Question about Grundig Televison & Video
Grundig Cinemo TV will not start
We have Grundig Cinemo TV (3 years old) The procedure for turning on the TV is
1. Switch on the power
2. Push upstart button on the remote contol. Then it normally takes 5 seconds and the TV is starting.
The problem now is that when we push the upstart button, the TV seems like responding as usual, but in the end the red light is turned on (TV is off) instead of the green light.
Have anyone experience with this problem?
Thanks!
    Top Expert:
  • Grundig Master
  • 45,139 Answers
The power supply could be failing.
Posted on Jun 02, 2017
SOURCE: will not turn on?
I have had the same problem twice. The complete PC Board had to be changed on mine for it to start working again. The part usually runs around $150 not including labor.
Posted on Dec 16, 2006
  • 13 Answers
SOURCE: Help ,help.
It looks to me that your tv is starting up and then shutdown. I have suspect that your tv have a high voltage shutdown. Check your B+ voltage, if not correct rectify it. If it sound like gibridge to , then seek professional help. good luck
Posted on Dec 23, 2006
snakehead
  • 1074 Answers
SOURCE: TV does not turn on; red light blinking.
your problem is a more technical problem you will need a tech to look at your set if you are not a tech you wont be able to do it your self. contact a tech to repair your set the problem is in the power supply or related circuit.good luck.
Posted on May 02, 2007
IrishDruid
  • 2712 Answers
SOURCE: sony trinitron kv-36fs76u
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other).
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced,
Since the set is new, it may be worth getting fixed up. If you decide to do so, call around, as shops have different rates and different expertise. Many shops are hurting for work because so many of the smaller sets are never repaired anymore; they are just thrown out and replaced since the cost of a new set is sometimes as low as the repair expense.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers,
IrishDruid
Posted on Apr 26, 2008
  • 23 Answers
SOURCE: Power light flashes and computer turns off
This is a 1,2,3 item. If it is not the power supply, the cpu or motherboard are the next likely culprits. Generally, if the power supply is OK, the pc would have the fans running and you should be able to open the case and check the North Bridge, the large chip on the motherboard near the cpu and the cooler on the cpu itself. If they are both still cold, it is most likely the mother board.
It it were the cpu, it won't post, but you should still be able to feel the heat with the back of your fingers, just to be safe and touch it quickly so you don't get burned.
You can also try to remove the ram and try to reboot, if you get a steady series of beeps, you can add 1 stick at a time and reboot just to try to elimanate ram as a potential problem.
My next step would be to remove all of the other cards and add 1 at a time and reboot after each card, I probably removw the 4 pin connectord from the dvd/cd hard drives also ans add 1 at a time.
I know this sounds like a lot of work, but this is how I troubleshoot pc and telephone systems for the last 25 years.
Posted on Jan 25, 2009
Tip
How to reset ECU,Throttle and Accelerator Position Learning
Hi.
Below the procedure to reset ECU,Throttle and to perform Accelerator Position Learning on Nissan. It works on Titan, Altima, Infinity, pathfinder and other models.
ECU Resetting
While performing the procedures below, ensue that you are respecting the times stated. If the steps are not done within the specified times, the module will not reset. You will need to use a watch or a chronograph while performing the procedures.
Procedure:
1. Ensure that the accelerator pedal is fully released, set ignition switch to the “ON” position, then wait 3 seconds.
2. Follow the steps a and b below, repeat the two steps in sequence quickly for five times within 5 seconds.
a. Push hard the accelerator pedal untill fully depressed.
b. Release the accelerator pedal in full.
3. Wait 7 seconds, then depress the accelerator pedal completely, and hold it for about 10 seconds until the CEL (check engine light) starts blinking.
4. Release the accelerator pedal while the CEL is still blinking.
5. Wait 10 second.
6. Depressthe accelerator pedal in full and hold it for 10 seconds or more.
7. Fully release the accelerator pedal while the CEL light keeps flashing.
8. Turn the ignition switch to “OFF” position and start the vehicle. If procedure has been done correctly, then the light light will turn off.
If the light continues to stay on, repeat the procedure.
Accelerator Pedal Release Position Learning
Procedure
1. Ensure that the accelerator pedal is completely released before starting the procedure.
2. Turn the ignition switch “ON” and wait at least 2 seconds.
3. Turn the ignition switch “OFF”, and wait at least 10 seconds.
4. Turn the ignition switch “ON” and wait 2 seconds.
5. Turn the ignition switch “OFF” and wait 10 seconds.
Throttle Valve Closed Position Learning
Procedure
1. Ensure that accelerator pedal is completely released.
2. Turn ignition switch to the “ON” position.
3. Turn ignition switch to the “OFF” position and wait at least 10 seconds.
Ensure that the throttle valve moves after turning the switch off.
Idle Air Volume Learning (Throttle Position Learning)
Procedure
1. Follow the Accelerator Pedal Released Position Learning described above.
2. Do the Throttle Valve Closed Position Learning also described above.
3. Start the engine, and allow warming up.
4. Turn the ignition on “OFF” positionand wait 10 seconds.
5. Ensure that accelerator pedal is fully released, then turn the ignition switch to “ON” position, and wait 3 seconds.
6. Repeat the steps a and b below five times within 5 seconds in sequence.
b. Release the accelerator pedal until reaching full extension.
8. Wait 7 seconds or more, depress the accelerator pedal completely and hold the pedal down for about 20 seconds until you see that the Check Engine Light stops blinking and starts getting steady..
9. Rrelease completely the accelerator pedal within 3 seconds after the light coming ON.
10. Start engine and let it run at idle for about 20 seconds.
12. Test the engine to ensure the idle speed and ignition timing are set correctly.
Regards.
on Mar 25, 2010 | Nissan Titan Cars & Trucks
GRUNDIG TV
Could be an open internal fuse or power supply failure
Aug 03, 2017 | Televison & Video
Can't find sky remote code for grundig gu37fhd1080
Hello
Sky remote codes for Grundig are:
563 582 515 098 584 219 104 233 223 065 471
Sky+ Remote Control Unit Programming Procedure Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
Aug 20, 2011 | Televison & Video
Aquos model LC46D64U...approx 2 years old..Won't power up and get the power light flashing 3 times then the OPC light once..which is repeated...Any ideas...I believe this is quite common with Sharp TV's
I have a Sharp LCD 46 in.tv do this often.Yes,it is.This problems,the tv Tuner signal board have problem,but the tv is still useable.The POWER and OPC light indications flashes.Just push the power switch again,wait see tv turn,not POWER and OPC flashes again,push the power switch agian and wait.Have to do this like 3 or 4 times sometimes,than the tv backlight will come on,tv will work.Don't know but,if u require to pushing power button more 10 or 12 times,the tv Tuner signal board don't take an turn on the tv backlight get the tv to work.The Tuner signal board is dead,time to replaced the tv Tuner signal board.
Oct 18, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
F-26 flashing
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door
switch is open while the door is locked for more than
5 seconds.
Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Faulty door Switch or CCU board or door not closed during run cycle.
Starting Diagnostic Test and bypassing
the Service History Mode:
Execute this procedure with an empty drum. All
of the steps below must be done in sequence
in order to reach the Diagnostic Test. This
executes the automatic test but does not show
the error history.
Close the door.
Push POWER.
Select the CLEAN WASHER cycle.
Press EXTRA RINSE four times within
5 seconds.
Press EXTRA RINSE to advance to the
next step of the test procedure.
If the starting procedure fails, push
PAUSE/CANCEL, then repeat the starting
procedure.
Nov 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sony KDL40S2010 Bravia LCD TV... turns off / on on it's own
If TV does not remain in standby and turns on itself then power switch on top of it could be defective and power supply board is also suspected. Take off its back cover and unplug top switch connector just to confirm is that cause of On-Off its own. If problem still exist then power supply board has problem and will be replaced. Let me know the results to move forward.
Jun 13, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Safe mode on Grundig 200 car radio, do not know where to find serial number.
Grundig 200 car radio can decode in the next way:
First step: Switch off the radio and the ignition as well.
Second step: Push the AS button and keep it pushed, at the same time turn on the ignition.
After this you will hear a beep sound. Now you can release the AS button.
Now you can enter the code in the next way: The first number can be set with the button ''1'', the second number of your code can be set with button ''2'' and so on. By pushing the ''1'',''2'',3'',''4'' buttons the value indicated in the screen will be increased by one. So if the first number of your code is 5 then you have to push the button ''1'' 5 times.
if this doesnt work then it will be cheaper to buy a new car radio contact me and let me no how you get on :)
Oh and the serial number is either engraved on the side of the unit or an actual sticker which is in the format you describe. You'll need to remove the unit from the dashboard to be able to get access to this.
Apr 20, 2009 | Car Audio & Video
Tuning a Grundig Tele Pilot 750c Television
It might be an old hotel tv. Try this, it worked for me
http://www.tvtuning.co.uk/makes/grundig.htm
basically you hold the i button whilst turning on the tv.
ta
Jan 07, 2009 | Grundig GF70-600 TV
TV PROBLEM
No sir its not just an adjust ment or "twiddling" It sounds like its one of the same as your girlfriends set except a differant part such as a capacitor in the vertical curcuit, Output IC or even a defective resistor?? Good Luck
May 18, 2006 | Grundig GF70-600 TV
Televison & Video Logo
109 people viewed this question
Top Grundig Televison & Video Experts
Raj Patel
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
