Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Whats error code 136 - Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
  • 343 Answers
136 is 'motor stall' error and could be anything from a jammed inner bowl to a broken wire or a faulty motor controller board...Probably best to call a tech. because there are a number of components which need to be checked before board replacement....Good luck....Nomess
Posted on May 31, 2010
2004 mazda tribute error code p 0 136
Code 136 is for a problem with the O2 sensor bank one sensor two.
That is the sensor after the catalytic converter.
The sensor or the wiring would need to be checked.
Oct 16, 2014 | 2004 Mazda Tribute
Error code 136 showing
Just repaired code 136 on a 2013 chevy Orlando and it was a detached ground wire on one of the starter bolts causing the fusebox relays not to energise.
Mar 28, 2014 | 2013 Chevrolet Cruze
Error code 136 on aquasmart wl80t65cw1
If your bowl turns freely bearings are not seized,
Your rotor position sensor must be faulty & not outputting the right signal to the motor controller.
Feb 11, 2013 | Fisher and Paykel Washing Machines
Electrolux oven error code f 136...what to do?
Hello - Could it possibly be error code F13 or F36? According to my research this manufacturer does not have an error code F136. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and see if the error code clears. If it proves to be ineffective, contact a professional to move forward accurately to properly diagnose the unit.
Nov 25, 2012 | Ovens
Hi I have an approx 8 yr old F & P Intuitive Eco Washing Machine and I'm getting a 136 error message every few wash cycles. (well I've had it twice in about 8 washes) What does this...
Hi - check out this post - Code 130 - 136 all mean the same its a communication error between the sensors & the controller.
By mattnewmanha on Jun 16, 2011
I have a F&P MW512 top loader. It has developed a code 130. I have been told this is a faulty RPS. is this something I can fix at home? is there a bypass? how do I access and inspect the part?
Jun 19, 2011 | Fisher and Paykel (IWL12)
Error code 136 Fisher & Pykel washing macine
Hi just read your posting.Now Error code 136 means you have a motor stall fault.This means the motor controller cannot start the motor turning.Has your machine been noisy on spin?The things that cause this fault are,seized or faulty bearings, wiring to the motor faulty,faulty motor,faulty rotor position sensor, or faulty motor controller.Do you have or can borrow an electrical test meter ?If the answer is yes I can guide you throe the testing of the components to track this fault done.Please reply with additional information about the spin cycle and if you can get a meter and I will help you further.
Jun 19, 2010 | Fisher and Paykel (IWL12)
Calls error code at end of first rinse
Hi just read your posting.Error 136 means you have''Motor Stall " fault. Now just a couple of questions, has your machine been noisy on spin?does the machine leak water?Please reply with answers and I can help you rectify this fault.
Jun 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
What is error code 136 on a fisher & paykel IW709AU top load washer
136 fault is 'motor stall'...Quite often this is a broken wire to the motor. However it could also be a Motor fault, or Rotary Position Sensor problem. Water damage can cause this fault as well. After a visual check for broken wires or water damage, and if your machine is in good condition, you should consider a tech....Good luck...Nomess
May 20, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
May 18, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Washing Machine IWL12
130 rotary position switch fault 136 motor fault
Apr 29, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
488 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
