Question about Braun 350 Watts M810 MultiMix Hand Mixer
Bought one secondhand and need instructions for use of different beaters!
  • 276 Answers
I have access to this manual if you require. It's a 3MB file.
Posted on May 17, 2010
How do I keep beaters in mixer without them falling out?
Each beater may be shaped differently and only will click into its appointed port. There may be a picture on the mixer showing which side to put each beater.
May 12, 2014 | Black & Decker MX55 PowerPro Hand Mixer
How do you place beaters in mixer without them falling out?
I can't find a manual for the MX55 online, Suzanne, but looking at the picture of it I found on Amazon and based on the manuals for other B&D models, it looks like you should have two slightly different beaters: one with a collar and one without and it's very important that each beater go into the correct hole. The one with the collar should go into the left hole (looking at the bottom with the holes at the top) and the one without a collar into the right. The other manuals say "insert each beater and, if necessary, turn it slightly until it locks into place." I hope this helps. Good luck!
I need replacement beaters for GE hand mixer model # 169204
Last time I bought them from amazon. Take a look Amazon com replacement beaters, and choose which one fits for you. I hope this was helpful. cheers
Jul 02, 2012 | Food Mixers
Kitchen aid khm3wh beaters will not stay in mixer
I fixed mine (my wife's). Kitchenaid 3-Speed Hand Mixer KHM3WH. Here's how I did it.
This is a pretty old mixer. My wife bought it at a thrift store for $1. She brought it home, we found the beaters and whisk beaters on eBay. Paid $34.00 for both sets of beaters, but when we received them we found they would not stay in the mixer. Oh we also bought the alternative/replacement beaters from Sears, parts online. I don't think those will work with my fix. However with some $0.92 rubber washers from Lowe's and a heavy duty paperclip I fixed the mixer, and it works flawlessly. Maybe some stainless steel wire would be a better, more permanent fix.
Apr 30, 2012 | KitchenAid KHM3 Classic Hand Mixer
The flat coated beater has worn off the coating why and how to fix it
Hi ARADAM, you don’t provide the model number or say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, which would helpful, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number and select a file listed under Owners Manuals and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Beater to Bowl Clearance
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance.
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface of bowl.
If you find the adjustment screw missing, you’ll need to replace it. But now you’ll need
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Dec 22, 2009 | Food Mixers
Bowl too low
Hi, JAKELEGJEETE, You don’t say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM5PS)and select the last file listed that appear under Owners Manuals: and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the Beater to Bowl Clearance. I have extracted the instructions below:
Tilt-Head models
• Unplug mixer.
• Lift motor head.
Bowl-Lift models
• Unplug mixer.
Dec 11, 2009 | Food Mixers
Can you lengthen the beater by loosing a screw?
Hi, KLOEHR, your beater will not lengthen by losing a screw. However, if you lost your Beater to Bowl Clearance adjustment screw, then it might appear that your beater had ‘grown’ because now the beater may be touching the bottom of your mixing bowl, where previously it had not. Simply said, the beater didn’t grow the mixer head drooped.
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM5PS)and select the last file listed that appear under Owners Manuals: KSM5PSWW0.pdf (2930.74 KB) and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Tilt-Head models
• Unplug mixer.
• Lift motor head.
Bowl-Lift models
• Unplug mixer.
Dec 10, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Have a kitchenaid artesian mixer need to adjust beater depth-it is scraping the bottom of the bowl. Model #KSM150PSEr 325 watts
Hi KELLYSERMAN, this should be pretty easy to do by yourself the instructions for adjusting your beater to bowl clearance is in your Owners Manual. I you don’t have the original manual you can easily download a PDF version of your Owners Manual from the KA website: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case KSM150 and select the file listed for your model that appears under Owners Manuals (66): KSM150PSER1 (732.33KB) and save that file to your PC. Turn to Page 14 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Tilt-Head models
• Unplug mixer.
• Lift motor head.
I hope this helps! – Howard, Burke, VA
Dec 07, 2009 | KitchenAid KSM150PS Artisan Series Stand...
I need replacement beaters for an old GE hand mixer.
I bought an old GM mixer no. 30M47 with no beaters yesterday at the Salvation Army store. The beaters I have for a newish (ugly) GE hand held beater fit perfectly. I suggest taking your old beater to a store that sells new GE handheld beaters and seeing if the new beaters fit. If anyone reads this and wants me to look up the number of the new ugly beater for them, please say so before I take it to the Salvation Army.. : )
Oct 21, 2009 | Black & Decker MX55 PowerPro Hand Mixer
Instructions for Sunbeam 2350 Heritage Series Mixmaster
Go to sunbeam.com, select "kitchen", then select "customer service", then "instruction manual", then "stand mixers", scroll down to model #
Nov 23, 2008 | Sunbeam 2350 Heritage Series Mixer
Braun 350 Watts M810 MultiMix Hand Mixer Logo
117 people viewed this question
Top Braun Food Mixers Experts
Slo Mover
Tom Chichester
ray gallant
Are you a Braun Food Mixer Expert? Answer questions, earn points and help others
