Question about D-Link DIR-615 Wireless Router
I have a D-link 615 router. My lap top see's the wireless network signal but I have no internet. And I do have an internet connection going to the router but still I get "Local only". What the hell is going on?!
    Genius:
  • 1,354 Answers
Configure the Router 1. Step 1
Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
Posted on May 16, 2010
My macbook pro laptop does not work with D-LINK DIR-615
go to wireles on lap top then restart serching for router signal.
Feb 22, 2011 | D-Link DIR-615 Wireless Router
How to secure the router
HI
please find the ans.
Features
  • Firewall protection for your network
  • Parental control to supervise Internet activity
  • Works with wireless 802.11b/g adapters
  • Backward compatible with 802.11g and 802.11b devices including game consoles and digital media player
  • Secure wireless network using advanced
  • WEP, WPA, or WPA2 encryption
  • Easy to get started with D-Link Quick Router Setup Utility
Description The D-Link DIR-615 Wireless N Router provides better wireless signals for your network than existing wireless 802.11g technology. Upgrading your home to Wireless N provides an excellent solution for sharing an Internet connection and files such as video, music, photos, and documents. D-Link Wireless N products use Intelligent Antenna technology to transmit multiple streams of data which enable you to receive wireless signals in the farthest corners of your home. Not only does D-Link's Wireless N technology extend your wireless range, it also works with your existing 802.11g and 802.11b wireless devices.
Easy To Set Up:
The D-Link Quick Router Setup utility quickly configures your new Wireless N Router to get you up and running in minutes. Our D-Link Quick Router Setup walks you step by step through the installation process to configure your Internet connection, wireless network settings and security, and everything else you need to get your network up and running so that you don't have to be a networking expert to get it set up.
Easy To Secure:
The DIR-615 supports the latest wireless security features to help prevent unauthorized access, be it from over a wireless network or from the Internet. Supportfor WEP, WPA and WPA2 standards ensure that you will be able to use the best possible encryption, regardless of your client devices. In addition, this Wireless N Router utilizes dual active firewalls (SPI and NAT) to prevent potential attacks fromacross the Internet. Delivering great wireless performance, network security and coverage, the D-Link DIR-615 Wireless N Router is ideal for upgrading your existing wireless home network.
Specifications Technical Specifications Standards: IEEE 802.11n (draft) IEEE 802.11g IEEE 802.11b IEEE 802.3 IEEE 802.3u Device Interfaces: 4 10/100 LAN Ports 1 10/100 WAN Port Antennas: Dual external 2dBi Gain reverse SMA antennas Security: 64/128-bit Wired Equivalent Privacy (WEP) data encryption Wi-Fi Protected Access (WPA, WPA2) Advanced Firewall Features: Network Address Translation (NAT) Stateful Packet Inspection (SPI) VPN Pass-through / Multi-sessions PPTP /L2TP / IPSec Device Management: Internet Explorer v6 or late Mozilla Firefox v1.5 or later Java enabled browsers Leds: Power Status WAN WLAN (Wireless Connection) LAN (10/100) Internet Status Power Input: DC 5V 2.5A, through external power adapter Dimensions: 193 x 116.8 x 30.5 mm Weight: 940 grams (0.7 lb) Operating Temperature: 0ºC to 40º C Storage Temperature: -20ºC to 65º C Operating Humidity: 10% to 90% Storage Humidity: 5% to 95% Certifications: FCC Class B IC CE
Dec 11, 2010 | D-Link DIR-615 Wireless Router
Lap top not connecting to internet
GO TO CONTROL PANEL,
CLICK ON NETWORK SHARING CENTRE(WIN 7)
click on,Connect to a Network.If this doesn't lead to an internet connection you may have cable faults or port configuration not set up correctly.You must have an internet service provider(ISP).
Aug 07, 2010 | D-Link DIR-615 Wireless Router
MY LAP TYOP WONT PICK UP THE DLINK SIGNAL
Please give the correct IP address to the wireless network adapter which you are configure in Dlink Router and try check available network and connect the correct SSID.
Aug 06, 2010 | D-Link DIR-615 Wireless Router
DR 615 router is not connecting to laptop from PC, can get on the internet from PC but not on lap top
If you connect the computer to the router , it
works.
That means the wired connection is OK.
Open the set up page of the router check the
wireless settings of the router.
I think your network is secured and you are not
typing the correct network key.
just open the router set up and check the wireless
settings .
Click Here for step by step solution
Jan 11, 2010 | D-Link Computers & Internet
New laptop won't connect to internet thru D-link 615 even tho main computer works thru D-link 615
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that you have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Dec 26, 2009 | D-Link DIR-615 Wireless Router
DIR 615 router. Host computer can not find network.
I dont know your router personally but what you need to do is setup a network bridgefull explanation is given here
http://www.microsoft.com/windowsxp/using/networking/expert/crawford_02april22.mspx
Oct 27, 2009 | Computers & Internet
We've had a laptop connected to our d-link wireless router for the last few weeks with no problem. Yesterday we lost the laptop internet connection. When we go to diagnose the problem, it shows that the...
Try resetting your wireless router first, then make sure that the network you are connecting to is yours and not another nearby wireless signal (I live in an area that's polluted with wireless signals and sometimes a neighbor's signal will be stronger than mine, so it will try to connect to theirs). If that doesn't work then go to your Network and Sharing Center and choose the setup a network connection option. You'll have to manually enter your info again but it should work fine.
Sep 15, 2009 | D-Link DIR-615 Wireless Router
Connected to wireless router, not connected to the internet
Try setting up a new network connection in the Network and Sharing Center. You'll need your info from your router like:
router username:
router password:
network name (ssid):
network security type:
network security key:
connection type:
Some will also ask for a serial id(I've only ever come across one)
I've never used your particular brand of router but it ought to work the same way as far as the setup.
Aug 25, 2009 | D-Link DIR-615 Wireless Router
Cant connect to the internet on my lap top
first thing is to identify the wireless settings of the router,you need to identify the wireless name (SSID), channel and the encryption you are getting from the airlink router. Next is to make sure that the wireless computer has enabled wireless signal/ or the wireless is on.
after that, you may connecting wirelessly to the computer, right click wireless connection and go to view available wireless networks, try to connect -input the encryption key from you wireless router or password and hit connect.
Jun 28, 2009 | Airlink AR430W Wireless Router
D-Link DIR-615 Wireless Router Logo
209 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
