Question about Samsung LE40R73BD 40 in. HD-Ready LCD Television
Clicking sound dtv is not available and its making a clicking sound
All input sources eg. DVD, cab/sat, cd, tuner etc have audio out of the amp ... but not the tv. Can someone help me with this one?
Have you checked to make sure the TV connection is from the correct TV output? The TV is not on mute? Recheck all connections. The amp obviously works ok.
Dec 26, 2013 | Yamaha RX-V1600 Receiver
Toshiba 19DV500 b will only pick up BBC1, BBC2, ITV, C4, C5 no freeview channels. there is no reset or reinstallation options
Hi, sounds like you are in Analouge mode and not in DTV mode so you can't access the DTV menu to tune in the tv.
Press the 'SOURCE' button and move to DTV using the arrow keys, then press ok and if channels aren't already tuned you will now be able to tune them by accessing the DTV menu by pressing the 'MENU' key on the remote control.
If you don't have the manual you can download it or view it by clicking ----> HERE
Hope this helps.
Feb 09, 2011 | Toshiba Televison & Video
Formatting the hdd message came up out of nowhere and now its making scratchy sounds during the format
Hello
#1
Insert your ( memory card , flash disk , cellphone , .... ) into your computer.
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Jun 25, 2010 | Directv Plus DVR DTV Receiver / 100-Hours...
Cant get dtv to work on panasonic
Do you live where DTV is available? Does the TV support DTV? Are your signal levels adequate? Have you switched the set to its DTV setting? Have you run an autoscan?
Jul 17, 2010 | Panasonic Televison & Video
Audio output levels disparate
make sure volume is up on the ipod.....bc you can control vol. on your receiver with the ipod
Jan 03, 2010 | Yamaha RX-V2400 Receiver
Radio Schack converter doesn't program Ch: 25 like Magnavox!
Returned product to dealer. That fixed my proble.
Thanks...
Aug 19, 2009 | Philips Magnavox 20MT133S 20" TV
DTV Tuner Inoperative Until it Warm UP
The DTV board is bad. Replace the board will fix it.
Nov 06, 2008 | Vizio GV46L 46 in. LCD Television
No sound all of the sudden when on dtv
make sure input mode selector on the front is set to either analog or or digital. For example if the sound input from the dtv/cable is analog and you have it set to digital, you will get no sound. Change it to analog. This happens to me when using my crappy dvd/vhs player and I have a vhs playing (analog). Hope this helps...
May 22, 2008 | Yamaha HTR-5840 Receiver
Samsung LE40R73BD 40 in. HD-Ready LCD Television Logo
218 people viewed this question
Jerry Greenberg
Jerry Greenberg
