Question about Frigidaire ATF6000ES Front Load Washer
Softner releasing during first fill up
For some reason my softner is releasing in my first fill up in a normal cycle and i definately have it in the right basin so i'm not sure why this is happening? Can u help?
  • 770 Answers
Has anyone worked on this machine>?? The reason I ask is the disp. is flushed with water by a solenoid valve if the wires were swapped then it could be flushing out the cup when the say it should flush out the soap?/ let me know and we can move on from there
Posted on Apr 01, 2008
SOURCE:
The water isn't filling into water softner for setting up
Depending on the washing machine, it is supposed to have a gizmo inside the softner housing that triggers the water during the rinse cycle to flow into the softner dispenser. Sometimes, they go missing or are clogged with hardened softner. Open the door fully open and carefully prize the entire housing out. Clean it with hot water and put it back in. Some machines require the slide in tray be raised about 70 degrees (most common) and then pull out, others require a downward angle.
Mar 12, 2015 | Washing Machines
In my hotpoint ultima WMD942P washing machine's softner compartment i always find water at the end of the cycle. its a new machine.
This is completely normal, the machine puts water into this chamber during the rinse cycle to wash the softener into the machine.
Mar 05, 2012 | Hotpoint Washing Machines
Softner is dispensed in Wash cycle
in the top of your soap draw compartment is a lever that switches the water jets over ( for instance on the main wash the jet arm is directed in the main wash compartment which will take away your main wash powder then it moves the jet are to the sofner compartment on the final rinse ) the jet arm somtimes jams and needs cleaning and the small holes above your draw compartments clog with lime build up the thing to do is take out your draw clean the inside at the top where the holes are and take the top off your machine there are two screws at the back top you will see the little ark on your soap draw it will have a return spring on it gently move it from side to side this will clear any obstuction make sure that it will spring back clean any line around the arm ( make sure you switch unplug your machine before you remove the top)
Nov 21, 2011 | Washing Machines
Fabric Softner not leaving dispenser
Run some vinger through it. Fabric Softner leaves a filmy residue that can clog it up.
Jan 11, 2009 | LG DLE5932W Electric Dryer
The fabric softner drains out as soon as I pour it in
the fabric softner drains or flushs down in the rinse cycles,,,now if you fill past the line or open in dispencer it will sphion down by it self,,in short your overfilling dispencers,,onthejob
Jan 07, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Oasis HE 27082 Front Load Washer
ohm the release solenoid. could be shorted or open. check for voltage to the circuit
Sep 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Softner won't drain
Sir,
if you mean that the softner (from the detergant drawer) will not enter the drum during the normal cycle, then....
the softner has become solid, you need get hot water and get the hardened softner loose within the pipe to the drum clear.
I suggest using a solid electrical cable core to clear it
Aug 04, 2008 | GE WCVH6260F Front Load Washer
Whirlpool duet fabric softner problem
It obviously is backed up or splashed in from the wash. And if it is just water why worry about it.
Aug 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
