Question about Fisher and Paykel GWL11 Top Load Washer
Our GW611 recently had a moisture problem with the controll panel. We have removed any trace of moisture, but the unit is not working. just keeps beeping. What should we do?
  • Fisher and P... Master
  • 12,061 Answers
ANY moisture on any electronics no matter how insignificant, or little time it is present, IF the electricity is ON, at the moment any moisture is present on the circuit board there is an instantaneous, electrochemical reaction, that usually totally destroys any components within, as currents track through the moisture, and current goes where it never should and causes failure, generally unrecoverable. So you will have to replace that entire unit with a new one.
Posted on May 16, 2010
Electrolux_els6115 flauty
Possible fault on the program controller unit , you need to remove power and see if there is any moisture on the control panel board. Use a dryer if there is moisture.
If the program does not work even after resetting there is fault within the board.
Nov 08, 2011 | Dishwashers
Moisture in keyboard.keyboard is not working.
If water has seeped into the keyboard then it is important that you must remove the battery from the PC. remove the keyboard and keep aside , use a hair dryer to warm the keyboard, use moisture absorbants to remove all traces before the unit can be conneccted back.
Please get some tips from the link below.
http://www.fixya.com/support/r6041626-when_device_falls_into_water_when
Jun 25, 2011 | Samsung N150 (36725723009) Netbook
I have a GECE7006 induction cooktop and next to the timer button it is flashing "Lo" and i cannot clear it to use any of the hotplates?
Remove the main power for about few hours and then plug the unit while you press the Start/Stop button. If the panel still blinks around, check for any traces of moisture on the panel. if so dry and check. If not the processor is having some errors which needs to be checked from within and requires Tech help.
May 19, 2011 | Baumatic Microwave Ovens
My touch screen is not responding to unlock the device
Possible fault within the display unit interrface to the main board.
The best is to try to remove any traces of moisture on the board , then reset to try . if not the panel is faulty
Sep 14, 2010 | Dopod 818 Pro Smartphone
Camera got a little wet. Now it says battery not compatible.
Please remove the battery and use an hair dryer to warm very carefully so as not to damage the camera. Keep it off for a long time so that every trace of moisture is lost.,However if the battery was put in before removing traces of moisture, there is every possibility that the camera electronics could be damaged. In such case you will need to remove and clean/dry the boards , use soldering iron on components to remove trapped moisture underneath, repeat the work to ensure there is no traces of water. Now set this back and try , If the same error comes abck, I am afraid the camera electronics section has encountered a defect which might need a replacement. Get help from the Sony serrvice centre, take estimate and decide. Hope this helps you . Good day
Aug 15, 2010 | Sony Cyber-shot DSC-HX1 Digital Camera
Fisher & Paykel GW611 Not filling with water
Hi just read your posting.Did you remove any wires to the control module which is located under the top panel when you replaced the bearings.Now did you put the cold inlet hose to the water valve marked with the letter C and the hot to H ?These letters are next to the valves.Have you got the Efficiency option button?Can you select a manual water level instead of just an auto fill?Have you tried to put the machine throe a spin cycle?Do you hear any water coming into the machine at all?Please with additional information to these questions and I am sure we can rectify this problem for you.
Jun 28, 2010 | Fisher and Paykel Fisher & Paykel Washer
Control panel unresponsive
open up the inner door shell after powering down the unit from the power source,wiggle and remove and replace all ribbon cable connections on the electronic control panels and any other connections you can see,moisture corrodes these connections after years and removing and re-installing these will sometimes wipe off any corrosion for a better connection to the machine the screws are on the inside of the door to access the control panel
Jun 19, 2010 | KitchenAid KUDR24SE Built-in Dishwasher
Kenmore Elite Electric Dryer, Model # 110.8586400, Control Panel Lights inoperative, But Drum Light works fine. I am going to try this procedure, Will let you know if it works. Jay/ Jacksonville Florida...
I followed that procedure, Taking the Electronic Control Unit out of the dryer, Blow Drying the printed circuit Board (PCB) Board out and reseating P3 and P4, Worked fine.. No moisture was found in the Drum area. I forgot to tag the TECH SHEET FOR this particular dryer . But punch in Tech sheet , Part # 8546206 into google, this gives Schematic and valuable Troubleshooting steps, The only thing i could not find was the pin to pin test on chekcing the individual switches on the main functions, Suppose to be 14 pins I only found 13. But in all drying the PCB board and reseating the plugs worked for me. Again the symptons were no Light indication on ANY button depressed but the drum light was on. Great Site, Not a first time user
Dec 04, 2009 | Kenmore Elite HE4 Electric Dryer
Air conditoner eelctronic temp setting goes up on its own as if Im pressing the button, then the controls stop working for 10 minutes
I had this happen on a Maytag unit. Condensation was getting behind the control panel, causing the buttons to short out and changing the temp. unscrew the front cover from the unit and carefully pop the tabs loose from the edges and remove the front plastic cover. then look around the control panel area and see if there is any moisture. if so, you will have to find out why it is wet (probably high air humidity). you could try stuffing some rags around the control panel and see if that keeps it dry. if its not wet around there, then you have a short somewhere, or your remote (if you have one) is malfunctioning.
Jun 09, 2009 | GE AJCQ08ACB Air Conditioner
How do I remove the control panel?
Figured it out. There are three screws under the lid. One of them is tough to get at, but if you remove the lid support and the phone rest the lid will open to 90 degrees. At that point the top just pulls away from the base unit. You may have to unsnap the small cover where the wires pass from the base to the top unit so you can pull enough slack in the wires to pull the top off the hinges. Once that's done removing the last screw is easy.
After the screws are out, prying around the edges of the panel unsnaps the remaining retainers and pops it right off.
The problem in our unit ended up being corrosion in the circuit area of the board. I cleaned up the corrosion and found one trace that was broken. I soldered a jumper around the broken trace. The broken trace was preventing 4 of the buttons from functioning. Once the jumper was in place all the buttons started working.
Back in business.
Jul 21, 2008 | Brother MFC-640CW All-In-One InkJet...
Fisher and Paykel GWL11 Top Load Washer Logo
198 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
