Question about Samsung ML-2851ND Laser Printer
IP address of printer on the network has changed
The IP address (192.168.1.104) of my Samsung ML-2851ND printer on the network has changed since installing it yesterday, so now it won't print. Nothing was done to the system configuration to change it. So why did the IP address change? And how can I manually reconfigure the printer to the new IP address(192.168.1.106) to get it printing again?
    New Friend:
The SetIP utility does not do what you are suggesting.
1. If you want to manually configure the IP address on the actual printer use the SetIp utility to do that.
2. If you want to configure your computer to talk to the printer which is now found at a new address you need to do a "repair" install of the printer and the drivers will find the printer at the new IP address again.
Yes, it seems crazy but for some reason you can't "reset" the drivers to use a new IP address.
Posted on Feb 19, 2013
You have to use the utility call SetIP that comes with the printer. Check the CDs. It is easy to use.
Posted on Sep 18, 2010
ML-2851ND Printing Problem
Dear
You have mentioned its a refurbished unit. If you attach a sample print it will be easier to understand the problem. however my first doubt on toner cart. If you are known the refilling/repair procedure, check and clean all rollers and blades. Also check the electrical contact points and lubricate with silicon oil.
thanks.
Jan 07, 2015 | Samsung ML-2851ND Network-Ready Monochrome...
My Samsung ML2855ND laser is not printing dual page after ink cartridge has been changed
Dear
The toner cart. replaced has to be checked. If its alright, try to adujust darkness and resolution of the print on printer setting. This may helpful.
Thanks.
Aug 02, 2014 | Samsung ML-2851ND Laser Printer
SAMSUNG ML 2851ND TONER REFILLED BUT, NOT PRINT PROPER. 4-5 DARK VERTICLE LINES COME IN PRINTING.
you are using a mono laser printer
possible problem:
The surface (drum part) of the toner cartridge inside the machine has probably been scratched.
Remove the toner cartridge and install a new one.
Jul 17, 2011 | Samsung ML-2851ND Laser Printer
What is the default ip for the printer samsung 2571n
Hi
Normally its 192.000.000.000,But you can give it any ip address as long as its in the same ip range as the network you want to install it,just make sure its set on static and not DHCP!!
Jan 29, 2011 | Samsung ML-2571N Laser Printer
My printer is used as a network printer, but won't print from my Dell Optiplex 755 (Win7). Two other Win7 systems on my home network print just fine. The IP address pings OK, but when I print something,...
Its seems a different Printer Port is assigned in your computer.
Open Printer Properties and click on "Ports" Tab. Look at there for TCP/IP port is Selected.
For Example :
If your Printer is on 192.168.1.40 then in your Computer Printer Port must be selected to TCP 192.168.1.40. ( Mean to say not to LPT , USB etc)
Refer to Link it shoud be like this
Mar 28, 2010 | Samsung ML-2851ND Laser Printer
Hi, I have connected the printer to the computer with the network cable, both of the devices are switched on, and still the computer does not find the printer. I tried restarting the computer a couple of...
By network cable, you mean CAT5 or CAT6 actual network cable, or did you mean USB cable? If you are connecting directly from your printer to your computer with network cable, it would need to be a cross over cable, not regular network cable. If you are using USB cable, here is a link to Samsung for your ML-1630W operating instructions. Reference page 3.2 for using USB with software CD.
http://downloadcenter.samsung.com/content/UM/200911/20091120134236000/Guide_EN.pdf
Dec 06, 2009 | Samsung ML-1630 Laser Printer
How to install Samsung ML-2851 without printer install CD, Because I miss the install CD Please help me
no not prossible withour printer ,
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
vivekryp@yahoo.co.in
Oct 07, 2009 | Samsung ML-2851ND Laser Printer
I want to set up printer (ml-2571N) in a local network
set an IP address on the printer compatible with your network IP address
"add printer"
select "local printer attached to this computer"
Select "create new port", and highlight "tcp/ip port"
type in your printer's IP apdress
Select "have disk"
Browse to the installation software, and install.
Select "share this printer" when prompted
Done.
Mar 07, 2009 | Samsung ML-2571N Laser Printer
Samsung ML 2010 under mac os X 10.5
I found a solution that worked for me by prowling around various Apple discussion forums. The two keys to the solution for me were numbers 3 and 5 below.
1. Opened print/fax preferences
2. Opened Add printer by clicking the +
3. For protocol, select HP jetdirect-socket (not IPP or LDP)
4. Determined the IP address for my Belkin wired print server and typed this into the Address line of printer setup
5. Manually selected the printer driver as ML-2010. It is in the list of drivers but is in the M's, not under the Samsung drivers.
6. This worked for me. I've seen reports from people who had to power cycle their print server and/or printer as well.
Jun 22, 2008 | Samsung ML 2010 Laser Printer
Samsung ML-2851ND Laser Printer Logo
1,481 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
