Question about HP LaserJet 5550dtn Printer
Hi , i have 5550 jaserjet printer , error is coming 59.c0 which part is damage
  • 1,218 Answers
For those users who are having a problem with the printer motor, this C level problem is referred to as 'developing disengaging motor rotation error'. Most likely, this problem points to an issue with the function of the DC controller: either it has failed or it has affected the developing disengaging assembly. The solution is quite simple and the user may fix the error in a matter of few steps. The first step is to reconnect the J16 connectors that are used for the developing disengaging motor to the J1100 connectors that are used for the DC controller PCB (that is the printer circuit board of the DC controller). After connecting these two connectors to each other, the user must replace the developing disengaging drive assembly directly. The final step is to replace the DC controller PCB, after which the printer is to be recalibrated. for more help
http://www.fixya.com/support/t1517115-error_code_59_c0_in_hplaserjet
Posted on Sep 17, 2010
How do I go about it
Posted on Jul 08, 2010
Printer 5550 laser color cood 59.c0
I am assuming you meant HP Color LaserJet 5550 Error Code 59.c0
Description
A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly.
Action
  1. Press the green (Select) button to continue.
  2. Turn the printer off, and then turn the printer on.
  3. If the error message returns, turn the printer off.
  4. Perform a cold reset.
    1. Turn the printer on.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the green (Select) button.
    4. Continue holding the green (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
    6. Press (Down Arrow) button once. The control panel will display COLD RESET.
    7. Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
  5. If this message persists, contact an HP-authorized service or support provider.
Sep 06, 2016 | Laser Office Equipment & Supplies
Hi, i have problem with my hp color laserjet 5550 printer.it saiys printer error 59.c0
59.XY A printer motor error has occurred.
(X=C=developing disengaging motor rotation error)
(Y=0=no color/black)
Developing disengaging motor error
1. Reconnect the connectors J16 for the developing disengaging motor and J1100 for the DC controller PCB.
2. Replace the developing disengaging drive assembly.
3. Replace the DC controller PCB. Calibrate the printer after replacing the DC controller.
Jul 29, 2011 | Office Equipment & Supplies
Hp color laserjet code 59.fo error
All the book says is that one of the motors had a problem.
Power it off for at least 30 seconds. Power back on.
Make sure you are not using a surge protector.
Put the power cord directly into the wall outlet.
I just checked the manual for another printer and the 59.f0
could be the ITB. Make sure that it is seated correctly. If you have
a spare install it and see if problem goes away.
Apr 04, 2011 | HP Laserjet Cp2025n Printer
How to reseting hp laserjet printer ETB
59.XY
PRINTER ERROR
For help press
alternates with
59.XY
PRINTER ERROR
To continue
turn off then on
None A printer motor error has occurred.
X Description
0 motor error
1 motor startup error
2 motor rotation error
3 fuser motor startup error
4 fuser motor rotation error
5 print cartridge motor startup error
6 print cartridge motor rotation error
9 ETB motor startup error
A ETB motor rotation error
B developing disengaging motor
startup error
C developing disengaging motor
rotation error
Y Description
0 no color/black
1 cyan
2 magenta
3 yellow
1. Turn the printer off and then
back on.
2. This message might also
appear if the transfer unit is
transfer unit is correctly
installed.
ETB motor error
1. Clean the ETB unit
intermediate connector, J36.
If the connector is damaged,
replace it.
2. Reconnect the connetors J38
for the ETB motor and J1111
on the DC controller PCB.
3. Replace the ETB motor.
4. Replace the DC controller
controller.
Jun 25, 2010 | HP LaserJet 5550 Printer
59 C0 error on hp color laserjet 5550
the printer is sensing that one of the motors are not turning.remove the cover from the left side .you will find the main drive motor,next to the motor you will find a sensor clean this sensor with some electronic board cleaner .be sure that the sensor it dry before turning the printer on.
Dec 17, 2009 | HP LaserJet 5550 Printer
Error co 59
i have printer 5550 error code 59.0 coming so i need hp sevice help
Apr 18, 2009 | HP LaserJet 5550 Printer
59.C0error on hp color laserjet 5550 dtn
can you please suggest a solution for the above error on my printer urgenty
Apr 10, 2008 | Office Equipment & Supplies
HP LaserJet 5550dtn Printer Logo
108 people viewed this question
Seeker5211
Seeker5211
