Question about Panasonic KX-TG6700 Phone
How to turn off the auto answering and recording mode of Panasonic KX-TG6700CB
  • Panasonic Master
  • 12,061 Answers
Www.devicemanuals.com/.../Panasonic/Panasonic-KXTG6700-TELEPHONE-TlRJNE1nPT.html - all in manual above
Posted on May 16, 2010
Record message on Pansonic kxtg4021 cordless phone answer machine
With the phone in standby, press Menu on one handset. Use the Up/Down arrows to navigate to Answering Device. Press OK. Navigate to Greeting and press OK. Select Record Greeting and press OK. Highlight Yes using the Up/Down arrows and press OK. After you hear the beep, hold the handset about 8" (20 cm) away and speak your message. Press OK when you have finished the message. (The recording will end after 2 minutes.) Press Off to exit the menu system.
The answering system may need to be on for this option to be available. You can turn it on by pressing the Answer On button on the base. Alternatively, press Menu and navigate to Answering Device. Press OK and select Answer On. Press OK. Press Off to exit the menu.
The manual for the KX-TG4021 is available from Panasonic on the product site: http://shop.panasonic.com/support-only/KX-TG4021N.html . The direct link to the manual is ftp://ftp.panasonic.com/telephone/om/kx-tg4011_mul_om.pdf . See page 28.
I hope this helps.
Jul 09, 2016 | Lands Phones
How to continue using device as answering machine but route fax to new HP all in one
hook the answering machine after the fax and set the fax to answer after 4 rings and the machine after 5.
This option should be somewhere within the menu of the HP
Let me know if you can't find it
May 22, 2008 | Panasonic KX-FPG391 Plain Paper Thermal...
How to keep auto answer mode
Panasonic KX-FHD331 has Receive Mode Button (Just beside Display screen)at the top control pannel, as shown below: -
Press the button "RECIEVE MODE" Button and set the Fax to "FAX MODE ONLY" and the fax will automatically answer the calls in your absence. For further information you may refer to Page-52 of the Operating Instructions Manual.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Mar 31, 2011 | Panasonic KX-FHD331 Plain Paper Thermal...
My panasonic KX-TG5663B's screen says 9 and a little circle. The answering machine is not working. It just tells callers we are not available and hangs up. Can you assist us with this issue?
The answering system is set for the greeting mode. It will enter this state if the message memory is full or when the caller recording time is set to Greeting only.
To change the caller recording time from the handset, press Menu 0 6 2 then select the desired length of the recording. Then Save the setting and press Off.
If the phone is in this state, then delete messages from the unit. Then reset the caller recording time.
The manual for the phone is available here: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/5-8-GHz-Phones/Operating-Instructions/model.KX-TG5653B.O#ts .
I hope this helps.
Mar 30, 2011 | Panasonic KX-TG5653B Trio Cordless Phone
Why does the auto dial/store button lights up by itself on the kx-t7730
Get a picture of that and send it to Panasonic! Your phone would be the *ONLY* one that does, since the button has no light.
Now, the AUTO ANS/MUTE button lights up when pressed to put the intercom in the Auto Answer mode under certain conditions. That could be the one you're seeing. It either forces intercom calls into auto answer if it's a ringing call, or into handsfree answerback if it's a voice call. It also indicates a muted microphone on speakerphone calls.
Carl
Aug 17, 2010 | Panasonic KX-T7730 Corded Phone
Cant change the nite mode to a day mode
On the phone press PROGRAM, press the original DAY button, dial the number 2, dial 781#, press AUTO DIAL STORE, pick up and drop the handpiece.
May 21, 2010 | Panasonic KX-T7730 Corded Phone
Turn off the auto answer
in right side auto ans switch is there press it
Mar 01, 2010 | Panasonic KX-FL511 Plain Paper Laser Fax
How can I turn off the auto answer feature of the pansonic kx fh332. I never want it to pick up and go to fax mode.
Set the fax machine to Telephone mode by pressing
{RECEIVE MODE} until TEL MODE is
displayed.
You might also want to dowload the Operating Instructions for you fax machine: KX-FHD332 Operating Instructions (English) (17208 kb)
Aug 03, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
Recording a greeting
You need to be in Tam fax mode firstly.
1, {#} {0} {0} {1}:= “TAM/FAX” (default)
2,
Press {RECORD} repeatedly to display “TAM GREETING”.
3,
Press {SET}. A long beep will sound.
Speak clearly about 20 cm ( 8 inches ) away from the microphone.
The display will show the remaining
recording time.
5 When finished recording, press {STOP}.
The unit will repeat your message.
To erase and start again
Tam/fax mode again.
2 Press {ERASE} repeatedly to display “TAM GREETING”.
3 Press {SET}.
To cancel erasing, press {STOP}.
4 Press {SET}.
should be good now.
Regards
Richard.
Apr 24, 2009 | Panasonic KX-FPG376 Plain Paper Thermal...
Panasonic KX-T7433
Each phone has an AUTO ANSWER button. Press it. It should light up and you will be in AA mode.
On a TD system, the phone can be programmed to always AUTO ANSWER. In that case the button has no AA function.
Carl
Mar 24, 2009 | Panasonic KX-T7433B Corded Phone
Panasonic KX-TG6700 Phone Logo
123 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
