Question about Compaq Armada 1700 Notebook
Booted when cold (very cold)off for at least 2yrs. took it out to play with it and 5 mts later nothing
Try adding a monitor and see if anything happens.
never boot a device unless its room temp.
you probably have condensation on the inside which by now is not visible peobably burned something.
try to oprn it and with a toothbrush spill alcohol and rub it gently except for the cpu. though you may take it out and look for moisture hope it helps bro. goog luck f.j.
Posted on Mar 31, 2008
I have a gateway model #q5wtc, its only 2yrs old. Ive had no problems until today i turned it off only to return later to it not starting windows. It powers up says gareway, the red and blue lights in...
Could be as easy as starting in safe mode and then rebooting. Reason is that what you describe sounds like a hung driver. Booting in safe allows the system to relocate the driver. If that does not fix this you will likely need to reload the OS.
Feb 05, 2015 | Gateway Computers & Internet
Tip
Watch/Enjoy Joined Panasonic HS900 MTS Video on Asus O!Play in Full HD 1080p...
Enjoy Full HD Video on O!Play-Combine HS900 MTS into one file without conversion for playing on Asus O!Play
These days many of us have a constantly growing media library, with our favorite music, movies, and photos in a variety of formats and locations. The ASUS O!Play is designed to easily bring your media into your living room, without sacrificing quality. Enjoy video in full HD 1080p resolution,full-fidelity audio, and photo slideshows on your HDTV or home theater setup. With impressively wide format support, a wealth of connection options, and playback over a network or directly from USB and eSATA drives, the O!Play is an elegant and modern media solution. Such a cool HD media player supports formats include full hd 1080p mts.
If you are interested in recording with HD camcorder, like Panasonic HDC-HS900 which give MTS extension, you can directly Transfer and Enjoy Panasonic MTS files to Asus O!Play via HDMI. However, before enjoy them with O!Play, you may want to do simply editing like cutting off unwanted or unimportant parts and then merge or join the trimmed MTS files into 1 file while keeping the same format, without losing any quality. Sometimes you can also put them in a format for devices to watch anywhere in the house or on the go.
Now I will show you a fast way to Cut off Panasonic HS900 MTS clips, and then Combine HS900 MTS into one file without conversion for playing on Asus O!Play with Full HD 1080p resolution.
Step 1. Capture MTS from Panasonic HDC-HS900 AVCHD camcorder to Aunsoft Final Mate for Mac.
Free Download and Run Aunsoft Final Mate for Mac as the fast MTS Cutter/Joiner without Conversion, and use USB cable to connect your Camcorder to PC. Then follow the camcorder wizard to import videos. After selecting the Import option, you will face the window like below to choose the video clips for importing to Aunsoft Final Mate for Mac. The videos would be listed on the "Camcorder" tab.
Step 2: Create a Movie for Cutting and Joining Panasonic HDC-HS900 MTS clips.
Click the Add movie button, and choose the" For Lossless Output", a movie about cut mts for lossless output will be created by default. Then select one or multiple mts video files you would like to split/join from the Camcorder tab and then drag and drop them to Movie tab. In this way, a Movie for no re-encoding will be created.
Step 3. Split or cut off unwanted parts from HS900 MTS movie for Asus O!Play.
From the timeline, you may notice the vernier, which is used as time pointer. Click on the Vernier, and move to the timeline you want to cut, and click the Split button to cut the video. Then select the unwanted or unimportant parts and click Delete.
To change video sequences, just click on the video clip on timeline, drag and drop to the left or right for the position as you like. One movie will be exported as one file with Aunsoft Final Mate for Mac.
Step 4. Merge/Join/Combine HS900 MTS without Conversion for Asus O!Play.
Click the Export button and choose lossless output, the HS900 MTS cutter/merger for Asus O!Play will start joining large .mts files into one mts file without conversion at the fast speed. The non-conversion process will prevent loss of quality when joining MTS files for Asus O!Play with 1080p.
After a few seconds, then connect the lossless output mts format with Asus O!Play via USB. By Connecting the O!Play HD Media Player via HDMI with HDTV , you can Enjoy full 1080p high-definition video and digital audio output for lossless audio transfer to your receiver or TV.
Tips:
If you think that MTS file is so large that can't play smoothly on O!Play, you can also use this program to convert MTS file to MP4, AVI, MOV, WMV, etc with smaller size for Asus O!Play.
on Jun 23, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
Best Mac Manage MTS Converter-Watch Merged Canon HF M300 AVCHD MTS Files on...
Split and Join Canon HF M300 Full HD MTS to Panasonic HDTV with no loss of quality <br /> I am using Canon HF M300 to record videos and the camcorder saves AVCHD files in .mts format. The Canon VIXIA HF M300 captured 1920 x 1080 24Mbps Full HD Recording. I connect the Canon Camcorder to my Panasonic HDTV via direct USB. However, I found my shooting video of the HF M300 have some pause and interlace in the process of recording. So I need to delete much unwanted mts clips and join into one big files. So I asked for some help on some forums and was recommended to try freeware TSmuxer, TSsniper which can help me to split and merge mts files. But it is frustrated for Mac users because most of them can only work on Windows platform. Then one of my friend recommended to a new <b>MPEG-4 AVC/H.264 cutter/joiner software</b> for Final Mate for Mac exactly what I want - delete the unwant .mts clips and merge HF M300 1080/60p meaningful MTS files to one single MTS files without re-encoding. And I had succeed play those merged .mts files on my Panasonic TV. <br /><br />Here is the detailed guide introduces how to <b><a href="http://canon-videoconverter.com/2011/06/split-and-join-canon-hf-m300-full-hd-mts-to-panasonic-hdtv-with-no-loss-of-quality/">Split and Join HF M300 record AVCHD .mts clips for Watching/Playing on Panasonic HDTV</a></b> with Mac OS X Snow Leopard on iMac, MacBook, Mac Pro. <br /><br />Step 1: Import/Capture Canon HF M300 Camcorder AVCHD files to Aunsoft Final Mate for Mac. <br />Free Download Final Mate for Mac as a <b><a href="http://www.aunsoft.com/final-mate-mac/">Best Mac Manage MTS Converter</a></b>. When Aunsoft <b>Final Mate for Mac</b> is run, it can automatically detect and pop up a wizard for you to capture video from camcorder. The videos would be listed on the "Camcorder" tab. <br /><br />Step 2: Create a Movie for <b>cutting and joining HF M300 1080/24Mbps MTS clips</b>. <br />Click the Add movie button, and choose the" For Lossless Output", a movie about cut mts for lossless output will be created by default. Then select one or multiple mts video files you would like to split, join from the Camcorder tab and then drag and drop them to Movie tab. In this way, a Movie for no re-encoding will be created. <br /> <br />Step 3. <b>Cut off unwanted parts from raw MTS movie for store</b>. <br />From the timeline, to cut/trim the video, just play it and click the Split button when it plays to the frame you want, and then click the "Delete" button next to the <b>Split</b> button to remove the unwanted. And the Previous Frame and Next Frame buttons can help you locate each frame of the videos and cut with frame accuracy. <br /> <br />Step 4. <b>Join/combine HF M300 AVCHD MTS raw footage</b>. <br />To <b>join</b> another clip to the end of the movie, just select the file, drag and drop to the movie ID. The files will be joined into one file as output. <br /><br />Step 5. <b>Export One Big raw HF M300 MTS with no loss of quality</b>. <br />Click the Export button and you click the OK button, the Mac MTS/M2TS cutter/joiner will start merging large .mts files into one mts without conversion at the fast speed. The non-conversion process will prevent loss of quality when <b><a href="http://www.aunsoft.com/final-mate-mac/">Mac joining HF M300 avchd camcorder files for storing</a></b>. <br /> <br />After a few seconds, I <b><a href="http://www.aunsoft.com/final-mate-mac/">Connect Canon Camcorder Movies to my Panasonic HDTV</a></b> via direct USB. Then <b>Stream Canon HF M300 MTS to TV for watching</b> with family. The output mts also can store the video on your home server, NAS or external hard drive.
on Jun 22, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
Join/Combine Canon HF M300 AVCHD MTS raw footage-Stream Canon MTS to Panasonic...
Best Mac Manage MTS Converter-Cut and Join Canon HF M300 AVCHD MTS clips to Panasonic HDTV with Highest Qulity <br /> I am using Canon HF M300 to record videos and the camcorder saves AVCHD files in .mts format. The Canon VIXIA HF M300 captured 1920 x 1080 24Mbps Full HD Recording. I connect the Canon Camcorder to my Panasonic HDTV via direct USB. However, I found my shooting video of the HF M300 have some pause and interlace in the process of recording. So I need to delete much unwanted mts clips and join into one big files. So I asked for some help on some forums and was recommended to try freeware TSmuxer, TSsniper which can help me to <b>Split and Merge AVCHD MTS files</b>. But it is frustrated for Mac users because most of them can only work on Windows platform. Then one of my friend recommended to a new <b>MPEG-4 AVC/H.264 cutter/joiner software</b> for Final Mate for Mac exactly what I want - delete the unwant .mts clips and merge HF M300 1080/60p meaningful MTS files to one single MTS files without re-encoding. And I had succeed play those merged .mts files on my Panasonic TV. <br /><br />Here is the detailed guide introduces <b>how to split unwanted HF M300 record AVCHD .mts clips and join meaningful mts clips without conversion for playing on Panasonic HDTV</b> with Mac OS X Snow Leopard on iMac, MacBook, Mac Pro. <br /><br />Step 1: <b>Import/Capture Canon HF M300 Camcorder AVCHD files to Aunsoft Final Mate for Mac.</b> <br />Free Download Final Mate for Mac as a <b><a href="http://www.aunsoft.com/final-mate-mac/">Best Mac Manage MTS Converter</a></b>. When Aunsoft <b>Final Mate for Mac</b> is run, it can automatically detect and pop up a wizard for you to capture video from camcorder. The videos would be listed on the "Camcorder" tab. <br /><br />Step 2: Create a Movie for <b>cutting and joining HF M300 1080/24Mbps MTS clips</b>. <br />Click the Add movie button, and choose the" For Lossless Output", a movie about cut mts for lossless output will be created by default. Then select one or multiple mts video files you would like to split, join from the Camcorder tab and then drag and drop them to Movie tab. In this way, a Movie for no re-encoding will be created. <br /> <br />Step 3. <b>Cut off unwanted parts from raw MTS movie for store</b>. <br />From the timeline, to cut/trim the video, just play it and click the Split button when it plays to the frame you want, and then click the "Delete" button next to the <b>Split</b> button to remove the unwanted. And the Previous Frame and Next Frame buttons can help you locate each frame of the videos and cut with frame accuracy. <br /> <br />Step 4. <b>Join/combine HF M300 AVCHD MTS raw footage</b>. <br />To <b>join</b> another clip to the end of the movie, just select the file, drag and drop to the movie ID. The files will be joined into one file as output. <br /><br />Step 5. <b>Export One Big raw HF M300 MTS with no loss of quality</b>. <br />Click the Export button and you click the OK button, the Mac MTS/M2TS cutter/joiner will start merging large .mts files into one mts without conversion at the fast speed. The non-conversion process will prevent loss of quality when <b><a href="http://www.aunsoft.com/final-mate-mac/">Mac joining HF M300 avchd camcorder files for storing</a></b>. <br /> <br />After a few seconds, I <b>Connect Canon Camcorder Movies to my Panasonic HDTV</b> via direct USB. Then <b><a href="http://sony-mts-converter.com/2011/06/joincombine-canon-hf-m300-avchd-mts-raw-footage-stream-canon-mts-to-panasonic-tv-for-watching/">Stream Canon HF M300 MTS to TV for watching</a></b> with family. The output mts also can store the video on your home server, NAS or external hard drive.
Tip
Convert and Play MTS Files to Droid X with 854 x 480 Pixels Resolution How to...
How to Play MTS files on Motorola Droid X? Droid X offers a 4.3-inch screen, a dual-flash eight-megapixel camera, an HD camcorder for 720p capture. And this great MOTOROLA Droid X can only play videos in MP4 with 854 x 480 pixels resolution, and music in MP3, AAC, WMA, WAV, etc format. So is there any way to put MTS files on Droid X for playing? Yes. Aunsoft MTS to Droid X Converter is the recommended tool for you to convert and play MTS files on Motorola Droid X with 854 x 480 Pixels Resolution. Follow the steps below to convert MTS to Droid X for watching AVCHD MTS videos.
Step 1. Load MTS to Aunsoft MTS/M2TS to Droid X Converter.
Download MTS to Droid X Converter and click the Add button to load the .mts files on hard drive.
Step 2. Choose Motorola Droid X MP4 output.
Click the Format option and choose Android > Motorola Droid X H.264 Video (*.mp4) (recommended) for output.
Tip: The default resolution of output format H.264 MP4 is 480*320, if you don't like it, please click "Settings" to set the size (pixel) to 800*480 or 854*480, or you can custom the resolution if you wish to.
Step 3. Join MTS videos for Droid X. (optional)
Tick the checkbox for Merge into one file next to the Settings button, and the MTS joiner will merge the video clips according to the ranking order on the file list.
Step 4. Convert MTS to Motorola Droid X MP4.
Click the convert button under the preview window and the conversion from .mts to mp4 for Motorola Droid X starts right away.
After the conversion is finished, connect Droid X to computer and transfer the video to Droid X. Hope you enjoy the steps above for converting MTS to Droid X.
Tips:
1. If you are using Mac computer, you can use the Mac version of Mac MTS to Droid X converter.
2. If you want to know the way to transfer files to Droid X. Please read: Transfer or Copy Movies and Musics to Motorola Droid X.
on Aug 04, 2010 | Cell Phones
Some channels have no sound some are in spanish
With your remote, go into the menu, find the audio setup and click off the SAP. Thats the Second Audio Program. Some Broadcasters send a second lanquage along with the regular audio. Someone must have been looking around or playing with the remote and turned on the SAP.. Good Luck PS please do not forget to rate this thread
Oct 18, 2006 | Orion STV2763 27" TV
Tip
Upload Sony NEX-5 MTS to QuickTime H.264 MOV for YouTube Sony Alpha NEX-5 is one...
Sony Alpha NEX-5 is one of the interchangeable lens digital cameras, with all the components, bodies and lenses support the feature to tackle continuous autofocus and exposure adjustment while recording video. The Sony NEX-5 supports recoding 1920x1080 AVCHD video.
With the HD videos filmed by Sony NEX-5, you may want to upload them to your YouTube account for sharing with friends and families. However, YouTube does no support .mts files yet. One of the fast solutions is to convert .mts videos to QuickTime H.264 MOV with Mac Sony NEX-5 MTS to MOV converter. Aunsoft MTS/M2TS Converter for Mac is the recommended tool for you to share Sony NEX-5 videos.
Have a look at the steps below to upload MTS HD videos to YouTube on Mac OS X like Snow Leopard.
Step 1. Load Sony NEX-5 videos to Aunsoft MTS/M2TS Converter for Mac.
Run Aunsoft MTS/M2TS Converter for Mac as the Mac Sony NEX-5 MTS to MOV converter, and click the "Add" button to load .mts videos for conversion.
Step 2. Choose QuickTime H.264 MOV format.
Click the "Format" option, and choose HD Video > H.264 HD MOV(*.mov), and the Mac Sony MTS to MOV converter will transcode the HD MTS files to MOV for YouTube. As YouTube supports HD video in 1920x1080 and 1280x720, the default settings in the profile are OK for uploading.
Step 3. Convert Sony NEX-5 MTS to H.264 MOV for YouTube.
Click the convert button under the preview window, and the Mac Sony MTS to MOV converter starts converting 1080i MTS to HD MOV for uploading to YouTube.
After the conversion is finished, log in your YouTube account and browse the output QuickTime H.246 MOV for uploading to YouTube. The Mac Sony NEX-5 MTS to MOV converter also deinterlaces AVCHD videos. It is easy to share camera video on YouTube without interlacing problem for watching on computer. The converter also works with Sony HDR-XR500, HDR-CX110, Cyber-shot DSC-TX7 and other AVCHD cameras.
The NEX-5A with the 16mm lens sells for US$650, while the NEX-5K with the 18-55mm lens will sell for US$700.
on Jul 28, 2010 | Cell Phones
Tip
How to Play AVCHD with Sony DSC-HX5V on VLC Media Player? After recording some...
After recording some HD videos with the new Sony Cyber-shot DSC-HX5V, do you want to play the videos on computer? You may face the problem that the full HD videos at 60 fps in .mts file format do not play properly, and the playback on VLC is choppy.
If the VLC media play shows the HX5V .mts video, but with pixelation or interlaces, you can adjust VLC to see if the video playback on VLC is perfect without interlacing artifacts. Just play the video as normal videos on Mac, and right click on the player to choose Video > Deinterlace and choose the options like Discard, Blen, Mean, Bob, Linear, X, Yadif, Yadif (2x).
If the above solution does not work for you, you may try Mac Sony DSC-HX5V MTS converter to deinterlace AVCHD, convert HD .mts to HD .mov, HD .mpg for VLC media player. The output HD MOV is compatible to QuickTime too. Here are the simple steps to convert Sony Cybershot DSC-HX5 .mts to HD .mov with Aunsoft MTS/M2TS Converter for Mac.
Step 1. Load Sony DSC-HX5V videos to Aunsoft MTS/M2TS Converter for Mac.
Run Aunsoft MTS/M2TS Converter for Mac as the Mac Sony DSC-HX5V MTS converter, and click the Add button to load .mts videos.
Step 2. Choose HD .mov output.
Click the Format option and choose HD Video > H.264 AC3 HD Video(*.mov) for converting .mts to .mov.
Tips: The Mac Sony DSC-HX5V MTS converter will convert 1080i AVCHD to 1920x1080 by default. If you records videos at 1440x1080, you can click the Settings button and change video resolution by choosing 1440x1080 from the drop down menu.
Step 3. Convert Sony DSC-HX5V .mts to HD .mov.
Click the convert button under the preview window, and the conversion from Sony DSC-HX5V .mts to QuickTime HD .mov starts immediately.
When the conversion is finished, you can play 1080p videos on VLC without interlaces or choppy problem on Mac. Your QuickTime will play the HD .mov videos seamlessly too. The Mac Sony DSC-HX5V MTS converter would work perfectly on Mac Leopard, Snow Leopard for your iMac, MacBook Pro.
on Jul 15, 2010 | Computers & Internet
Compaq Armada 1700 Notebook Logo
46 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
