Question about Rokinon 85mm f14 for Nikon
ROKINON AUTO ZOOM Macro--- HELP to enable macro
Hello, I have a ROKINON AUTO ZOOM MULTI COATED MACRO 1:3.9/4.9 f=80-200mm.
The problem is that a CANNOT enable the macro feature. The focus ring is smooth and turns from 1m to infinity. But below 1m I see a MACRO point where I cant turn the ring. Can anyone help me?
Thanks a lot
    Scholar:
  • 117 Answers
Some of the Rokinon (and other ) zoom lenses could only go into MACRO at certain focal lengths- the lens you have "zooms" from 80 to 200 focal length,but is that done by "sliding" a ring forward and back on the lens, or by twisting a different ring that the one that focuses?
Posted on Jun 02, 2010
What does Macro On and Macro off mean
macro on means that the lenses of the camera are enabled to take pictures at a very short distance, it's like a zoom but with the camera placed very close to the object being photographed.
macro off disables this feature.
Dec 03, 2014 | Cameras
Taking macro photos
hi,
when you use macro, you must stay really near the subject... so if you use the zoom to get closer, that want to say that the camera is too far, you may put it nearer and so, use less zoom, or get rid of the macro and only use the zoom (and you can move the camera to good distance) you'll get better results !
cheers,
mich
Nov 07, 2014 | GE X5 Power Pro Series 14.1 Mp Digital...
Macro problem
Most modern lenses have a lot of plastic to save money and weight. Any trips in a hot car?
May 12, 2010 | Sigma 28-80 F3.55-6 ASP Macro HF (1:2)...
Lens for Nikon D60
I will try to help you, but please understand that my experience is with Nikon film cameras. Assuming that the D60 works in a manner similar to a Nikon 35 mm body and that Sigma macro lens work like Nikon macro lens, you should be able to determine the usable subject to lens distance by experimentation. First, make sure the lens is in the macro mode. To do this you must set the auto-focus mode control to the manual focus mode (see your manual). On Nikon lenses, you must first set the focus ring to infinity, then move slider switch, which has two positions marked; "normal" and "macro., to the macro position. You should now be able to rotate the focus ring to the macro range. Use the zoom ring to zoom in and out and focus with the focus ring. The the range over which the lens to subject to lens distance will yield an in focus image will be rather limited and in the range of an inch or so to 6 or 8 inches.
Dec 09, 2008 | Cameras
I can't get my Powershot S5 to go into Super Macro mode - Help!
There seem to be two stipulations for getting into super macro mode,
First you must be in scn ("A" or "S" mode's only) and "movie", "P", "TV", "AV" or "M" modes only.
Secondly the zoom Lens must be all the way out.. set at the widest angle.
Best of luck
Jun 14, 2008 | Canon PowerShot S5 IS Digital Camera
Canon S5 IS. I am having problems with Macro shooting. As I look through view finder, object seems in focus, but when I press focus lock button (halfway) the image jumps out of focus.
Dear Stefan:
Barring a malfunction with your len's autofocusing mechanism, the problem that you're experiencing is likely due to the limitations of the camera's focusing / zoom range in Macro mode.
You didn't say what ranges you were shooting from but basically, in order to get proper focus, you must first make sure you're within the proper lens to subject distance for the macro mode that you've chosen.
There are two macro modeson the S5, Macro and Super Macro. Macro shooting is done only within the ranges of 3.9 inches to 1.6 feet from your subject. SuperMacro mode (which is entered into by simply pressing the Macro button for one second) will only focus within the ranges of 0 inches to 3.9 inches. So if you are in either of these modes and stray from their focusing ranges, your camera won't focus properly.
Another issue that you may be dealing with is the very limited zoom range in Macro/Super Macro Modes. The zoom is basically meant to be set toward the maximum wide angle end of the zoom range. There is a yellow indicator bar below the Zoom Bar in the viewfinder that indicates the Out-Of-Zoom range in which the zoom basically can't be used. As you may see, only the first 10% or so of the zoom range is useable.
It might be that you could possibly be wavering in and out of the two macro mode focusing ranges and/or zooming into the Out-Of-Range zone during your session. Either can cause a similar effect such as you are describing. It's hard to say without actually being there.
To test this out I would simply set my camera on a tripod or other stand at a known fixed distance from the subject, set the camera to the macro mode indicated by that distance (either MACRO or SUPERMACRO), zoom out to the widest focal length and take the shot to see if it is clear or not.
If so, your camera probably has no problem. If it is still not focusing properly you might want to send it into the service center for a diagnostic. There is no charge to diagnose a problem with your camera and if nothing is found to be wrong you will only be out of the shipping charges spent to send the camera in to the service center. If a repair is needed, it can be done at that time.
Hope this helps you.
Sincerely,
HeavyDLB
Jun 01, 2008 | Canon Cameras
Trouble focusing with sigma 70-300 DL macro super lens
It will not focus on anything closer than 5 feet.
(From Sigma lens literature)
Capable of macro photography, this lens has a 1:2 maximum close-up magnification at the 300 mm focal length. It's the ideal high performance lens for portraits, sports photography, nature photography, and other types of photography that frequently use the telephoto range. It also has a switch for changeover to macro photography at focal lengths between 200mm and 300mm with a maximum close-up magnification from 1:2.9 to 1:2. The minimum focusing distance is 1.5m / 59 in. at all zoom settings.
Dec 25, 2007 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Focus
Your camera has the ability to shoot Macro and Super Macro, although in some Dial Modes, you can't use Macro.
To engage the Macro mode, press once the button on the left side of the lens/camera that looks like a Flower. To engage the Super Macro mode, press and hold the same button for more than one second.
Macro mode range 3.9 in. - 1.6 ft
Super Macro mode range is 0 in. - 3.9 in.
To cancel Macro mode, press the Flower icon button once.
Zoom levels are limited, and you will know that when the zoom bar turns yellow. This means the zoom is not available at that zoom level.
Hope this helps.
Nov 24, 2007 | Canon PowerShot S3 IS Digital Camera
Focus in Macro mode
1. Do not use the zoom while using macro. 2. When clicking the Macro button, click it again, only for 2 more seconds at the second click, it goes to 'Super macro' mode for zero distance. This works in the Canon S3 IS, I hope it will help you in the older S2 IS. 3. Use a tripod. 4. Use the timer for no movement when using a tripod. 5. Try using the manual focus, it does the trick when the camera doesn't focus automatically. Good Luck!
Aug 13, 2006 | Canon PowerShot S2 IS Digital Camera
Canon Powershot S2 IS Super Macro mode
Make sure your camera isn't zoomed in (full telephoto) The camera can't handle both full zoom AND super macro. Don't forget super macro goes from Zero to 20cm from the lens. Zoom completely out and you should be able to see something within that range. The biggest complaint I've heard about the S2 IS is if you take closeups of bugs the chances of the bug crawling onto your lens is pretty good.:-) Be very carefull of blocking light with the lens at extreme closeup too. Although the flash squelches well to allow for closeups it can leave a nasty shadow. If you're really serious about macro you'll find a ring flash would come in handy. BMW
Jul 13, 2006 | Canon PowerShot S2 IS Digital Camera
Rokinon 85mm f14 for Nikon Logo
245 people viewed this question
Top Rokinon Cameras Experts
Are you a Rokinon Camera Expert? Answer questions, earn points and help others
