the pressure switch has failed. These are usually inexpensive and are very easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the inspection and replacement of this part. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Posted on May 16, 2010
When i turn on the washer it won't start& water keeps flowing into washing machine. does the water flows or not suppose to flow into the washing machine from the inlet valve?
water into a washing machine is controlled by a tube in the side of the bowl up to a pressure switch
as the water level rises in the bowl, pressure in the switch is built up until it overcomes the setting that you have made for a water level on the wash size selection switch
at this point it turns off the inlet solenoid switch and starts the wash cycle
If the water solenoid is burnt out then water will continue to come in and over flow the bowl but it should be washing as well
If the water is not stopping then check for a disconnected hose to the switch or ma hose full of water
failing all that get a washing machine mechanic in
Apr 18, 2015 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool GSQ9669LW1 washer. Originally Load Size was set to small. After water was filled to that level and machine started to work, wanted to add more water. Turned the Load Size knob to Medium, nothing...
You would have to start the wash cycle all over in order to get enough water for the med load size. Once the washer starts it cycle you have to cancel that cycle to start a new one. Hope this is a help to your question
Apr 24, 2014 | Whirlpool Washing Machines
Kenmore washer model 1102781269 over fills
Possible that the settings of the water level sensor is too high, you need to short the switch and see if the inlet flow stops. if not there are issues with the main controller unit.
Check this links for tips: controller unit
Nov 20, 2013 | Washing Machines
Ge load size selector broken
You can buy this part, suggest you go online and purchase it. Contact this website: Appliance Parts Accessories Repair Help
May 19, 2017 | GE Profile WPRE6100G Top Load Washer
Water just keeps flowing from the machine
replace the load size switch/diaphragm assembly.
Feb 17, 2011 | Whirlpool LSR8433K Top Load Washer
What size drain stand pipe should be used? Water is backing up from the drain. Machine is working great but water over flowing at the stand pipe
The problem is being caused because there is a blockage or restriction in the stand pipe, it needs to be cleaned out.
Feb 24, 2010 | Frigidaire GLTF1670A Front Load Washer
Gcxrpo9odoww GE washer .. On fill up, it over flows onto floor?
Fill switch could be bad, or fill tube could be plugged making water not stop and it keeps filling. The fill tube goes from fill load selector switch to bottom of tub. Remove from top and blow it out. If this doesnt work replace water load size selector switch.
Jan 17, 2010 | GE WBSR3140DW Top Load Washer
Model crtf1240aso. some water goes to washer, not enough to wash. door locks, led comes on, strainer is clear and water is going to washer, timer is rotating on its own
Not sure what is happening here. Sounds like a pressure switch that you think of as a "wash size" selector switch is seeing the correct amount of water for the size load you have selected, yet that amount is not there and the switch stops the water flow before it's reached the proper amount.
Could be a problem with that switch.
Could be that the flow of water is obstructed some way.
My bet: Could be that the water is not turned on to the washer fully and the timer times out the flow of water before its up to your desired level.
Sep 27, 2009 | Washing Machines
Water dose ot stop when washer is full. It continues to run.
If you disconnected power and water still flowed, replace the water valve. If water stopped flowing when power was disconnected, clean out tube from tub to water level switch.
Jun 07, 2009 | GE WDSR2080D Top Load Washer
GE WJSR4160DWW Top Load Washer Logo
70 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
