Question about Microwave Ovens
Kitchenaid KBMC147HSS0 Bulb replacement
OK, the Top Venting Parts illustration should satisfy my needs.
Thanks!
    Genius:
  • 3,587 Answers
Good..just takes some time sometimes to run this obtuse information down.
Posted on Mar 30, 2008
SOURCE:
I need detailed instructions on how to change light bulb on Kitchenaid microwave KBMC147HSS0
Please check the details of how a microwave works which will help you identify before the panel is removed and the lamp replaced.
The top cover of the unit can be removed after the screws can be removed with the power cord removed. The lamp can be seen fitted on the front side with the light to shine into the chamber, you can remove the buld from holder and replace with the same type .
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
Oct 27, 2011 | KitchenAid KBMC140HSS Convection/Microwave...
hmmm..ok...let's try the service manual, first, shall we?
Mar 30, 2008 | Microwave Ovens
How do I change out a bad control panel on Kitchenaid microwave KBMC147HSS0 ???
Please check this link and you will get a good idea of how the components works. The front panel can be removed once it is confirmed .
Oct 27, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Replacing glass cooktop
The following link explains the steps required to replace a glass cook top:
http://www.fixya.com/support/r4249512-replacing_glass_cook_top
Replacement parts can be purchased from any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you need further guidance, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
Aug 25, 2010 | KitchenAid Microwave Ovens
I have a kitchenaid microwave model KBMC140HSS01 that has a burned out light bulb. I don't have any idea how to get to the bulb to replace it or even where the bulb really is. Can you please tell me what...
You would need to probably open the cover. Once all the screw is taken out the cover just slides back and it should be freed. You will then see where the light bulb is which is usually on top.
Jun 26, 2010 | Microwave Ovens
I need to rplace the bulb in the interior of the microwave. It's loose in the top housing.
some of the front(vent) covers have a sliding hook I think you need to push it to the left. You should be able to access the bulb when you get that off.
Jun 01, 2009 | KitchenAid Microwave Ovens
Kitchenaid microwave bulb
You can download the owner's manual and installation instructions here.
You can also download the parts manual here. It has handy exploded views. The bulb is shown on page 5 and is ref # 75.
You will need these instructions, because to replace the bulb, you will need to pull the microwave down from the wall mount and remove its cover.
Always unplug a microwave before removing or installing any bulbs.
And it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
If you don't find a replacement locally, check here.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Oct 05, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
the question was in two parts, service manual, and also how to open up to get at the bulb..check the links again on the solution
If it's the one that lights the cooktop, it's normally beneath the bottom cover.
In some cases, it's located in a compartment behind the grille that goes across the top of the unit.
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. It may help. It's at http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Please let me know if that helps or not.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 29, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
LIght bulb burned out
I a Kitchen Aid Buit-in microwave (KEMC308KSS01) with the same problem - light went out. Can you send me the instructions on how to replace the bulb? Thank you! [email protected]
Jan 23, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
