Question about RaidMax 350W Power Supply (NEWITEM36787964) Power Supply
Model# RX-380K power supply does not pwr up no fan or pwr out
I found the Power input lead to circuit board off of the 110/220 switch shorted at a componet labeled thr1 the lead on one side of the device(thr1) is loose looked like a solder connection popped. What is THR1 and would replacing this component possibly fix the pwr supply problem.
3 Suggested Answers
siawolf
  • 749 Answers
SOURCE: Not sure if Pwr Supply failed
unplug the power supply from the wall, hold the power button down for about 10 seconds to discharge the powersupply and motherboard. plug the power supply back into the wall and try to start the computer again..
Post here again if that doesn't help..Regards..
Posted on Jun 29, 2010
cheifhoho
  • 217 Answers
SOURCE: Replaced smoked RaidmaxKY-520ATX power supply.
You can actually test the power supply before connecting it to the motherboard. Take a look at the power supply pinout by CLICKING HERE. Jump pin 14 with 13, 15, 16, or 17 to turn it on. You will have to get a manual for your motherboard to see how the front panel connector is configured with your case power switch. If you have that manual you can jump the 2 connector pins for the power switch to test the p/s from the motherboard.
Posted on Jun 03, 2011
Yamaha RX-663 Powers down
It sounds like it's going into safe mode try testing the resistors just after the power supply you will probably find one or two at fault
Feb 15, 2014 | Yamaha RX-V363 Receiver
Check engine light came on
What do you mean "can't find code"? If the check engine light is on, there is a fault code stored in your onboard computer - that's the way it works. If you are using a generic OBD code reader, that is most likely the reason you cannot find any codes. You need to use a scanner that has the correct software to access your ENTIRE computer network, not just the "continuous memory" or "generic" side of your computer system.
The window problem is a seperate problem and must be diagnosed accordingly.
Apr 23, 2012 | Daewoo Matiz Cars & Trucks
Faulty Power Circuit board Short Circuit on Motherboard Malfunctioned circuit on mother board Faulty Motherboard, Power supply not working Power does not flow through the circuit board Faulty Circuit...
Test your power supply unit if the PSU units fans not working its faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error computer error a computer needs its connections continue its cycle and have an end to function
hope this helps
May 12, 2011 | IBM 41D2469 Motherboard
Jun 29, 2010 | RaidMax RX-530 Volcano (RAIDMAXRX530VOL)...
Tv turns off a second after I turn it on
Just repaired this actual model.
remove the back of the tv. Loof at the circuit board on the left as you face the back of the tv. In the middle there is a diode that burns out. Remove all ov the screws holding this circuit board to the tv. Carefully unplug all of the connections and flip the board over. See that the number on the back side of the board by the burnt diode is d1940. Have the diode replaced by a competent repairman and oberve polarity. put everthing back as you found it and try the tv. You may want to have a fire extiguisher nearby.
Sep 28, 2009 | Emerson LC320EM9 32 in. LCD HDTV
No power to E-Machine T1860
hi,
Issue seems with the power IC of the motherboard need to repair.
May 29, 2009 | E-Machines T1860 PC Desktop
Power supply/ no output voltage
Actually i haven't fixed the problem as yet but i did find some info that would help me to fix problem.
I went to google and entered keyword,,, Electronic parts,,there came up a page,,and i went to several manuf sites till i found a replacement transformer,,then i disassembled the power supply and am now waiting for a replacement transformer.
Sep 21, 2008 | Boston Acoustics MicroMedia Computer...
Power problem
Please do NOT TRY TO SWITCH ON your comp in same condition again as you would be damaging it further. Its not your power supply alone there EXISTS A SHORT CIRCUIT IN OTHER COMPONENTS as well . The SHORT CIRCUIT Protection circuit of your Power Supply senses this and switches off preventing further damage . Well you could try this - Disconnect power to all the componenets like HDD , CD/DVD , MOTHERBOARD and FDD etc.,. Plug in the AC input power to your Power supply and on the 20 pin connector look for green colored wire and black wire on the same connector and short these 2 wires ONLY with a metal paper clip or a piece of wire , if the fan in the PS works and spins at full speed till you disconnect or remove the short between the two wires (Green and Black) then your PS is Working FINE . Now connect each of the component's power connector only and repeat the same exercise you will be able to identify which component is shorted.
May 01, 2008 | EliteGroup P4VMM2 Motherboard
Need schematic diagram, some advice and ultimately replacement parts
You have something in short circuit in power supply pattern, so filter coils are burnt. It may be voltage regulator, or regulating transistor, electrolytic capacitor or even shorted diode at pwr. input serving to protect in case of inverse polarity applied. Check all for short. Was it reverse polarity or overvoltage occured?
Mladen,
mladen@propilots.net
Mar 18, 2008 | Lowrance GPS
Audiovox FPE3000 turned off sponataneously and will not turn back on
I would suggest getting a schematic of the set and using a multimeter looking at the power supply test points to determine what is happening exactly with the power supply.
Sep 08, 2007 | Audiovox FPE3000 30 in. HD-Ready LCD...
RaidMax 350W Power Supply (NEWITEM36787964) Power Supply Logo
146 people viewed this question
Top RaidMax Computers & Internet Experts
David Payne
David Payne
Are you a RaidMax Computer and Internet Expert? Answer questions, earn points and help others
