Question about Samsung SMH7178STD Microwave Oven
Samsung Microwave -SE- Error
Sorry to bother you.
I was just wondering what ever happened with your microwave from this thread:
http://www.fixya.com/support/t244852-samsung_over_range_microwave
Ours is still having the same error.
How can i fix se error a samsung microwaveSMH9187ST
Posted on Oct 25, 2012
  • Samsung Master
  • 9,086 Answers
The -SE-error is a shorted keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 21, 2008
    Problem Solver:
  • 7 Answers
I have tried a few different things suggested for the Samsung microwave SMH8165 - flashing -SE- code. What finally seems to have stopped it is I took the keypad off and disconnected the connector for the thin 2 wire connector to the circuit board. They are towards the top of the board in the middle. They seem to go to the sensor that was malfunctioning. We do not use the sensor cook modes so that resolved the SE error.
To access Keypad
***Turn OFF POWER***
Unscrew two screws on top of Microwave vent panel (Top of Micro above door)
Remove vent by picking up and shifting left.
Removes screw at top of key pad.
Remove green ribbon cable at right hand side of panel
Re attach
Turn power back on.
Posted on Apr 28, 2015
My kenmore over the range microwave is showing an error code of 5E or SE . . . What does that mean?
it's the touchpad, you have to stick a new one, call a technician or buy the touchpad corresponding to your microwave oven model
https://www.applianceblog.com/mainforums/threads/51787-Kenmore-Elite-SE-error-code
Nov 05, 2017 | Kenmore Microwave Ovens
How to fix E5 code for Samsung Microwave
About 64,200 results (0.62 seconds) Search Results
    Fixing a broken Samsung Microwave - The dreaded 5E ...
    ? 4:30
    https://www.youtube.com/watch?v=_yWSU0kTkTg
    Mar 20, 2013 - Uploaded by Joe Devlin
    When my Samsung Microwave was just over a year old it failed giving me an "5E" or "SE" Error code which ...
    Samsung Microwave SE (5E) Error Fix - YouTube
    ? 9:23
    https://www.youtube.com/watch?v=YubSrHE7WFc
    Dec 7, 2012 - Uploaded by eric hatch
    I had pretty much decided to throw it away since the cost to fix it by a ... Fixing a broken Samsung Microwave ...
    Samsung Microwave SE Error FIX! - YouTube
    ? 1:33
    https://www.youtube.com/watch?v=oPQE2oLTR3o
    Jan 26, 2014 - Uploaded by jjthetechguy
    I am not responsible for any damage done to your microwave*** ***Do at ... Fixing a broken Samsung ...
Jan 27, 2016 | Samsung SMH8165B Microwave Oven
What does this mean on my Samsung smh9151 microwave oven? -SE-
The SE error indicates a short was detected at the key pad. This could be a problem with the wiring (dirt at a connection) or a bad circuit board. If your microwave is under warranty, contact Samsung.
Since microwaves have high voltage, you may not want to try to fix this yourself. If you do, make sure to be careful. Some have fixed the error after unplugging the microwave. Then disassemble the microwave keypad area. Disconnect the various wires and clean all of the contacts. (Do one wire harness at a time so that you replace them in the right place.) Reassemble and plug in the microwave. Test if the SE error returns. If the error remains, then the control board needs to be replaced. To get the entire keypad and control board, seehttp://www.repairclinic.com/Shop-For-Parts/a6b160i468/Samsung-Microwave-Touchpad-And-Control-Panel-Parts . The board alone is here: http://www.repairclinic.com/Shop-For-Parts/a6b160i324/Samsung-Microwave-Control-Board-Parts .
I hope this helps.
Jan 16, 2016 | Samsung Microwave Ovens
Oven shows -se- error,and now doesnt heat
Sorry but the -se- error code from the manual means:
An error of the oven may cause
low performance and problems
in safety. Stop using the oven
immediately.
Call local SAMSUNG service
centre.
Look for the 1-800 number on the back and give them a call.
Jun 10, 2014 | Samsung Microwave Ovens
Samsung microwave se error
see the video attached. God bless you
Dec 09, 2013 | Samsung MS1040BB Microwave Oven
My Samsung microwave SMH9187W is getting a 5E or SE error code when I plug it in. Unplugging and replugging use to clear it for a bit but now it happens as soon as I plug it in. I am just out of warranty...
Maybe Just Lucky; I removed the front cover above the door by removing the two screws on top of micro. Then I removed the screw above the controll panel and carefully lifted off the panel. I checked all wire connections while plugged in and the SE code changed to 0. I reset the clock and put the panels back on.
Done Loose Wire
Jun 29, 2011 | Samsung SMH7178STD Microwave Oven
Samsung Over range Microwave
Mine just started today too. I am thinking of taking a ball bat to it. Samsung foriegn made piece of shit.
Jan 04, 2008 | Samsung SMH7178STD Microwave Oven
I have the same "SE" problem. After reading this thread here, I realise it's likely the keypad problem, which explains the microwave's behaviour (no key was working).
So there were two possibilities. (1)keypad failure and (2) bad connection.
Obviously the easiest thing I could start with is to clean the connection. So I first take the cover off. Behind the keypad is a circuit board. In addition to a few connections between the circuit board and other parts of the microwave, there is a ribbon connecting the keypad to the circuit board.
Loose the plastic on the connection, pull the ribbon out from the socket. I then used spirit to clean the exposed copper connections. Put every thing back to place.
Voila, it's working again and we have been living happily ever after.....
Nov 04, 2007 | Samsung SMH7178STD Microwave Oven
Microwave Ovens Logo
4,278 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
