Projection TV Problem
I have a 50-inch rear projection TV. When it is turned on, it works good for 10 or 15 minutes (sometimes for 25 minutes), then forms images with separated color. Any suggestions will be greatly appreciated.
(Many posts suggest convergence-circuit problem. If so, why does it work fine for several minutes when turned on, and then only go bad?)
Thanks, Slinteriors. In replacing the ICs, I am concerned about the residual high-voltages. Are there any locations I should avoid coming into contact with? Are these easily identified?
Also, can I find step-by-step instructions on the IC replacement process? Thanks again.
Posted on Apr 03, 2008
  • 8,617 Answers
The convergence ICs are nearing the end of their operating lifespan. You will need to replace both ICs . Let me know if you need more information.
Posted on Mar 30, 2008
SOURCE:
Why will my Panasonic 52 inch rear projection will not turn on?
I had a 50 inch projection tv and when the bulb would go out there was always a popping sound. I went on ebay and found a new bulb at half the price the tv maker wanted. I would replace the bulb. If that is not the problem then you will just have a spare that will be needed at some point.
Apr 26, 2014 | Panasonic PT-52LCX66 Projection Television
HELP! 50 inch projection RCA HDTV. Turn it on sometimes minutes later, sometimes hours later the picture will go black with sound on once or twice and then it will power itself off entirely. None o
I got all the components you need for your tv I'm parting out mine it was oar king break when I turned it off we bought a wall hanger if you need parts call 270 589 8074
Oct 27, 2012 | RCA HDLP50W151 50" Rear Projection HDTV
Turns off by itself
you have an overheat problem somewhere on one of the pc boards and the thermosistor is sutting it downfor safety you need a pro to service it sorry
Sep 28, 2009 | Samsung HCL4715W 47" Rear Projection...
Magnvox 50 inch rear projection tv
Have you tried cleaning the projectors? I had a halo issue and that resolved it. Good luck
Aug 28, 2008 | Philips Magnavox 9P6034C 60" Rear...
Ticking noise from TV - Sony 50' rear projection 1080p LCD
The problem is ht leakage . remove the ultar cap of the tube and clean both the tube and cap with wd 40. then reinstall cap using some silicon glue.
this will correct your fault.
Jul 11, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
50 inch screen
I will check when I get to work tomorow and see if we have one and I will repost tomorow
Apr 17, 2008 | Toshiba 50H82 50" Rear Projection...
Mitsubishi vs 50707 50 inch projection tv problem
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Dec 15, 2007 | Mitsubishi VS-50707 50" Rear Projection...
50 inch LCD rear projection Bravia TV
Could be faulty fan, check and see if it is spinning correctly
Dec 15, 2007 | Televison & Video
Hitachi 50 inch Rear Projection Color problem
Which sounds like a loose connection in the video or chroma section. you can carefully tap around affected area with a rubber screwdriver handle(not metal part) and see if it does come and go and look in that area for loose connections that needs soldering back. Hope this helps
Jul 30, 2007 | Hitachi 50UX57B 50" Rear Projection...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Ekse
