Question about Samsung CLP670ND Colour Laser Duplex Printer
How do i fill tonner cartrage - Samsung CLP670ND Colour Laser Duplex Printer
  • davidbevingt May 16, 2010
    had a go. got to the refill plug took 10 min to work it out. Why bye a new catridge?
  • 22 Answers
You might as well just get a new toner catridge
Posted on May 16, 2010
Ink system failure
hi there
usualy the ink failur happens when the ink cartrage is the wrong one or if you try to fill it yourself.
some printeer does not "like" the cartrage to be filled again, and evry one has it own "trick" to overcome the the failur after refilling the catrrage.
" RYLWY"
Nov 13, 2013 | HP Photosmart 3310 Printer
My laser printer taking page but i cant find any output after printing finish.
did you check up the tonner status
tonner may be finish
Change the tonner / re-fill
May 30, 2011 | HP LaserJet 1020 Printer
How to fix error replace/print cartrage in xerox 440ps If this error is cartrage chip or tonners, i have not availble chip while tonner is available. if problam is chip, what is tricks & tips
You will be wasting money buying just a chip. The toner and all is in the cartridge. Normally when the replace message comes on, the cartridge is shot.
Nov 23, 2010 | Xerox DC440ST Copier
How to refilling toner in canon lbp2900b
it a very easy to refill the 12 A tonner
remove the drum from cartriage then find 2 hook fixed the cartriage just relese it you find your cartriage divided in to 2 parts relese the nut from other side of the cartriage open the cap then fill with the tonner fix all
Nov 08, 2009 | Canon LASER SHOT LBP-2900 Printer
How to refil Cannon LBP2900 cartridge
you do not have to take the whole printer to the shop to fill the ink cartrage if you have the manuel to the printer it should tell you how to remove the ink cartrage and replace it with a new one and also they may have a refill kit at one of your local computer stores or where they sell ink and they should be able to tell you how to get the ink cartrage out to replace it
Sep 02, 2009 | Canon LASER SHOT LBP-2900 Printer
Paper is jammed inside, probably several sheets. how do i open thetop of the unit?
at the back of the printer there is access door.you will have to remove the door slowly and you can remove the paper easily.try it slowly.thanks. please do rate the solution.thank you for using fixya.keep updated.
Sep 01, 2009 | Canon PC-795 Copier
CANON PIXIMA IP5300 cartrage problem
I can suggest you one thing. If you can't do it yourself, get a friend who can.
Make a small hole (using a drill) in a new cartridge. This hole should directly go to the ink cartridge. (Make sure you don't spill ink everywhere!) Make a similar hole in the old cartridge. Take a syringe and pull out some ink from the new cartridge. Put it into the old cartridge. If you can see the ink level, fill about half of the old cartridge this way. Close both holes. Now use the old cartridge in the printer!
(You can repeat this process whenever the old cartridge runs out of ink).
Aug 13, 2009 | Canon Office Equipment & Supplies
Empty Ink Cartrage message when cartrage still has a lot of ink.
I'm going to provide you a solution worth many dollars now you can use your left over half filled cartidges and in future also use the cartridges to the extreme.
1. Go to menu and select manual override for toner cartridges and then only replace toner when the print quality starts to suffer. This can save you thousands of dollars over the life of this fine printer.
2. download and read this
http://74.125.153.132/search?q=cache:9mwf_bY_x-AJ:www.refill4.com/refillinstructons/pdf_downloads/Full-RefillInstructions.pdf+brother+mfc+5840+override+cartridge+empty&cd=6&hl=en&ct=clnk&gl=in
Jul 26, 2009 | Brother MFC-5840CN All-In-One InkJet...
Color ink cartridge says empty i just filled it
When you put in a "new" cartrage the printer sens an electrical charge to the cartrage to set it up properly. So I would treat this as a new cartrage, rather than a refilled one. Go to the printer menu and re install the ink cartrage in question, it should recognise it and start the function as a new one, good luck
Mar 24, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Replace tonner catridge error
Dear Sir; You fill up the cartridge that's fine,but you forget to change RF chip, it located right behind the cartridge, if you don't replace it , machine not going reset .
Jan 08, 2009 | Xerox CopyCentre C118 Copier
Samsung CLP670ND Colour Laser Duplex Printer Logo
27 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
