Here are some steps to tune a Teac LED/LCD digital TV without a remote:
Find the TV's on-screen menu buttons on the TV itself (often located on the side or bottom of the TV)
Use the arrow buttons to navigate to the channel setup or tuning menu
Select "Auto Tuning" or "Channel Scan" and follow the on-screen instructions to scan for available channels
If the TV has manual tuning option, select it and input the frequency, symbol rate, and other information for each channel you want to add manually.
Once the tuning process is complete, the TV should display all the available channels. If you are unable to access the menu without a remote, consider using a universal remote that is compatible with your TV or obtaining a replacement remote from the manufacturer.
If the recorder is old the analogue/digital change is screwing it up. It isn't the TV that is the problem, it is the received signals, but the problem is the same.
If your TV is not in Digital it won't give you the tuning option.
Select DTV from the on screen menu, (like scart 1 scart 2 etc). When
you have found DTV select it and then press menu for tuning.
Hope that helps.
If you were unable to tune in digital before the switchover then most likely your digital reception is poor. Unlike analog signals you will not see anything on screen until it can lock in. You may have to repoint your TV antenna or check what size of antenna you need at antennaweb.org
You havent listed your TV model but most Samsung sets that are digital will have A button on the remote marked DTV this will tell set to look at the digital chans.
Now try & go in to the menu & select tuning & scan the digital chans in.
One other thing are you in an area of the UK that can pick up digital channels without changing your aerial.
