Question about Sanyo DVW-7200 DVD/VCR
Dvd player The vcr works fine. When I switch to the dvd function the the picture goes black. the disc door will not open and I cannot use any function on either the remote or on the unit itself. Then the unit switches back to the vcr mode automatically
  • 2 more comments
  • garybrenda Mar 30, 2008
    the vcr compartment is empty
  • garybrenda Mar 31, 2008
    The timer is not on, I had already checked it. I am not able to get the DVD out of the player, and the DVD player will not work. The VCR works great.
  • Anonymous Sep 27, 2008
    The exact same thing is happening with my dvd player. Is there any reason for this, or anything else that can be done?
  • darleneme123 Feb 17, 2009
    I Have the same problem and none of the above has worked is there a fuse for the DVD part of the player? VCR Works just fine but DVD seems to have no power to it no nothing
    New Friend:
  • 136 Answers
You must eject the tape in order for the disc player to work
Posted on Mar 30, 2008
  • Zahara Shah
    Zahara Shah Mar 30, 2008
    you may check and see if the timer is on
  • Zahara Shah
    Zahara Shah Mar 31, 2008
    you can unplug it and manually open it and remove the disc this is what i had to do unfortuneatly
GO VIDEO model 1030....VCR works fine...DVD..nothing happens...door won't even open?
Combo units have this essential flaw--if one half fails you are usually done especially if the DVD side fails.
If Door does not open either a disc is jammed inside the mechanism or the mechanism is out of alignment or damaged.
Good argument against buying these units--DVD individual parts are rarely sold--only (if available) would be the entire DVD unit itself--not cost effective to repair.
DVD players are now real cheap (see some for as little as $20) so if not a simple jammed disc or something like that buy a DVD player.
Apr 05, 2012 | GoVideo Go Video DVD/VCR Combo
DVD player doesn't work
you can open the top cover and take the cd out.
Jun 04, 2008 | Sony SLV-D350P DVD Player/VCR
DVD slot does not open. Can't insert into it.
Sounds like the dvd door is stuck. Try using a paperclip in the small hole by the dvd door to open manually. Once opened then try to use the button to close. Hope this helps.
Dec 22, 2008 | GoVideo Go Video DVD/VCR Combo
You should make sure that DVD lance is power. You can check the lance by switch on the door switch.
May 11, 2008 | Sony SLV-D350P DVD Player/VCR
FUNAI drvr-b778
Use a head cleaner to clean the heads on the vcr.
Jan 09, 2008 | Funai PY90VG DVD Player/VCR
Vhs dvd combi panasonic dmr ez47
If you select the HDMI channel to watch a dvd does it do it then, if not disconnect both ends of the scart lead and reconnect or replace. If the scart lead is not in properly this could happen, when you switch on the player and play a disc your tv will automatically switch to the AV/Scart channel, but you are better off manually turning the TV over to the HDMI Hi-Def channel for DVD.
Dec 24, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Samsung dvd-v4600
Wish I could. I have the 4600 combo and the VCR works fine. The DVD stopped working many months ago and just yesterday started working fine again. Worked fine for two days and then stopped, picture froze, and all I got out of it, is the picture is loading. Wont give me back my DVD nohow, so have opened the case and stole it back. Tray will not open at all. Trying some repairs, will holler if succesful
Dec 20, 2007 | Samsung DVD-V1000 DVD Player/VCR
Dvd won't play
sounds like microprcessor board failure the best thing to do is get a new unit
Nov 27, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Insignia DVD Player
Try hitting the "Lock" button on the remote. That solved the problem for us.
Dec 03, 2006 | Insignia IS-DVD1001 DVD Recorder/VCR
Dvd/vcr combo,vcr is fine ,but dvd no picture,or sound,disc reads.
Hi There is an I/P button on your player's remote control. Power your player on then press the I/P button on your remote control.
Aug 16, 2006 | Apex Digital ADV3800 DVD Player/VCR
Televison & Video Logo
134 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
