Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Won't start, keeps beeping when i push start.
The red light also blinks. The lights inside of the dryer use to be on when you have the door open. it now is not on. Beeps everytime i try to start the dryer
  • 619 Answers
The door switch has gone bad. Replace door switch and you should be good to go.
Posted on May 16, 2010
Testimonial: "Thank you. I will try that"
I opened the dryer door to put in a load of clothes and the light inside flashed and went off. power comes on, i can set to the drying time, but when i press start i get 3 short quick beeps...no error
It sounds like maybe the switch that recognizes your door is closed my be bad or out of adjustment. Look for a 3/8" to 1/2" opening on the face of the surface that the dryer door meets. There may be a small plate that acts as the actuator. It may also be a small rod sticking out that gets pushed in by the door. Either way, try to actuate it with your hand or screwdriver with the door open and press the start button and see if that works. If not you'll possibly have to take the dryer apart to get at the switch. If you're comfortable with using basic tools this can be done and you just need to be patient while doing it. Test the switch if you have an ohmeter to see if it works. An ohm reading is fairly simple to do and meters cost less than $30 at a Home Depot. Don't get intimidated by their dials and number readouts. (O.L. = Open, 0 ohms = closed) If the switch doesnt change states it's bad and you'll need to search the p/n on the switch in Google. Someone on Ebay or other sites will likely sell these switches for $5 or less. Hope this helps.
Dec 02, 2014 | Dryers
The light on my whirlpool duet dryer keeps blinking on all settings, won't start
push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Mar 18, 2013 | Dryers
GEW92509W0 will not start. When you hold start button, it beeps like door is open. Tried many settings. It will only blink "sensing light" . No error code is blinking in the display. Plugged...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 19, 2010 | Whirlpool GEW9250P Electric Dryer
How to reset change oil light after service
turn your key on without starting it then in the fuse panel inside the driver door jam there is a red reset but push it till the oil cange light blinks then push and hold it till the car beeps at you or the light shuts off this also the same way you reset the tire pressure light
Oct 10, 2010 | 1999 Pontiac Grand Am GT
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
My Kenmore Elite Smartheat Quietpak 4 will not start. F70 code
leave door open and press the rubber botton inside, \ I just hooked up mine and it did same thing, i pushed botton light went out, so this told me the door wasnt closing correctly, you have to push hard on door first couple times. hope this helps you.
dave
Feb 09, 2010 | Kenmore Elite HE4 Electric Dryer
My fisher and paykel dryer ( mod# ED56 ) wont start, power is on
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem.
After i did this, i closed the door and my dryer started as normal.
Aug 11, 2009 | Fisher and Paykel DEGX1 Electric Dryer
When I press start, it beeps, but will not start -- Kenmore HE-3
I pressed the reset button inside the dryer with my finger and then turned the dryer on with the door opened. After I closed it, it worked again.
Jun 16, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Malber Dryer won't start (sine-wave light flashing)
The dryer is easy: turn it on and turn the control to 0. It will beep. Then turn it to the desired program (20, 40, 60 minutes or a pre-programmed cycle), it will beep again and start. If there's a red light you have to empty the water tank at the front on the left. The washer is a normal washer. Just pick your program and press start (be patient as it takes a while to get cranking). Sometimes you have to really push the door closed very hard. Try and turn the control to 12 o'clock before setting it again.
May 30, 2009 | Malber TD800 Electric Dryer
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
447 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
