Question about IOGear GCS632U 2-port KVM Switch
Keyboard not working on one side of switch
Installed the KVM MiniView USB Plus (GCS632U) switch using a Dell Dimension 2400 desktop and a Dell Latitude D630 attached to a docking station. The desktop works fine for mouse, keyboard, monitor and audio, but the D630 laptop only works for the mouse, video and audio, but the keyboard does not work. I noticed that the KVM switch only has one USB output that handles both the mouse and keyboard. Could be a problem with the docking station? Perhaps I should split the USB with a pigtail into separate connections. Not sure what I can do. Intersting this is the keyboard works to log into the laptop but does not work with any of the applications. Can you suggest a solution as I really like this set up.
  • 30 Answers
The GCS632U has keyboard and mouse emulation that may not function correctly with docking stations. To ensure the KVM it self is working correctly I would suggest plugging the single USB from the KVM directly into the laptop and see if you have the same keyboard problem. This will at least tell you if the KVM is working properly or not.
Posted on Jul 26, 2010
USB Mouse works, keyboard does not
You will need to update the drivers on the computer for the docking station. It will be the windows seven drivers or lack of them that is causing a failure to remap the usb ports that the wireless dongle is plugged into.
May 25, 2017 | IOGear GCS632U 2-port KVM Switch
Hi . .. I want to use this KVM switch to connect
The GCS632U has keyboard and mouse emulation that may not work with all wireless combos. If your wireless combo is going to work the single USB connection would need to go into the keyboard port as that is the only port that will recognize the hot key switching commands. If the wireless combo still has problems then try using a USB wired keyboard to ensure the GCS632U is working correctly.
Mar 18, 2010 | IOGear GCS632U 2-port KVM Switch
I have iogear miniview kvm (gcs62) keyboard works but mouse conn does not. Mluse is usb mouse with ps/2 adapter. Direct connection via usb works. used to also work with adapter but having tried it with kvm...
USB mouse with PS/2 adapter is not guaranteed to wok with GCS62. This KVM switch is designed to work with PS/2 keyboards and mice only.
When the USB mouse with PS/2 adapter is used in a computer directly, it will surely work, because the USB port can give enough power for the mouse to work. And it can easily convert the signal.
Unlike in KVM switch, the switch serves as a bridge between the mouse and the computer. And the computer does not easily recognize the mouse.
I would suggest to use a regular PS/2 mouse. Or if you want to use USB keyboard and mouse, you need to have a USB KVM switch. Model GCS632U.
Thank you and good luck!
Jan 21, 2010 | IOGear MiniView GCS62 2-port KVM Switch
Iogear MiniView Micro USB Plus KVM Switch (GCS632U) Problem
The GCS632U does not have any form of display emulation which may cause video problems if the boot up is not done right. What IOGear recommends is when booting up a computer the KVM should stay on that computer until it comes to a desktop. What this does is it allow the KVM to pass the EDID information from the monitor to computer and that should help.
Jul 03, 2009 | IOGear Computers & Internet
I have an iogear usb kva switch connected to two PCs (one desktop; one laptop). It used to work fine with a wireless keyboard (HP), but after I replaced it, it stopped allowing me to switch between PCs...
Hi ther. make sure that you connect them to the correct port. If using a wireless keyboard, connect the receiver to the keyboard port. check underneath for the keyboard icon. Make sure that the receiver is connected to that port.
May 09, 2009 | IOGear GCS632U 2-port KVM Switch
All Keys do not work on keyboard with KVM switch
GCS632U is designed to work with standard USB keyboard an mouse only. You have to make sure that you are not using any type of adapter such as PS/2 to USB adapter. To further isolate the problem, please follow the steps below:
1. Connect the USB keybord directly to th computer to make sure that the keyboard is working properly.
2. Make sure that the keyboard is connected to the keyboard port on your KVM switch. You may take a look under neath this GCS632U (near the USB ports) and you will see an icon where to connect the keyboar and mouse.
3. If you're still gettings the same problem, Try power cycling this kvm switch by disconnecting if from the computers and disconnect also the keyboard and mouse from the KVM switch and leave them disconnected for a minute or two.
4. Reconnect everything after two minutes and then reboot the two computers.
5. If same problem exist, try using different USB keyboard.
NOTE: This KVM swith does not work correctly with wireless, gaming and smart keyboards because it's designed to work with standrd USB keyboard only.
Mar 23, 2009 | IOGear GCS632U 2-port KVM Switch
Wobbly screen on mac laptop
are you using a Mac Mini-DVI to DVI adapter or any adapters? This is a VGA video output type of KVM switch so probably the problem is with the adapters involved to it.
Nov 19, 2008 | IOGear MiniView GCS62 2-port KVM Switch
Problem with KVM switch and Vista
Your problem has nothing to do with the Operating System (Vista), it has something to do with the brand of your computer. I have similar problem before, I have Vista (Dell), but the time I connected another Vista (Sony Vaio), everything worked correctly.
This is what you need to do:
1. You have to make sure that you are using a standard USB keyboard and mouse.
2. Connect first the keyboard and mouse directly to the Vista computer to see if the USB ports of your computer are working properly.
3. You may power cycle the KVM switch by disconnecting it from the computers (including the keyboard and mouse) and leave it disconnected for 2 minutes.
4. Reconnect everything after two minutes and then reboot the computers.
5. Try using different USB keyboard if problem exist after power cycling the KVM switch.
Sep 16, 2008 | IOGear GCS632U 2-port KVM Switch
Hotkey mode
This just worked for me. Using your PC keyboard, boot up to the PC first and then power up your mac. Hit the scroll lock twice and IMMEDIATELY hit enter. You have to go fast- click-click-click with no hesitation and it works great. I still can't toggle the hot keys to set up my mac keyboard, which I prefer using, but I'm assuming it takes the "right" timing on the keys. I'll keep trying.
Oct 23, 2007 | IOGear GCS632U 2-port KVM Switch
Mac and Vista
Operating System doesn't deal anything on your problem. The problem depends on the brand of you computers or the type of keyboard you are using.
The GCS632U is designed to work with standard USB keyboard and mouse only. And wireless and gaming keyboards and mice are not guaranteed to work correctly with this KVM switch. If any one of you is using the new Mac Aluminum keyboard, this keyboard will not work with the older version of the GCS632U. But IOGEAR releases a new batch of GCS632U that would work with the Apple Aluminum keyboard.
If you have an Apple Aluminum keyboard that does not work with the GCS632U, you may contact the IOGEAR Tech support and they will process a Return Merchandize Authorization (RMA) if your device is still under the warranty period.
To resolve your keyboard issue, try to power cycle the KVM switch by disconnecting it from the computers, disconnect also the keyboard and mouse from the KVM switch. Leave it disconnected for two minutes. After two minutes, reconnect everything and reboot the computers.
Oct 20, 2007 | IOGear GCS632U 2-port KVM Switch
Open Questions:
See all IOGear GCS632U 2-port KVM Switch Questions
IOGear GCS632U 2-port KVM Switch Logo
870 people viewed this question
Top IOGear Computers & Internet Experts
Greg Cann
Greg Cann
John Anderson
John Anderson
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
