Question about Friedrich CP12C10 Wall/Window Air Conditioner
Ac works but not cooling. The thermostat dosen't work properly.
When you turn the thermostat knob nothing happens. Do you think the condenser needs to be replaced or needs some freeon. I had this unit about 7 years and never had any put in. I replaced and cleen the filter.
  • 53 Answers
Open unit an check the thermoprotector on the compressor thats the problem
Posted on May 17, 2010
Why 2004 Buick lesable running hot when ac on
Excess heat not being properly disposed of. Check the AC condenser fan for operation, clean condenser and radiator, proper cooling system levels and thermostat operation.
Sep 18, 2015 | Buick Cars & Trucks
Dometic rm7732 not cooling
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Jun 17, 2008 | Dometic RM2652 Refrigerator
GE Side-By-Side Refrigerator Stops Cooling
HI,
  • The compressor
  • The Thermostat
  • The defrost timer
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Goodluck..
May 27, 2008 | Refrigerators
Why would my goodman gas furnace leak water from the panel that the blower motor is attached to?
the only reason water would come out of your furnace is if you also have your AC in the same system, and the condensation line is not allowing the water to drain properly.
If the water only happens during cooling, clear the condensation line. If it is happening during a heating cycle you may have an improperly connected thermostat, a bad control board, etc...
Nov 16, 2014 | Goodman Heating & Cooling
While running the air conditioning, the air cools and then warms and eventually cools for a little bit again. I think the water pump is what's needed here? what is the big bolt behind the fan?
It is unlikely that the water pump is causing the trouble you describe. The large hex behind the fan is what you would turn to remove the fan clutch from the water pump shaft. This fan clutch is supposed to detect heated air coming through the AC condenser and radiator and engage the fan more positively with the water pump shaft when more air needs to me moved to cool the radiator and AC condenser. The fan clutch could be bad or the AC system may not be properly charged--either of these conditions could cause the problem you describe.
Feb 25, 2010 | 2005 Dodge Ram 1500
AC stops working when cabin temp reaches 109-110
indicates gas pressure and condenser cooling problems
check the condenser fan is working properly and have the gas pressures checked by gauges
check that the evaporator fins are clean and not blocked as ice build up will cause the same indications
Apr 07, 2017 | 1997 Audi A6
The ac in my 95 Jetta just works while the car is cool, then it stop
In addition to what emission wiz says, observe the speed of the fan when you turn on the a/c. some fans, when the are cold they run faster, then they get hot and slow down a lot. Also check that the small belt that drives the second propeller is ok. And for last, check that the front of the radiator is clear of any garbage, like a plastic bag that might have been cought in front of the condenser with the wind. If all this is working properly, there is nothing else that could be happening machanically to this a/c to stop it from cooling. look at the center of the pully of the compresor, make sure the entire thig is spining when clutch engages.
Aug 18, 2008 | 1995 Volkswagen Jetta
Fan Seems To Be the Only Thing Working
no you problably have a bad thermostat on the unit
May 27, 2008 | GE AJCQ08ACB Air Conditioner
Amana Refer. runs all the time.
Have you ever cleaned the condenser coil in the back or under the bottom of the refrigerator. Dirty coil will cause this problem, also make sure the little fan motor in the back is working if it stops you can get the same condition. If not these two conditions you may be starting to have a refrigerant problem.
The unit gets low on refrigerant and just dosen't cool properly.
May 17, 2008 | Amana Refrigerators
Friedrich CP12C10 Wall/Window Air Conditioner Logo
335 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
