Question about Kitchen Ranges
Frigidaire oven heating elements **** the bed
Frigidaire range model CPES389AC - top and bottom stove elements stopped working. With the back off I still cannot access electronics - is there a fuse I need to check? If so how do I access it?
  • icekings May 09, 2008
    TOP AND BOTTOM ELEMNETS STOPPED WORKING -- THEY ONLY GET WARM AND THE OVEN STAYS IN 'PRE' HEAT MODE ... can i fix this ? the service repair wants $100 just to diagnose .. anyone had the same problem - the over is only 5 years old.
  • robert samples May 11, 2010
    are you in the usa and is this a freestanding range or wall oven is the eoc or clock working
    President:
  • 1,314 Answers
Open the bottom drawer and get the model number off the serial plate on the left hand side i think its a slide in with the controls on front
Posted on Mar 31, 2008
Top and bottom heating element does not work on Frigidaire electric range ES300
Usually when both elements are not working and everything else is working fine, the problem is your OCU (oven control unit), commonly known to consumers as the clock.
The clock controls the oven and most times does not produce an error code when it fails.
You will need the actual model number from a sticker located on the oven frame when you open the bottom drawer, the sticker will have the model and serial number clearly listed.
Do a Google search for that model number and find the clock.
I've provided a link for what probably is the proper clock but without the full model number I can't say for sure:
http://www.appliancepartspros.com/frigidaire-clock-316207529-ap3764682.html
Apr 05, 2013 | Frigidaire PLEF398AC Electric Kitchen...
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire range model #FEFLFSA, is the top element
When you say Top Element, I assume you mean the TOP OVEN ELEMENT, correct? You have bake, and broil? Bake is usually on the bottom, and broil is the top. In order to have the oven operate correctly, the top and bottom elements may come on at start, in order to do as you just said, "Preheat the oven". This will insure an even distribution of the heat in the oven box and result in better cooking expierences. I would not be alarmed or concerned if the top element came on for a short period to pre-heat in preparation for cooking. This is normal. If the top element stayed on, and did not shut off on bake after the pre-heat period, then I would say you have a control board problem. However, if it comes on and then goes out, except when you are broiling, then I would say that this is normal for your stove, and the pre-heat mode of operations. Your owners manual should advise you of this very process in the guide section to how to use the oven. I hope this helps and that all your cakes, pies, souffle's and the like are......delicious. I'm sure they are. I hope this helps and eases your concerns. Kindest regards, Slats.
Sep 25, 2009 | Frigidaire Kitchen Ranges
I have kitchen aid in the counter range, the bottom heat element is bad. The element has burnt and has a 3" piece that has separated. At the same time the oven stopped working the burners stopped working...
The oven element will not affect the top burners, Unless it tripped the breaker at the panel when the element burned it two. Is there power to the stove? The top burners have their own power and control separate.
Aug 01, 2009 | Kitchen Ranges
Heating element does not work in oven
you can unplug the stove and unscrew the bottom heating element and go to a appliance store or home depo and purchase a new one and screw it but on that should solve the problem...
Jul 13, 2009 | Frigidaire GLGF386DC Stainless Steel Gas...
The bottom heating element in the oven has stopped working
It isvery easy to replace just unscrew the bottom heating element (unplug stove first ) take it to home depo or appliance store and get a replacement and screw it back on......then plug stove in ...
Jul 13, 2009 | GE Spectra JBP78 Electric Kitchen Range
Top element in oven not working
This "top element" is your broil element. It will only get red when broil is selected.
Nov 20, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Kitchen Ranges Logo
764 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
