Question about Canon Pixma MP500 All-In-One InkJet Printer
Won't take paper
My printer says it as enough ink and everything is fine, but whenever I try to actually print something, it takes the paper halfway and says it's jammed. If I "un-jam" the paper, it continues to print regularly. My main point being, the printer just won't take the paper all the way. I believe it is something wrong with the loading of the paper, and not the printer itself. I thought I might have jammed something inside by accident, but the paper path is clear. Anyone have this problem or can help me?
  • sues_shaw Jan 17, 2009
    I have the same problem, been trying for hours to sort it, it will not take any papert at all... i tied doing a maintence check, cleaning rollers and print check, i can here it doing somethng but wont take paper... it keeps saying paper jammed!! help!! before i throw the thing out the window...
  • cschapman10
    cschapman10 Nov 22, 2012
    Help me too
    Scholar:
  • 85 Answers
Clean The Paper Feed Rollers Using The Unit's Operation Panel If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit. Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary and no more than three (3) times.
  1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
  2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for additional information.
  3. Press the <Menu> button.
  4. Use the right / left cursor button to select [Maintenance/settings] press the <OK> button.
    Note: This procedure is skipped if your machine is in Scan mode. Proceed to step 5.
  5. Use the right / left cursor button to select [Maintenance] and the press the <OK> button.
  6. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
  7. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
  8. To check if the rollers are clean, load a sheet of Letter-sized plain paper in the same paper source you selected in step 2, and press the <Open> button.
  9. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
  10. Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
    Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
Paper Source
Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source.
ASF
Cassette
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Source setting in the printer driver. If the option is not set to 'Paper Feed Switch', paper will feed from the source selected in the driver.
Click to return to step 2 above.
Posted on Apr 03, 2008
I cant print any paper out. it dosent work. something wrong with the paperhead. ive tried to clean up all printer but it dosentwork anyway. to print out pics on a cd works triffic. bt i want to print out...
If it prints photos but not regular (black) text. This means the black ink is not flowing at the nuzzle. This usually may not be resolved by just running printer ink head clean up.
What you should do is take out the black ink cartridge, press a folded tissue paper to the nuzzle (where the flows from); if it comes out blotted with ink, it is OK. if not, that's the cause of the problem. So place it in a plate/saucer/bowl with a bit of water so that the nuzzle part is all touching water. Leave it for about 10 minutes. take it out and press a folded tissue paper to it. The tissue should be blotted with black ink. You may need to repeat procedure till the blot is good enough/the flow is good enough. Then return it to the printer and print again.
Dec 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Paper in correct turned printer on red light flashing and will not print paper is blank when it comes out.
Red light flashing, do printing, paper blank out : ink low message. Ink level low, near to ink out level. But it just program, may be ink tank is out actually (no ink at ink tank). Refiil ink tank or replace w new one. Check Nozzle.
Jun 11, 2009 | Epson Stylus C46 InkJet Printer
MP 780 DOESN'T PRINT
Try printing something in a colored font, like red or green and see what happens. This printer uses two black ink cartridges. It uses the larger one for black text printing. If it is dry, blocked, or damaged, your text (usually black) will not print. Changing to a color font will rule that out.
Good luck.
Feb 23, 2009 | Canon PIXMA MP780 All-In-One InkJet...
CX6600 prints black lines through out documents
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Now try to Print it should work fine.......... Still same Problem Catridges Defective......... Good Luck...........
Jan 19, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Paper feeding halfway through then stops
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Samsung CLP 300 Laser Printer
Brother 1440 Printer Black streak - is it Drum or Toner?
perform a halfway test by printing something with a full page of letters or graphics and try and stop the printer before the print actually gets to the fuser but has the toner on it from the toner cartridge, remove carefully as the toner won't be melted into the paper and see if the defect is showing up on there. If it is then its your toner and if not then it's your fuser...hope this helps please leave feedback...
May 27, 2008 | Brother Office Equipment & Supplies
Printer paper feed error #3
Dear EATRUNNER,
This Error is related to PaperJAM now you can find the complete solution to related this Error ,on this URL:
http://support-au.canon.com.au/contents/AU/EN/8000647001.html
i'm 100% sure ,your problem is solved ,whenever you read this page properly.
Cheerup and Be Happy Always
Mar 14, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam, when there's not a paper jam?
there is a small micro switch , when paper is loaded that switch
is activated, bent switch, paper shreds jamed in switch, will cause paper feed problem.
Jan 13, 2008 | Lexmark P4350 All-In-One InkJet Printer
Black Ink Skipping
After entering my posting earlier today, I did some more internet searching on this problem. I found a helpful British website that listed a trick for cleaning the printer carriage area. It's a little more than halfway down the page, if you click on this link, http://www.valueshop.co.uk/printing.asp
Here is what they suggested:
"1. OPEN printer so the cartridges move to center of the carriage.
2. REMOVE all cartridges.
3. FOLD a letter size piece of paper in half, and then in half again the other way so it is quartered.
4. START with the long, folded edge and insert into front of printer where paper normally feeds out. (it will slip in a little over halfway)
5. MOVE the paper left and right to remove any excess ink under the carriage. When the excess ink is removed the printer should print streak-free. "
I tried this (actually used 3 or 4 pieces of paper because it was pretty grungy), and I can print without bands of gray now. Although, the colors are not as vibrant as they used to be, neither is the black. (My holiday newsletter looks good enough to send out, at least.)
After cleaning the printer carriage area, I ran the nozzle check pattern test again and it still looks bad. I then cleaned and realigned the print head, and again the nozzle check pattern continues to look bad. The user manual for the F60 (page 10-5)said that if the nozzle check pattern does not improve after a deep cleaning then the printhead may be damaged. I called Canon tech support and they think that the printhead is probably damaged, but they suggested that I take it to an authorized Canon repair shop, which is too far away, and probably too much trouble. My other option is to order a new printhead directly from Canon for $45 plus $6 shipping and install it myself (or make hardware engineer hubby do it ;-) ).
Hopefully this trick for cleaning the printer carriage area will help others at least for the short term, like it helped me. Good luck!
Oct 15, 2007 | Canon MultiPASS F60 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
2,273 people viewed this question
old marine
old marine
