Question about Refrigerators
Fridge Door seems to have dropped
Westinghouse fridge, may have had too much weight in the door??
Appears to have dropped and is catching on the bottom of the cabinet and therefore not sealing unless really pushed shut.
Can't see any way of adjusting the hinge
  • 619 Answers
The cam risers at the bottom hinge have gone bad. Get the model number form the fresh food section and you will be able to order new ones. Not expensive to repair.
Posted on May 16, 2010
Have purchased a westinghouse aurora double door fridge frezzer second hand in the middle off doors its very warm and the fridge side doesnt seem to be as cold as it should be. Frezzer side fine any...
There is a heating coil in those for defrosting purposes. You need to check and see if there is a defrost timer and see if it is stuck. Since you did not post the make and model number, that is as far as I can advise
Oct 27, 2017 | Westinghouse Refrigerators
Hoover HFOE54B fridge ice box door catch does not close properly.
The door needs adjusting as the seal is usually magnetic.
Jul 16, 2017 | Hoover Refrigerators
How do a fix a Westinghouse fridge door that has dropped slightly
Hinge screws probably loose. Refrigerator doors have hinges screwed on the outside. The hinges allow for you to move door to be level, loosen screws, move door level and hold it there till you tighten screws. Sometimes the hinges are covered with a plastic piece that you pry gently up on to remove.
Jul 03, 2016 | Westinghouse Refrigerators
New Westinghouse fridge cannot seem to adjust freezer lower than 0' except if power freeze on getting colder ?
read the user manual or get a technician out under warranty
from 10 down to 0 on a fridge is getting colder with the smaller numbers
with a freezer 0 to 10 gets colder as the numbers get bigger
Jun 05, 2016 | Westinghouse Refrigerators
I have a westinghouse frdge freezer bj 385 motor constantly running with the door close motor stops intermidently open door motor stops recently moved fridge
Hi Peter, It it's not freezing the fridge up then it needs regassing but it it's freezing the fridge up then could be the thermostat, Good luck mate..... CHEERS..
Apr 04, 2016 | Westinghouse Refrigerators
The door on my Neff fridge seems to have dropped although it's true to the fridge body so it looks as though the fridge body has dropped at the right hand side.
try adjusting the feet at the bottom of the fridge.Doors overtime will drop,because of the weight we put in them.
Jan 14, 2016 | True Refrigerators
Our Westinghouse RS662V fridge is tripping the power. Has done it twice in the past 2 months. Any suggestions?
This solution is one possible answer if it applies to you. My fridge did the same and i thought the fridge was dead. The fridges freezer compartment's door was being left open and the freezer would thaw out and produce lots of water which would accumulate in the rear in a container which overflowed causing the fridge to trip the power. Closing the door and drying the rear container solved the problem. There are other causes too but if this applies to you it is worth giving it a try. Good Luck!
Jul 20, 2014 | Westinghouse WHITE Fridge Freezer Bottom...
I have a westinghouse 2 door fridge that is not getting cold enough, 7 degrees in the fridge, freezer seems ok. not sure where to set the controls as i have no manual. its a 2 door,freeze at the top and...
i think your ref working normal try to adjust thermostat setting on the fridge if you want to cool lower than 7 degrees but this temp. allready can chill the food. then you said that freezer ok.
Feb 12, 2011 | Westinghouse Refrigerators
Fitting an integrated fridge freezer!
Hi Gareth. I fitted a door to my Hotpoint hsz2321L today. I used self tapping screws through the brackets into the fridge door sides. Looking at the old fridge that came out showed that this was the method used previously. No seal is broken and so the fridge is working perfectly. I do have an issue re-fitting the door onto the new fridge though. The pivot hinge on my fridge doesnt give enough clearance and so it catches on the unit at the side of it. The old fridge (a Bosch) cad cabinet hinges that would sort of concertina out to give clearence. Anyway, good luck.
Nov 23, 2008 | GE Profile GCG1700LII 15" Built-In Trash...
Dodgy fridge light
Generally, these doors drop from excessive weight, a warn part or loose fittings. Unload the door and investigate. You may also want to check that the unit is levelled...the box may be warping/sagging...although this is unlikely.
Dec 24, 2007 | Bosch Exxcel KGV35421 Bottom Freezer...
Refrigerators Logo
221 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
