Question about Bosch WAS20160UC Front Load Washer
Will not finish the cycle
Wont finish cycle and water left in drum, wont drain i tried a quick wash but it still wont drain
  • 8 Answers
SOURCE: Bosch Washer
Yes, check the brushes. Our 7-yr. old WFK-2401 just stopped spinning and a brush change did the trick. Repair people wanted $350 for a whole new motor, but it was only the brushes. Replacing them is not very difficult if you are somewhat handy with a 1/2in. wrench and have some common sense about mechanics and electrics. Just look carefully as you loosen motor - disconnect its wires first, and think, and study, and try to understand what you're doing. I took lots of photos just in case. In the end it was easy; make sure to get belt off motor and motor will be out in no time; just two bolts to undo. Also, make sure you put brushes in properly - their tips are slanted and need to go in the right way and make full contact with commutator inside. Again, common sense. Bosch sells brushes, also RepairClinic.com, for slightly more but real Bosch parts. I paid the latter $45 with shipping - Bosch part No. 154740. Another option is to take motor out and find local motor repair shop and have them do it. Bosch won't help you. Power to the people - and the motor!
Posted on Sep 05, 2007
  • 1294 Answers
SOURCE: bosh logixx
Click on your model number above (below FIXYA ) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you will hv your manual on line. If available that is.
And rate me pl if helped............
Posted on Feb 25, 2008
SOURCE: Why is the fault F18 error code on my bosch washing machine flashing?
Open the small flap at the front bottom right of the machine. DONT unscrew the circular white knob yet!!! Use the small black hose to drain the machine into a tray, by removing the small cap on the end of the hose. You will have to use a tray, rather than a bowl because the hose is only short, and keep emptying the tray.(put a washing up bowl next to the machine, so you don't have to carry the tray.) If water does not come out of the hose, then gently unblock it with a piece of wire or fine knitting needle. When water finally stops coming out of the hose, it is time to gently unscrew the white knob anti-clockwise, and pull it forwards. Now you can clear the debris out of the pump rotor, which is behind the white knob. Check with your finger that it can rotate freely, then replace the white knob firmly. Make sure the small cap is replaced on the end of the hose, clip it back into place and put back the cover panel. If this doesn't work then there is a blockage deeper in the machine, and dismantling will be required. Good Luck!!
Posted on Dec 24, 2009
barkencoa
  • 3463 Answers
SOURCE: The water will not drain from my drum. The spin
Check the filter, which is located at the bottom front right of washer behind a flap or drop down cover.
Unscrew anti-clockwise to remove and clean.
Please rate my solution.
Thankyou.
Posted on Jan 28, 2010
SOURCE: not finishing cycle & wont heat water up!
to solve this disaster you must.......
...... GET A NEW ONE AND STOP BEING SO CHEAP hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahaha
Posted on Feb 04, 2010
Testimonial: "yeah cheers mate massive help that was grow up!"
In a samsung yop loadinf HE wash machine, should there be water left under the drum after cycle is finished
Either clogged outlet or if you are running an aux hose to outside sometimes the water freezes causing an ice plug and wont drain .
Jan 23, 2016 | Samsung DV422EWHDWR 7.2 Cu Ft Capacity...
Rinses light flashing fast and wont drain drum and finish wash
Try checking the filter for a blockage or pump being jammed with a button , disconnect drain hose at sink hold a few feet off ground over a bucket should pump/ flow quite freely if not then check filter and pump. good luck
Oct 13, 2014 | Miele Novotronic Premier 500 Front Load...
How do I drain all the water from the drum?
Depends, on model but all will drain if you disconnect the tub to pump hose. Do not confused liquid manufactured into the bowl for balancing on spin with a small amount of water left in the outer bowl when the cycle is finished.
Dec 21, 2013 | Washing Machines
Hotpoint WMA76 - been on a normal wash cycle but wont spin to drain water - cycle finished, drum full of water and cant empty. How do we empty it to open machine?
Remove drain outlet hose from point where it discharges into waste pipe, and lay the hose down into a bucket or bowl, this should let the water syphon out, enabling you to open the door.
Dec 29, 2010 | Hotpoint WMA76 Front Load Washer
Washing still wet after washing machine cycle. After full cycle the wahing in the machine was still soaking wet
Either the pump is not emptying the machine quickly enough, or the drum is not spinning. This could also be because there is too much water left in the machine. Check that the drain hose is not blocked and that water is draining/pumping out of the machine. A partial blockage will extend the drain period and the machine may not have time to empty the drum...Good luck......Nomess
Apr 18, 2010 | Washing Machines
Water appears in drum after wash cycle is finished.
if you remove the front cover there is a drain plug that holds change and lint paperclips etc, it fills up and gets plugged and wont go throught the drainig pump. if you find this and clean it out you will be good for another 6 months...its important to check pockets before washing
Sep 09, 2009 | Washing Machines
Water is always left in the machine when the cycle finishes
Because the water pump operates as a timed cycle, a partially blocked water passage either from the outer drum to the pump, inside the pump, or from the pump to the house drain is restricting the amount of water being pumped. Remove the drain hose from the house drain just enough that you can watch the water flow during a normal pump cycle. The water should be coming out quite forcefully--if just a trickle, then something is blocking the flow. Look for kinked hoses or even a slow running pump.
Jul 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Bosch WAS20160UC Front Load Washer Logo
188 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
