Question about Canon imageRUNNER 8500 Copier
Ir 8500 cannnon copier black shade on paper
Hellos sir i have ir 8500 cannnon copier black shade on paper
i exchange the 3 time drum cleaner blade
but still this problem
  • 59 Answers
Hi dude i dont think u have problem with drum cleaning blade coz it not making trouble for me from last 5years.
just replace the crona wires both charge and transfer and clean the whole scanner mirors .
thanks
Posted on May 16, 2010
How to change settings in system monitor (IR 8500), like time,sheet & copy details
Posted on Apr 16, 2011
SIR,i AM RUNNING IR 400 FOR 2 YEARS THIS TIME ONLY wHEN I CHANGE A DRUM THE PRINT WILL BE GOOD WHEN 200 COPIES CONTINUOUSLY TAKING THE DRUM DAMAGED IT MEANS SMALL CRACK ON THE DRUM AT THE FRONT DOOR SIDE...
first, did you install complete Canon original drum unit or just replaced with not genuine low quality drum?
Maybe the problem is in bad quality of drum.
In original drum unit you get whole unit with new drum, blade and charge roller.
Second, you should inspect the developing cylinder, he is magnetic and in some cases something like paper clip or other metal dirt can stuck on it and cause breakage or damage of drum surface.
I recomend you to remove the toner unit, vacume it and check for foreign materials, also rotate the developing cylinder and look for damages or foreign materials.
Hope that something of this will help!
Aug 24, 2011 | Canon imageRUNNER 400S Copier
I am getting white specks on all four colors on my phaser 8500 and some black smudges. I just did a smudge clean and it helped, but it didn't clear it.
Hello.
Try a laser printer roller cleaner (paper sheets), like PathKleen or Perfect Data. You may need to run sheets through several times before the cleaning is complete. Do not use a sheet more than once.
Hope this helps.
Feb 03, 2011 | Xerox Phaser 8500/SN Color Laser Printer
After changing toner on my sharp, SF-2022 copy machine, the copies are coming out with black smudge marks across the paper? how/where should i clean?
This means the machine is over-toning ie using more toner than required caused by either improper toner or different brand of toner. The correct toner is sf 222T1. Replace developer and use the right toner and clean the drum and its blade. You may need to clean fuser rollers for cleaner copies.
Nov 13, 2009 | Sharp Office Equipment & Supplies
How can i solve the black line and half black of whole paper?
Hello sir; Only thing you need to do is replace drum cleaning blade.
Nov 09, 2009 | Canon Office Equipment & Supplies
Drum is black
Hello sir; it is the time to replace developer.pull out developer unit ,right underneath drum unit, remove two snap clip open the ccover dump old developer clean out inside the unit with vaccunm cleaner. then fill in new devloper the simulation2801 & 2805.
Sep 06, 2009 | Ricoh Aficio 450 Copier
There is a line on side of the paper when I copy
A couple of things to look for. If this is a laser style printer, pull the cartridge and look for like a finger button and a long slot below it. Hold the cartridge in the light just right, this should be a 'Cleaner' for your corona wire. Slide it several times back-n-forth, reinsert back into the unit. If this is going through an ADF ( Automatic Document Feeder ), look for a long slot that has clear glass and a light bulb underneath ? When your paper curls around, 180 deg, look for the exact location in relationship to the black line you are receiving. Clean the speck off of the glass with glass cleaner or a finger nail. Nothing metalic that would scratch the glass or you'll have way more lines.
Toby White-Beebe
Dell Certified Lead Systems Expert
Aug 28, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
Vertical black line shows up on printed paper.
Hello sir;It is the time to replace drum cleaning blade.
Aug 18, 2009 | Ricoh Office Equipment & Supplies
Poor copy quality - lines on paper
Hello sir; The problem is caused by drum cleaning blade, you need to replace drum cartridge or drum blade if you can.
Jan 23, 2009 | Canon NP 6551 Black and White Copier
Canon NP7161copier ( Indicates 8z and stops copying)
Dark shades on both side of the paper? Drum cleaning blade or fuser assembly. Check the upper fuser roller and the drum for build up.
Jul 16, 2007 | Canon NP 6551 Black and White Copier
Canon imageRUNNER 8500 Copier Logo
309 people viewed this question
old marine
old marine
