Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Standard washing machine hoses dont seem to fit my Whirlpool Ultimate Care II washer? Do I need an adaptor of some sort....
The Whirlpool Ultimate Care II is an American top loading washing machine and requires different hoses available from Whirlpool.
Posted on May 17, 2010
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    My Whirlpool Ultimate Care II Washer doesn't stop filling with water
    If this only happens when the machine is turned on,the tube from the tub to the water level switch is pinched or broken. If the clear plastic tube is not pinched or broken,the water level switch in the control console is bad. If the machine lets water through when it is in the OFF position,the water valve where the hoses connect are bad.
    Dec 27, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
    On rinse cycle...cannot control water temperature...set it for warm but still feels cold to touch. wash cycle is ok. model is whirlpool gold ultimate care II..top loader.
    Is the hot water turned on. Remove hose from washer and check screen in water inlet. If it is clear you may need a new water inlet valve.
    Apr 01, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
    Washer leaks during fill up
    check the bottom of the inlet hose where it enters the machine. It is most like;y a split hose or a corroded valve.
    Sep 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool ultimate care II stops after filling
    Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
    Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
    Whirlpool Ultimate Care 2 leak after wash cycle
    Hello, you may have a small drip from the pump or a small drip from the hose that goes from the pump to the rear of the cabinet. To make sure you will have to run the unit with the cabinet removed. A local service tech can remove the cabinet quicklyand isolate the leak.
    Dec 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care II - NO WATER COMING IN
    take the hoses off the back of the machine. make sure that water is coming through. if water is coming through the hoses and the screens are clean then you need to replace your inlet valve
    My Whirlpool Ultimate Care II will not fill up with water.
    ck drain hose end of hose should be at least 30-36 inches from floor also end of hose needs to fit loosely in standpipe ..if drainhose is too tight siphoning will occur
    Dec 21, 2008 | Whirlpool Ultimate Care II GSW9650LW Top...
    Whirlpool Ultimate Care II keeps taking water.
    ck your drain nose/drainline, chances are you have along hose, perhaps even draining along the floor behind hte unit, into a "closed" drain system. in which cawee the wwater is syphoning out during the rinse cycle, youlll needt o raise the drain hose to above 48" and have it drain into a stand pipe to prevent siphoning effect
    Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
    194 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
