Question about Canon Pixma MP480 All-In-One InkJet Printer
There is a line from the top to the bottom in a scan copy
    Scholar:
  • 111 Answers
R u scanning on flatbed?
Posted on May 16, 2010
When using my Samsung M2070F to scan, the scanned copy has a black line from the top to the bottom, just left of the centre of the page.
If you are using the feeder for scan, lift up the feeder and just clean the narrow surface on the left with plastic sheet. DO NOT REMOVE THE PLASTIC SHEET!
Jul 18, 2017 | Samsung Office Equipment & Supplies
I have an HP Officejet 6500 wireless printer. If I scan or copy a document through the feeder the scanned or copied document has vertical lines from top to bottom. If I lay the document on the glass and...
Lift the scanner top, then look at the narrow pane of glass. There probably is a spek of dust or ink on it. Clean it with alcohol. I've had to remove the glass, due to the speck being on the undersaide of the glass.
Also, lift the ADF cover and clan the rollers with a damp cloth.
Jul 17, 2011 | HP Officejet 6500 Wireless All-in-One...
I have the SCX-4521. When I feed paper into the top to make copies, the copies come out with a black line in the middle of the page from top to bottom. However, if I make copies by laying the page on the...
Have look where the paper feeds into the tray at the top.
Most likely there is a piece of rubbish stuck in there, another piece of paper or some fluff or something. Blow it out and give it another try.
If this doesnt work open the lid and have a look to the far left of the plate glass. you will notice a small plate glass seperate from the main plate running parallel with the main plate. Clean this with a damp cloth and some window cleaning detergent. Sometimes correction fluid gets wiped off onto this portion which acts as the Scanning Region for documents inserted on the top feeder. This causes a "permanent" black object being scanned for copying, hence the black stripe.
Regards,
BD
Sep 02, 2010 | Samsung Office Equipment & Supplies
HP Scanjet N6010 Once documents are scanned a line appears on the scanned copy
The lines on a scanned document are typicaly caused by dirt on the scanning glass. To clean it use the following steps.
1. Unplug unit.
2. Open the fron access door from the top.
3. Clean both top and bottom **** glass that run the width of the scanner.
The glass can be cleaned with a lint free cloth and a mild glass cleaner.
Jul 21, 2010 | HP Scanjet N6010 Photo Scanner
Copy or Scan problem
Open up the doc feeder and clean the scanner glass
Apr 19, 2010 | HP LaserJet 3050 All-In-One Printer
Auto Document Feeder copier problems
The scanning glass probably needs cleaning.
Jul 31, 2009 | Epson ACULASER CX11NF All-In-One Printer
Top to Bottom gray line on left side of Copied Page
hello
does the grey line appear if you scan true the "upper" scanner.(set paper on top of printer and sscan it that way)? you should also clean the smal slim glass that is at the side of the big scanner glass.
also try to remove all cartridges and tilt them side to side several times. then put them back and test your printer.
Jul 02, 2009 | HP LaserJet 2840 Printer
Lines on paper through the ADF when making copies
there is a dirt on the ADF (CIS contact image sensor) that reads your document, identify where the lines came from either from top or bottom then open your adf and clean the affected area. this will solve the problem.
Jul 24, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Lines on making copies
clean the glass of the scanning area, a small dot of debris on the glass produces a vertical line from top to bottom in the feeding direction of the laser printer.
May 07, 2008 | HP LaserJet 3055 All-In-One Printer
Black lines on scanned copies
Try this. Lift the lid to expose the top glass. To the left of the main glass panel, you will see a narrow glass strip. Clean this strip using a soft cloth or sponge moistened with a nonabrasive glass cleaner, then dry it off with a dry chaois cloth or cellulose sponge. A.
Apr 04, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Canon Pixma MP480 All-In-One InkJet Printer Logo
37 people viewed this question
old marine
old marine
