Question about Whirlpool EL7ATRR Refrigerator
Swopping the door over
How do i change the door over from one side to the other
Passenger rear window will go down wont go up
Sounds like the switch has gone faulty, try swopping the switch with the other side window, if the problem goes with the switch, replace it. To test the window motor, remove door panel unplug motor, then with fly leads from a battery probe the socket, then reverse the probe wires, should get the motor to operate in both directions.
Feb 27, 2017 | Cars & Trucks
Drivers side power window will not roll up
Swop the switch with the passenger switch, to eliminate that, if that does not work then the door card will have to be removed to check the motor and wiring.
Jan 03, 2014 | 2004 Pontiac Vibe
Driver's side window power
Swop the switch with the one for the passenger side and see if that sends the window up, if yes replace the switch. If not the door card will need to be removed to check the motor and the power supply
Jan 03, 2014 | 2005 Pontiac Vibe
97 Lexus ES300 door indicator light stuck on
at this age there should be a switch on the door pillar which controls this ,,,, swop it to passenger side to see if problem follows ,,,, if so get a new switch,,,, some cars have it built into the door lock so it might be the lock in that case
Dec 06, 2013 | 1999 Lexus ES 300
Need part number for left and right hinge clip(s).
You just swop the bottom and top hinges,remove the top hinge and install on other side on bottom, do reverse with bottom hinge ,if there is provision for the hinges to be swoped by means of threaded holes on the refrigerator and holes on the otherside of the door (left or right). Before you start see if its possible. Good luck,
Peter (S.A)
Jan 17, 2013 | Refrigerators
How do you change the front speakers on a renault clio grande 1999 with electric windows. not sure on how the front grill for speaker is removed.
the grill is fixed to the door trim .take off door trim carefully.speaker/s are fixed to door frame simply take out/swop over speaker make sure they are fixed securely/dont vibrate....
Feb 11, 2010 | 2005 Renault 18I
The driver's side power window on my 2001 C 320 Mercedes fails to operate on occasion. Is a complete switch replacement necessary or is there a wire loose? Is it a DIY project?
the way to do it is take the switch out and swop it with passager side then if passager side stops working you no the switch has gone and you need to buy new switch. if not you would have to check window motor in door
Jan 26, 2010 | 2001 Mercedes-Benz C-Class
Acer 7630G laptop - keys are swopped ; @ and '' are the keys
Did you changed the Region to London or something? Check your Default Input Locale!
Apr 11, 2009 | Acer Computers & Internet
Install instructions for new window switch module
Drivers side. Pull back the trim inside the door handle pocket, uner the trim there is a philips screw, then the window switch with wood trim pops out, disconnect the connector, swop the sprung wood trim and your good to go.
Nov 18, 2008 | 1998 Jaguar XK8
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
May 02, 2008 | Refrigerators
Whirlpool EL7ATRR Refrigerator Logo
23 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
