Question about Whirlpool GR460 Electric Kitchen Range
Changing oven light bulb
We have a whirlpool kitchen range (oven) and we are wondering how
to change the interior light bulb (trying to undo from the interior)
or should access it from the external cover and how to undo please...
thanks
  • 1 more comment
  • ovenproblems Aug 23, 2008
    did you ever figure out how to get the cover off of the interior light bulb in the oven
  • dwriver Oct 04, 2008
    I can't find the product number, buts its a whirlpool gold convection stove. How do you change the interior oven bulb.
  • Anonymous Mar 17, 2014
    Need to replace light bulb and cannot remove cover?
The manual states to turn the cover counter clockwise. I was able to turn it about an inch and then it stopped turning. You really have to apply pressure, but it will turn more. It is similar to a tight light fixture. I was worried about breaking it, but it did finally loosen. I believe the replacement bulb is a 40 watt mini oven bulb also...
Hope this helps!
Posted on Nov 29, 2008
  • 185 Answers
Model number please
Posted on Mar 30, 2008
How do I change the light bulb in my Whirlpool range oven - model RF262LXSQ 2 - I've tried unsuccessfully to turn the lense in either direction, I'm afraid if I try harder I'll break it.
Re: Difficult to get protective cover off of oven light.
I had the same problem until I out on a rubber kitchen glove.
The adhesive properties of the glove allowed me to turn it off with no problems, but only after I messed with it for 15 minutes prior to noticeing a pair of kitchen gloves under our sink.
I hope this helps someone else. Kevin Gildart
Apr 18, 2010 | Whirlpool GR563LXS Kitchen Range
Oven light burned out and the cover won't come off
i had a look at the model it looks bult in from inside the oven has to have a special tool to undo it he has to take of a few covers also but he should do it cheaper then 99 he is ripping u off call around more people first see what they say
Sep 10, 2008 | Thermador PRG304US Gas Kitchen Range
Whirlpool GR450LXLQO range while changing oven
You will have to replace the light socket. Part number is 3150505 at approx. 30.00. Hope this helps
Feb 03, 2010 | Whirlpool Kitchen Ranges
How do I change the oven light bulb on my Whirlpool Super Capacity 465 Gas Stove. There is a cover over the bulb that won't budge what do I do?
ok its been a long time since ive seen this model
but if i remember correctly, that cover pulls out, it does not screw out, sometimes it can be loosened a bit by warming the oven to about 100 degrees, this will swell the metal ring that is the clip for the bulb cover
Oct 17, 2009 | Whirlpool GR460 Electric Kitchen Range
OVEN LIGHT ONLY WORKS PART TIME
Poor connection in lamp holder, change bulb and make sure connections are ok
(Make sure you turn off the cooker at the fuse box.)
Sep 22, 2009 | Whirlpool GR465LXLS Electric Kitchen Range
Ge oven model xl44. my oven will not lite, the broiler works fine.
Hi..
You need to do this
  • Replace the bulb
  • Test the switch
The interior oven light in most ovens is a standard 40 watt appliance bulb. Often, to change the bulb, you first need to remove a shield or glass dome. If the bulb isn't burned out, the problem may be with the switch on the oven door frame. If the switch works poorly, intermittently, or not at all, you need to replace it.
When an indicator light has stopped working, you may be able to replace just the bulb--but you usually have to replace the entire light assembly. Alternatively, there could be a problem with your burner sensor (stuck open or closed) or your indicator light circuit.
Good luck !!
Regards
PCmania
Jul 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven light exploded and seems fused in socket
I was able to remove the base from the socket by inserting pliers and opening them so that they pressed against the inner sides of the base and then turning while exerting pressure.
Nov 12, 2008 | Whirlpool RF369LXPQ Electric Kitchen Range
LG LRE30451SW range
Jul 19, 2008 | LG LRE30451ST Electric Kitchen Range
Oven light problem
sure you can use with out back cover, sounds as if connection inside socket is loose( not making contact with bottom of light bulb securely
Feb 10, 2008 | Whirlpool RF368 Electric Kitchen Range
Whirlpool GR460 Electric Kitchen Range Logo
2,484 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
