Question about Brother MFC 420CN All-In-One InkJet Printer
Brother MFC-420CN I am also having the same problem. I did reconnect the flat cable at the PCB. It isn't lose at all but I still get the same error message. Anything else you can recommend? -S
  • skcanus Mar 30, 2008
    all the silver side circuits are intact. I don't see any scratches. How would I know if this is the the pcb that is defective? Can something else cause to have "unable to init" error message?
  • dora6860 Mar 31, 2008
    will not install with vista
  • 832 Answers
Is the flatcable ok at the (blue/silver side) which goes to the pcb? Or are there some circuits(scratched silver plains) within the cable?
Sometimes the pcb is defective.
Sometimes the connection within the sacnner is faulty.
Posted on Mar 30, 2008
Mfc 7360 unable to print 7a
Error code 7A
A synchronized signal of the main motor cannot be detected.
Turn the power off and then back on again.
1 Flat cable connection failure of main motor
Check the flat cable connection of the main
motor and reconnect them.
2 Main motor failure Replace the main motor.
3 Low voltage power supply PCB failure
Replace the low voltage power supply PCB ASSY.
4 Main PCB failure Replace the main PCB ASSY.
Jan 14, 2015 | Brother MFC 7360N - Multifunction fax /...
I have a 420CN and it is giving me a unable to
The mechanical error is something literally wrong with the mechanics, usually this error occurs after a paper jam and when the paper is pulled out it cracks the maintenance unit.
Other issues include the switching arm, the ink cartridge/purge switch harness, purge cam switch, paper feed motor, and the main pcb.
Feb 01, 2010 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420cn "Cannot Init"
This is the Head Error 41
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement.
My advice is to take it to a
Brother service centre while if it is under warranty.
If it's out of warranty they are usually a throw away job, the heads cost as much as the printer.
Sorry I know what it feels like, just have a go and see what you can do, clean the heads and so on.
All the Best and good luck: Pineworks
Sep 26, 2009 | Brother MFC 420CN All-In-One InkJet...
How to clear error code
Unplugging and leaving the printer powered down for ten to fifteen seconds can work wonders. Try it; you might like it.
Jul 20, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother printer 420cn
actually the power cord is the only one that comes with the printer. In some cases brother has put an usb-cable into the box. For mfc with network connection there is no usb cable included.
Mar 17, 2008 | Brother MFC 420CN All-In-One InkJet...
You simply have to reconnect the flat cable of the scanner to the main pcb.
Therefore you have to open the mfc by opening the scanner cover as when you have a paperjam. Loose the the blue support by pressing down the clip on the right side and pushing the support to the right.
Disassemble the "Z"-forming by carefully pressing it up at the latches which can be seen. The flat cable has to be connected to the main pcb simply by sticking it into position :-)
Error will disappear.
Nov 08, 2007 | Brother Multi-Function Center MFC-240C...
Brother MFC 420CN shuts off and on automatically every minute
Did you had a lighting strike the days before?
Its either because of lighting strike /high tension or some electrical part are ruined.
Sorry, you cant fix it by yourself due to change of the hole main pcb.
Oct 26, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother Mfc 420cn says machine error AF
Open the small cover that hides the scanner flat cable. It has to be reconnected to the main pcb.
Oct 23, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420CN error message DF
Did you had lightning strikes or a high tension the days before? DF means that the faxmodem which is placed on the pcb is in disorder. The pcb has to be changed (sparepart is more expensive then a new mfc!)
Oct 03, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
60 people viewed this question
James Cagle
James Cagle
Jim Keysor
