Question about Uniden Cordless Phone
Phone rings as soon as i attatch phone line? - Uniden Cordless Phone
    Scholar:
  • 47 Answers
Have you tried using other phones to test the phone line to ensure there isnt an issue with the phone line itself?
-Mike
Posted on May 16, 2010
How do I extend ring time on a Telstra fixed home phone line to stop it going to 101 too soon
Did you even look this up on Google? It took me 15 seconds. Hope this helps.
https://crowdsupport.telstra.com.au/t5/Home-Phones-Services/how-can-I-extend-a-ring-time-on-my-home-phone-before-calls/td-p/36451
Jun 12, 2016 | Lands Phones
Goes to answer machine to soon
The 6041 isn't an answering machine. To change the ring count, consult the documentation for whatever answering machine you have on your phone line.
If you require further assistance, please add a comment to this question and specify the make and model of your answering machine.
Feb 01, 2014 | Vtech Cordless 6041 Phone
I have a Uniden cordless unit hooked in 4 lines. Incoming calls ring briefly for about 1 second and go out! You can talk if you pick up but not sure why no normal rings. There is no problem calling out....
When someone calls you and your phone behaves this way, does the caller get disconnected? The phone may be causing this, but it may also be due to trouble in the telephone line itself. The trouble is caused by defective wiring, a partial short circuit. When you pick up your phone to call out, the voltage on the phone line is low and it works normally. When you get an incoming call, a high voltage is sent to ring the phone. Because of the partial short, the phone company's equipment thinks you've answered the call as soon as the ringing starts. But you haven't picked up the phone, so the phone company's equipment thinks you've hung up and disconnects the call. The result is that short burst of ringing.
Disconnect the cordless phone base unit from the line and try another phone. If you still have the trouble this confirms the line is at fault. You'll need to contact your phone service provider for service. If it's in the outside wiring, they're responsible for repair. If the problem is in your home wiring, you may need to pay them unless you have a wiring maintenance plan.
If the problem goes away when the cordless base is disconnected, then it's time for a new phone.
Jul 16, 2011 | Uniden Cordless Phone
I have the AT&T Model 854 4-line phone. When the phone is plugged in the phone starts toning and won't stop.
Thats because its looking for the intercom number to be assigned. as soon as you assign one in programming it will stop.
Apr 29, 2010 | AT&T ATT-974 Corded Phone
Fax rings but machine doesn't answer
First check the setup/configuration and make sure the Fax is set to answer on 1 or 5 rings. If the line is dedicated to fax then it can be set to answer after the first ring. Fax machine works off a modem that listens for the ring and handshake tones. If the machine has been hit with a lightening spike then the hearing portion may be dead.
Translation: Your fax machine is Deaf and can not hear the ring.
It will never answer and do the fax handshake required.
If it is a new machine and still under warranty. Take it back as soon as you can.
If this is a fax machine installed at work.
Be careful, some phone systems used in the corporate buildings have too high a voltage and will fry the modem/fax card.
If this is a home machine with DSL.
Make sure the DSL line filter is applied correctly.
It will be clearly marked Phone or DSL line. Do NOT connect the phone/fax line into the DSL line connection.
Hope this helps!
Nov 08, 2009 | Lexmark X6170 All-In-One InkJet Printer
My v-tech phone will not set to EST. It goes back to Pacific time as soon as the phone rings.
The key is "as soon as the phone rings". Who's ringing it? I had one of those on Packet8. I had to go to their website and get the instructions to change the time offset in the Packet8 ATA. Check with your dial tone provider for a solution. Carl
Jun 16, 2009 | Vtech DECT 6.0 Cordless Phone with Digital...
Caller ID
Since it appears by default, I'm guessing that the phone is not ringing. It has to ring to display CID. You need to make sure that it is part of an ICD group with Immediate ring.
Carl
Sep 03, 2008 | Panasonic KX-T7630 Corded Phone
Ringtone doesn't want to set
Dear friend
pls go to settings option and open 2nd step go to ring style open then open ring style menu choose line 1 and slect ring tone by you choose then slect by scorall middle button and reday for use if fill diffcult then you go to nearest service center
thanks and regards
alok
bihar sharif
Feb 10, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Fax ring tone or ring leader
im sorry to say the machine you have does not have DRD distinctive ring detect.
Jan 21, 2007 | Panasonic Workio DP-2330 Printer
Uniden Cordless Phone Logo
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
