Question about Cameras
I have a samsung ES250 camera and like taking photos with it, but I don't know how to store photos on the computer from the camera with it! Can you please help me...? thanks!
5 Suggested Answers
  • 102366 Answers
SOURCE: my camera samsung lenz keep saing CARD LOCKED when I turn it on
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Apr 16, 2010
oxlena
SOURCE: Samsung S730 camera wont take photos with flash
I have the same problem with the same exact camera. Before the flash stopped working, I was taking pictures and the flash was making noise. Every time it flashed, it'd make a loud snapping sound. It only flashed 3 times before the flash finally kicked the bucket... Now I can't take pictures when the flash is turned on.
I read somewhere to try new batteries because the flash might not be getting enough juice, but I highly doubt that's going to work.
Posted on Aug 13, 2010
  • 34 Answers
SOURCE: 1. When camera is powered
Take out the memory card and find a friend/library with a laptop or computer with a slot for a memory card. A lot of people don't realize that they have this! On many newer laptops it will be on the front side of the laptop, with a mock card inside to protect the connections. If you can find this slot you will definitely be able to retrieve your photos. Let me know if you need help finding them on the computer once the card is inserted.
Posted on May 18, 2011
  • 11967 Answers
SOURCE: When I go to turn
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 14, 2011
We bave used Samsung Camera old one for the wound photo for the patient, recently we had lost accessary to connect to computer printrer.I could not find accessary through the shops in Sydney Australia. Do...
any electronics store should have the cable instock...it will be a type of USB cable.. if you take camera into store they will know what cable by looking at the connection on camera. will be around $12AU
May 19, 2014 | Samsung Cameras
I don't know how to take photos on my nexus 7
The Nexus 7 does not come with a built in camera app. I guess Google figures since there is only a front-facing camera that folks won't be taking too many photos.
I recently came across an app on Google play that will allow you to launch the camera to easily take photos. You can find the Camera Launcher App for Nexus 7 on Google Play.
https://play.google.com/store/apps/details?id=com.modaco.cameralauncher&hl=en
Apr 03, 2013 | Tablets & eReaders
I have a memory stick in my camera but no place to insert it in my PC Other than taking the memory stick to a photo shop and have them put the snaps on a disc. Don't know what else to do. Anyone
Get a memory stick adapter from any local store. Then you can connect your memory stick using that USB adapter to your computer.
Oct 27, 2012 | Cameras
I cammot see my pictures in the camera i dont know what to do ?
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Aug 27, 2012 | Samsung Digimax S700 Digital Camera
My computer can't read the camera and i don't have card reader
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Jul 18, 2012 | Samsung TL34HD / NV100HD Digital Camera
I have a Nikon Coolpix L110. I made the mistake of taking pictures without putting in my memory card and now my photos are stuck in my internal memory. I cannot locate the cable I have to connect to my...
No sorry, you cannot transfer the pictures from internal memory to the memory card. You can buy a USB cable online on that big auction site (they don't pay me, I don't write their name) for about $5 including shipping. Don't pay $35 at a retail store for one whatever you do!
Thomas
Sep 13, 2011 | Nikon Coolpix L110 Digital Camera
1. When camera is powered off, lens will not retract. "Whirring" noise heard 2. When camera is powered up the lens will extend. However there is no image seen on the screen when the camera...
Well If the photos you want to retrieve are on the 15Mo of internal memory, there is not much to do here except to see a repair center.
If they are not on the internal memory, open the Battery hatch of your camera, push on the small card that is close to the battery, then take the card out.
Now you can plug this card directly in a card reader.
If you have a laptop you might have a compatible card reader on it, otherwise buy one, it is always usefull.
Retrieving the photo this way on any camera saves battery and is usually faster than when using an USB cable.
Hope this helps
May 18, 2011 | Olympus Stylus 1010 Digital Camera
Try to take picture but message on screen memorie full how to fix that? samsung NV10
Hi, Memory full means there's no more room to store photos and video so if you delete some photos and videos off of the memory then you can take more. This can be done from playback mode in the camera or on the computer. If you need more help let me know =)
May 15, 2011 | Samsung NV10 Digital Camera
How i get my picture to edit it?
You would like to know how to get your pictures out of your digital camera so that you can edit them? No problem! I can help you with this.
First thing you need to do is make sure that you have a digital image program installed on your pc that will recognize your camera. You did not state what brand and model number of your camera, or I would have suggested one for you and provided a link to download to your computer.
Hopefully you have the disk that came with your camera, if so make sure that the software is installed before we connect your camera to your computer to download your photos. The pc will need the software in order to recognize your camera when connected.
If you don't have the disk that came with your camera, go to the manufacturers website and download the drivers and/or software to your computer. If you have an HP camera, you can find the drivers on their website at www.hp.com. The same thing is true for other brands. You can also go with a program that is pretty universal and accomodates most digital cameras like most of the photo editing software by "Arcsoft" or "Ulead". You can download a free version by either on Cnet's website (www.cnet.com).
After you have the software installed, connect your usb cord from your camera to your computer and then turn it on to transfer your pictures.
If you don't have a usb cord or prefer to use your memory card from your digital camera instead - then insert the card into the slot on your computer and follow the prompts to download and safe your photos. If your computer does not have memory card slots, then check your printer to see if it does and follow the same instructions as noted above. If you don't have a cord or a memory card slot on eithr your pc or your printer, then your next option would be to take your memory card from the digital camera to a local department store with a photo department and have them put the pictures on a compact disk or dvd. You can always save the pictures to your pc from a store supplied disk and edit them in your photo software. CVS drug store has a great photo department.
Hope this helps?? Good luck!
Apr 27, 2011 | HP Photosmart E327 Digital Camera
I have a Genius digital camera it is G-shot D610. I have taken photos without a a memory card. The photos are sitting in my camera and I don't know how to access these photos. I don not have a usb cord for...
The only way you will be able to access the photos on your computer is by plugging in the camera via USB. You can purchase a USB chord at any electronic store.
Mar 14, 2011 | Genius Cameras
Cameras Logo
288 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
