Question about Acer TravelMate C302XMi Tablet PC
Removing hard drive - any ideas on how to do this?
  • Acer Master
  • 4,924 Answers
Http://www.youtube.com/watch?v=kH3clgG17v8&feature=related
the Hdd is either on the back ..and you have to remove the lid to get to it and get 'em out ..and usually it is written on the lid Hdd and the other ram if it has 2 of them in the back ...or ..for most it is a system like in this video ..Just 2 screws and slide out at the side from the plug ..
In both cases is a piece of cake to do the job ...just open the back and get it out..it will have a safety system in a few screws..or it will be at the side and have 2 screws that holds the caddy in place
Posted on May 16, 2010
Im looking for to fix the computer thats keep coming on the it shows a blue screen then it cuts off and it comes back on and it does it agen.
Hi
You don't say which version of windows you use.
This is a serious fault. You either have a hardware fault (hard drive, memory or graphics card), a corruption of windows or a virus infection.
If you can, use your cellphone to take a close up full frame picture of the Blue screen so you can read it carefully all the way through to see advice on what the fault might be and some recommendations on how to fix it.
First you must back up any important data you have on the computer.
If you know how to remove the hard drive, (unscrew small cover underneath with CDs icon next to it, then unscrew hard drive bracket containing hard drive and lift both up carefully) you should unscrew the bracket holding the hard drive and then insert the hard drive into an empty hard drive enclosure. connect the enclosure to another computer and back up all important documents, pictures, music, spreadsheets, designs, favourites, contacts etc.
Then put the hard drive back in the computer as before and use a Windows XP, Vista or 7 Tablet Edition CD or DVD to boot from the disc instead of the hard drive by tapping the F12, F11 or F10 function key a few times at the beginning of the boot and then attempting a Repair Installation of Windows.
Then restart, remove the CD or DVD and hopefully it will boot successfully.
Post a further comment specifying your Windows version if you need more help.
Hope this helps.
Aug 24, 2011 | Compaq tc4200 Tablet PC
My acer 4315 got problem with sound device. I have no idea how how to fix it.
WE NEED TO REMOVE AND REINSTALL YOUR DEVICE DRIVER _Driver_1.00.01.zip file and save to your desktop. Use a file compression software to unzip the file located inside MyBook_vista_windows7_Driver_1.00.01.zip to your desktop. You will now see a file called "MyBook_vista_windows7_Driver_1.00.01.exe" or "MyBook_vista_windows7_Driver_1.00.01" on your desktop. Double-click on "MyBook_vista_windows7_Driver_1.00.01.exe" or "MyBook_vista_windows7_Driver_1.00.01" to launch the driver installation program. The wizard will display a message saying that it is ready to install the driver, click Next. Accept the license Agreement and click Next Click Install to start the installation of the drivers. The driver will be installed without further interaction and should take only a few seconds to install. When the installation is finished, click Finish to close the installation utility. Reboot the computer system before connecting the My Book Essential or Premium Edition hard drive. After connecting the My Book Essential or Premium Edition hard drive, Windows will automatically detect the unit and a new hard drive icon will appear in the My Computer window. Your My Book Essential or Premium Edition hard drive should now be ready to use.
Jan 23, 2011 | Acer Tablets & eReaders
Cant install windows on lenovo X41 tablet pc
hi
you should check your hard disk may be there is a problem in your hard disk
May 04, 2010 | Lenovo ThinkPad X41 Tablet PC
Unable to install OS on Hard drive. Error PXE-E61: Media test failure, check cable. PXE-MOF: Exiting PXE ROM. Invalid partition table
When your computer failed to boot from the disk-drive, it tried to connect to a network-accessible "boot-server" via the Ethernet adapter.
However, if there's no cable connected to the computer's Ethernet port, you will get the "check the cable" error-message.
So, your real problem is "invalid partition table", which means that the very first record on the disk-drive is either missing or corrupt.
That first record contains the "partition table", which lists the size of the hard-drive, and the size of each partition (usually only one) on the hard-drive.
So, you'll need to buy an adapter that has a USB-plug on one end, and a connector for your "SATA" or "IDE" hard-drive at the other end.
Remove the hard-drive from your computer, attach it to the connector, and plug-in the USB connector to a USB port on another computer, and then use software to delete and then reconstruct the partition table.
Or, the hard-drive is failing, and must be replaced (maybe under warranty???).
Oct 22, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Recovering date from a Toshiba Satellite R10/R15 series
Not all usb enclosures are created equal. try change the cable that came with the enclosure for starters also make sure it is plugged into either a usb hub that has its own power supply or a proper PC that has usb ports capable of supplying the correct power to drive the enclosure
Aug 07, 2009 | Tablets & eReaders
Need to install new os for motion computing m1400 can anyone help
I suggest Windows XP Pro...
You can open a lot more programs than what you can on Windows Vista with the same amount of RAM etc....
Or you could go for Vista.
Is there a CD Drive does it connect to PC?
I have no idea how to work these.
If it connect's through USB Insert a Windows XP disk into your Drive reboot your PC and install it to remove able Drive.
If you want to ensure that it does not scrub your PC copy then disconnect your PC's Hard Drive.
Sorry if I make no sense I am tired.
Hope it help's.
-Tom.
Jul 14, 2009 | Motion Computing M1400 CENTRINO 1.1G 512...
Don't know how to get rid of hard drive password on toshiba lapto
A hard drive password can only be removed by the person who knows the password because then it can be cleared thru the BIOS.
Otherwise the only other way around it is the buy a new hard drive so it doesn't have a password and you can then reinstall the operating system on the hard drive and then put the drivers on it and any other programs that you want on it.
Apr 07, 2009 | Toshiba Portege M200 Tablet PC
How to remove the internal hard drive
enter in bios and disable ide or sata on which your harddrive detectd.
then simply install win xp in external usb harddrive.
Jan 04, 2009 | Toshiba Tecra M7 Tablet PC
Toughbook CF-18 Supervisor Passwd
Toughbook CF18, CF-18
How to remove the BIOS Supervisor Password:
Open all covers and openings. Remove hard drive and battery. Remove bottom of notebook. Many many tiny screws.
Now look towards the rear of the notebook. You will see 2 plugs both have a red and black wires. The one with the much smaller wires and connector is the BIOS battery. Use a pair of needle nose pliers and remove this plug.
Leave it off for 5-15 minutes.
Leave the BIOS battery plug off. Replace the laptop's main battery. Leave the hard drive out. Turn the unit over and turn it on.
Press F2 when the screen comes up. POOF! NO PASSWORD!
Go to Security and disable the password. Save configuration. Turn off the notebook. Replace the small connector. Turn it back over and turn it back on. Press F2 and verify that there is no password. Go to Security and Disable the password again. Save the configuration.
Put the bottom back on. You're done.
NOW FOR THE BAD NEWS!!!
Your hard drive is now dead. Replace it. When a supervisor password is used it locks the hard drive to that password. There is NO WAY to recover the hard drive. It is called an ATA security password. Without the ATA password the hard drive is completely useless.
Nov 10, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Problem with Hard Drive
The easiest way to do that is to purchase an external enclosure for your type of desktop hard drive. They come with usb, firewire or both types of connections. It is a simple matter to remove the hard drive from the desktop and install in the enclosure. Plug it in and connect to your notebook. The enclosure will be seen as another hard drive and you can then copy what you need from the desktop hard drive to the notebook. Once on the notebook you can burn to dvd's if you like. This will not work for copying programs. They may still work, navigate to the program folder on the hard drive, find the application folder, open it and find the starting icon, right click on it and send to desktop.
All this is moot if the drive itself is too damaged to spin.
May 12, 2008 | Lenovo ThinkPad X60 Tablet PC
Acer TravelMate C302XMi Tablet PC Logo
Top Acer Tablets & eReaders Experts
Lawrence Oravetz
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
