Hi, I have just moved into a new apartment and cannot get the indesit WD11 to work. Partly I suspect the problem could be that I have never used a front loading machine before (I realise this is unusal but in New Zealand we are dominated by top loaders :) However, the main dial just keeps turning and clicking through all the stages continuously and nothing seems to work as it should. Any suggestions?
    New Friend:
Yeah, i have the same prob. Its the worst, shittiest washing machine in the world and apartment owners in NZ love them. you have to put the dial on the to the reset and keep pushing until it flashes slowly. Then put the dial on the settingbyou want and keep pushing the button until it has a steady light. should start working without clicking thru the cycles. f%##%@ frustrating.
Posted on Apr 02, 2016
    New Friend:
  • 136 Answers
Yes make sure your door is closed and locked all the way if theres a lock
Posted on Mar 30, 2008
SOURCE:
I have an Indesit WIXL123 washing machine that wont drain! Have checked all pipes, no blockage, have replaced pump but it still refuses to work! Any ideas?
Since I have never physically worked on a Indesit, I can only tell you what a normal washing machince diagnosis would be: Drain pump is not functioning. Possibly something clogging the intake (count you socks) or just stopped working.
My supplier does not have Indesit parts so can't give you the part number for the drain pump.
Oct 03, 2011 | Indesit W 123 Front Load Washer
Indesit DI620 but won't drain the water after a wash
are you finding water in the filter or is the appliance filled with water,if it is only in the filter at the end of the cycle,this is normal as it is used to condensed the steam after the 80o final rinse which drys the cutlery.if ithe appliance is filled then check the drain hose not partily blocked with grease or partly blocked at the sink if plumbed to there
Apr 28, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Change grip/handle on a indesit washing machine w105tx
Undo any screw that you can see on the inside of the door frame, and then prize the two halves apart,
This should give you access to the door handle assy.
Hope this helps.
Dec 02, 2008 | Indesit WA 125 Front Load Washer
My indesit WG1230 washing machine does not spin or move drum but water go in and out.
With the door open, try spinning the drum, there should be some resistance along with a slight wherring sound. If it spins freely without much sound at all - you probably need a new belt.
If you can feel it driving the motor, you may need new contact brushes for the motor.
If the machine buzzes when it should rotate on program, you need a new motor Run capacitor also.
If no sound - nothing, the motor may need replacing or at least checking.
Nov 05, 2008 | Indesit Washing Machines
Indesit WD11
is the drum turning round. is it draining at end cycle ? if the motor is spinning is it slow at start turning left then right after a time or does it just spin when its on spin cycle ? can you hear a clicking sound when it about to move or hear a clicking sound and nothing moves ? if you hear a clicking but nothing is moving it could be the switch on the main board has worn out, it could even be the motor but if it does a spin it could just be the switch on the main board. they soldered in on the board you can replace them if you have soldering skills or would like to learn.
Jun 22, 2017 | Indesit W 123 Front Load Washer
Fitting a drive belt to an indesit WG1130TGT washing machine. how do I release the tension to fit the belt round the motor and pulley?
I don't have the exact same model as yours, but on my WE16 I just place the belt over the motor pulley and partly round the big wheell attached to the drum, and then turning the big wheel by hand the belt gradually goes on completely. No adjustment to the spacing is necessary, unlike, say, the alternator belt on a car.
Hope this helps ya :-) D
Remember to have the machine disconnected from the power supply when working inside it!
Jul 05, 2008 | Washing Machines
Indesit Washer/ Dryer 1200
A lot of times when people move they find their dryer has suddenly stopped working. Check the voltage at the outlet, make sure it matches the voltage on the i.d. plate on the appliance. I know people who didn't want to fuss with it and bought a new dryer only to find it did the same thing.
Mar 15, 2008 | Dryers
Indesit D41 Slimline
HI THERE - I ALSO INHERITED A D41 - I HAVE JUST FOUND - SITE WHERE YOU CAN DOWN LOAD INSTRUCTION MANUAL FOR MANY INDESIT PRODUCTS - I NOW HAVE INSTRUCTION MANUAL FOR MY D41 NICELY PRINTED OUT - SEE www.indesitservice.co.uk hope this helps you too - Helen
Nov 14, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Washing Machines Logo
186 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
