Question about SanDisk Sansa e250 MP3 Player
I have a sansa e250 mp3 but my computer wont recognise the usb device so it can be charged neither will the other 3 computers in the house. what do I do??
  • 503 Answers
you need to right click on my Computer>Manage, then select Device Manager option in left hand side, Then in right hand side window you will have option Universal Serial Bus Controler and it would has a + sign, spread it, then you will have some options there if you have yellow exclamatory mark on any option so you need to right click on it and click on update the driver and then your USB device should be charged and you need to also check what is the version of your USB device. To install the USB Driver on your computer you can use
nirsoft.net/utils/usb_devices_view.html
you need to login to it and you can install the usb drivers.
Posted on May 16, 2010
HI, MY NAME IS ANGELA. I PURCHSED A SANSA MODEL
The Sansa charges via the USB cable. Fully charged, it should be good for 12-15 hours of playing. Be aware that not all computer USB ports put out enough current to charge external devices. If your computer doesn't charge the Sansa, try a different computer. You can also charge the Sansa using other USB charges, such as you'll see for charging cell phones from a wall outlet or a car cigarette lighter.
Jul 23, 2010 | SanDisk Sansa e250 MP3 Player
My sansa wont turn on
well did u make sure it is fully charged if so den plug it into the computer
Aug 20, 2009 | SanDisk Sansa e250 MP3 Player
My sansa e250 could not be detected on my computer
In Normal conditions, after plugging in the MP3, amd waiting one or two minutes, the device should be installed automatically by the system. This works in the same way on Vista and on XP. On Windows 98 and Me the device may not work. After the MP3 is installed, you can reach the Sansa under My Computer (Computer). It will be displayed as an external disk named Sansa. If you are using an USB extension or an USB external hub, get rid of it. Try plugging the MP3 to a different USB port. Try unplugging AC charger, and removing laptop batter for ten minutes, sometimes this can fix problems caused by accumulation of electrostatic charges on USB controller. If that does not solve the problem, test a different USB device on the same laptop, and test the MP3 on a different computer. Either one may be faulty. If the problem is the laptop you may fix it by removing and reinstalling USB root hub on hardware devices in Control Panel.
Jun 05, 2009 | SanDisk Sansa e250 MP3 Player
My Sansa wont take a charge? Can someone help me?
Probable causes:
1) Sansa connector is damaged
2) Cable is damaged
3) USB port is damaged
Have you tried other computer/cable ?
If you did and it didn't work, you'll have to take it to service since it would mean something is damaged.
May 27, 2009 | SanDisk Sansa e250 MP3 Player
The computer wont recognise my mp3
try messing with the usb settings on the mp3 player in settings/ system settings/ USB mode/ for a newer PC try MSC for an Older PC or mac try Mtp and if that dosen't work try auto detect just mess around with it fir a while
Apr 09, 2009 | SanDisk Sansa Fuze MP3 Player
SANSA E250 IS NOT RECOGNISED
There are two connection settings in USB: MTP and MSC. For some reason MTP is the default, but it doesn't connect properly on all computers. Select MSC and plug the player in again, the computer will recognize sansa e250 but not show the driver just yet. It is installing recognition software (just basic drivers - nothing heavy) and it doesnt tell you what its doing until its complete. WAIT FOR IT. Once it is complete you will see both the sansa e250 and the removable memory slot in your "my computer" now you're good to go.
Jan 28, 2009 | SanDisk Sansa e250 MP3 Player
When i connect my sansa clip 2gb it will not charge. it say connected and then goes off. I thought it was charging but when i checked it the battery had died what do you suggest i do to get it working...
Check for the following:
USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure the computer isn’t entering hibernate or sleep mode while the device is connected.  The computer must be on in order to charge your player.
USB Port 2.0
Make sure the player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged.  It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater
Jan 23, 2009 | SanDisk Sansa e250 MP3 Player
Cannot delete the songs on mp3
I do mine through Windows Media Player
1)Plug in Sansa
2)Open up Windows Media Player and wait for the Sansa e250 icon to show up under the library. First time, might say 'What device is this' or 'Autoplay'-for autoplay,you click 'sync media files to Sansa e250 using WIndows Media Player'
3)When library shows, click 'Sync' if it is not already there.
4)Just simply click and drag the songs you want from the computer library to the list pane on the side.
5)Once your done, click 'Sart sync'
TO DELETE
1)Plug in
2)Wait for the icon under Library in WIndows Media Player
3)Go to Songs under Sansa e250
4)Right click desired songs and choose Delete. You only want to delete from Sansa e250-nothing else
~loli~
Dec 23, 2008 | SanDisk Sansa e250 MP3 Player
Wont turn on
I don't know if this applies to the Sansa for sure or not but many MP3 devices and smartphones if completely dischard will not charge back up via usb to computer, you have to use a wall jack charger. This is true for the Motorola Q and other smart phones I know for a fact, also the Apple Ipod Gen 5 has had some issues with charging after complete discharge of the battery. Try a wall charger if possible. I don't know much about the sansas.
Jan 07, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
83 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
