Question about Stoves 800DFDOm Dual Fuel (Electric and Gas) Kitchen Range
My electric grill on my Stoves 800DF DOm, has stopped working, I was using it as normal and it just switched off and now will not heat up at all, is this there a quick fix,
4 Suggested Answers
bigg t
  • 640 Answers
SOURCE: stoves newhome
the residue is the grease being exhuasted from the oven.i wouldnt think you could vent it out unless you have an overhead hood.if its really bothersome look at a home depot/lowes for a heat/fire resistant filter and install it on the oven somehow.
Posted on Jan 06, 2008
  • 3 Answers
SOURCE: Top oven thermostat Stoves 800DF - fitting?
you dont need to remove the front panel, you need to undo the two black screws on the side of the hob unit, remove the two plastic plugs they went through allowing you to raise the hob, and remove just the back off the cooker this provides you access to all the areas you need you can then follow where all the cables go oh yes nearly forgot the thermostat is held in place by two screws you simply pull the knob off and there they are. ive just done the fan oven one and it seemed fairly straight forward, but please do remember to turn off the power to the cooker first all the connections push on using spade connectors, oh yes for legal reasons this is for information only and i wont be held liable for injury or damage caused by unqualified people following this information to fix it themselves as i would always have to recommend that you use a competant person ie a person who is trained, experienced and has sufficient knowledge to do the job, but those that do want to fix it do so at their own risk and i hope all goes well with getting the problem fixed
Posted on Mar 27, 2010
  • 3 Answers
SOURCE: i need to replace the top oven thermostat control
The grill gets hot but doesn't brown the food?
Normally, if a grill element fails, it just stops working. So if they are working then on full power, both elements should get red hot! If this is the case, all I suggest is that you try experimenting with different heights with the grill tray. And by the way, don't shut the door when you are grilling as this shuts the grill off!
Oct 28, 2011 | Stoves 720EF Electric Double Oven
I've a stoves efa600h electric oven and grill, and it's stopped working! It will switch on, and start up even as normal, but then after not very long (not long enough to cook oven chips) it's as if all...
There seems to be an overload switch in the stove and that is tripping out and resetting after the 10 minute interval. You need to find out if the overload switch is faulty and tripping out at a lower load, which is the more likely scenario, or if the stove is really overloading the switch. A snap amp meter around one of the cables will give you the stove current draw. Probab;y easier than doing that will be to replace the switch and see if that fixes the problem.
Feb 06, 2011 | Stoves Newhome ECH600MXa Electric Kitchen...
MY STOVES COOKER'S OVEN AND GRILL HAS STOPPED WORKING?THE HOB IS WORKING FINE.
The hob is normally totally independent of the oven. What is actually working or not working on the oven? i.e. does the grill still work, is the clock OK and can you set it, or is everything totally dead?
Oct 16, 2010 | Stoves 720EF Electric Double Oven
I need to replace the top oven thermostat control how do i remove the front panel ???oven is a stoves 800DF DOm 050565031
Feb 15, 2010 | Stoves 800DFDOm Dual Fuel (Electric and...
No Grill operation for stoves 720ef
Supply an email address for you and I will grant you access to my BT Digital Vault where a copy of the complete handbook is lodged. It includes circuit diagrams.
With your fault, can you here the switch operating, if not it just may be stuck?
Dec 12, 2009 | Stoves 720EF Electric Double Oven
Hi, we have had one of these ovens for 8 years (it was in the house we moved into). We had a new control fitted for the top oven (it took the repair company three tries to get the right part) and the problem didn't go away. To be honest, we can't stand this oven but are waiting until we replace the entire kitchen to replace it. The bottom oven is fine. The top oven is fierce and burns food all the time. Overall it's a ridiculous oven - I'd much prefer a sensibly-sized one that actually worked well! Rant over.
Jun 10, 2009 | Stoves 800DFDOm Dual Fuel (Electric and...
I have a stoves 720EF Heritage - electric - the top grill is not working - does it have a reset button?
No, there is no reset button. However, the grill will only work when the front is down as there is a microswitch which operates to provide connectivity when it is in this position. This is to stop the grill overheating. The switch could have gone faulty.
Does the top oven work ok?
When you operate the grill there are two options, part or full. Are they both failing? Does the cooling fan switch on when either grill is operated?
May 05, 2009 | Stoves 720EF Electric Double Oven
The grill is nt working
Highly unlikely, either element gone or selector switch faulty, you need to test element with a meter.
Plz leave feedback.
Dec 13, 2008 | Stoves Premier 600EMa Electric Single Oven
Stoves 720ef grill not working
The grills appear to be independant of each other. Does the oven still work and the oven light come on?
Depending on your answer it could be that the Top Oven Switch has gone faulty. The Grill Regulator and the Switch work together on the top oven. To get at both you will need to take the top of the oven off.
Oct 04, 2008 | Stoves 720EF Electric Double Oven
Stoves newhome
Jan 05, 2008 | Stoves 800DFDOm Dual Fuel (Electric and...
Stoves 800DFDOm Dual Fuel (Electric and Gas) Kitchen Range Logo
150 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
