Question about Music
How do I play the O1WFD sequencer through the Triton Pro X??
I have wo Korg keyboards. One is a Triton Pro X, the other, an O1WFD. I have sequencing on floppy disk from the O1WFD that I want to play and record on the Korg Triton Pro X. To do this I have set a midi cable up from the out of the O1WFD to the in of the Triton. Nothing happens. What other settings do I need to do to be able to play the O1WFD sequencr through the Triton? Many thanks. Brian.
    President:
  • 1,137 Answers
Here is a link to a site with all the info you need:http://forum.recordingreview.com/f18/midi-troubleshooting-101-a-5208/ You will need to join which is free and well worth the time. I also recommend downloading the free book Killer Home Recording Setting UP.
Posted on May 18, 2010
I can hear only one side of the sound coming out from Korg triton extream keyboard. It's not the cable problem for sure. i tested both the earphone out put and the Left and right out put. Did a
So you're saying with headphones you also only hear one side? I would suspect the internal amp is panned all to one side. There are also several other settings in this unit where pan can be set so you may have to check several areas. If you don't have any specific custom settings made I would try a restore to factory defaults. If that doesn't resolve it you likely have a hardware failure which is likely not repairable. I strongly suspect a panning issue though.
Aug 18, 2012 | Korg Music
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
Hi. My Korg X5d shows a sequence of small squares in the display panel and will not boot. Can you help?
You need a reprogramming done from the Maker . Contact Authorized Korg Service center . Be away from frauds.
Nov 18, 2010 | Korg X5d
I have a korg i4s do not have the manual can you tell me how to record a backing track on it and is there any site I can go to to download the i4s manual
There's so many steps to describe here.
So, this is link to Reference User Manual :
http://www.manualslib.com/manual/686295/Korg-I4s.html
To record a backing track (Backing Sequence Mode), see the manual, start from page 19.
Mar 18, 2010 | Music
I own a korg triton music workstation sampler and when I create a sequence using the 16 tracks and I want to make a song using a que list all of my inserted effects on all the instruments do not work when...
you need to ensure that you have recorded the midi command to select each effect and level of that effect. this can be done in the midifile. you need to start record and very quickly at the start of the song you need to select the effect and set the level, whilst in record. this should write the setting into the song. you can check this if you use an external sequencer.
Dec 13, 2009 | Music
How do I transfer music data off my korg Triton keyboard's floppy
Either the floppy format of the Triton is not PC compatible or maybe you don't have a floppy drive on your computer? If the latter, buy a USB floppy drive... about $20
Sep 16, 2009 | Music
PA800 Instruments making noise
you have memory problem it cost $150 to fix it
Aug 06, 2009 | Korg Pa800 Synthesizer
I am trying to load the new OS for the triton studio. My studio says i need sysyem 1 disk. I don,t have it. Solutions?
They need to be downloaded from korg.com. You need to have a floppy disk drive to load them unfortunately.
Jul 14, 2009 | Korg Music
I was fixing my keyboard key and putting everything back together again and now the keyboard will play but it isnt the same. There is a delay to the touch of the key. I must have done something wrong. I...
If this is happening on all keys it sounds like your aftertouch is not set right. You may not have gotten the key assembly lined up quite right also. Check these first.
Jul 07, 2009 | Music
Music Logo
168 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
