Question about Krell Showcase 5 5-Channel Amplifier
Will the amp play 2 ohm speakers - Krell Showcase 5 5-Channel Amplifier
    Sergeant:
    Champion:
  • 246 Answers
If your amp has ability to play 2ohms, then it will play. It will play even it dosn't have the provision. It might cause damage to the audio output at certain level if volume level is increased. My advice is to check your amp. or read the user mannual for perfact usage. Thanks
Posted on May 16, 2010
What is the impedance of the midrange speaker and the tweeter speaker in the Pioneer cs r5100 ? I have the crossovers and the woofers I use for my front channels (L&R)
If you are running three 8 ohm speakers in parallel then the total impedance would be 2.667. If running two 8 ohm and one 6 ohm speaker in parallel you would have 2.4 ohms. This will burn out your amp pretty quick. And very possible won't play at all. Though I have never attempted to play a home amp down that low in ohms. Guessing you may have an older model Denon type amp.
Aug 01, 2014 | Pioneer Audio Players & Recorders
Put new pa speakers in church 2 1000 watt tied 2gether and 2 300 watt. tied 2gether. the pa amp only has 250 watts with 6 mics connected and a cd player which plays fine. every time the mics are used if...
hi,
You have to check the ohms of the speakers all spekers should be 8 Ohms or above. if not it will overload the amplifier at high level. The minium ohms impedence of the amplifier is 4 ohms. If you connect two 8 ohms speakers together then the effective ohms will be 4 OHMS then the amp will handle the speakers. If you connect two 4 ohms spekers together then the effective ohms will be 2 Ohms, this will overload the amplifier. You will be able to connect two 8 ohms speaker to left channel or right channel of the amplifier. Check the speaker spesifiction to know its ohms. Make sure all the speakers have an impedence of 8 OHMS or above
OK
Aug 19, 2011 | Radio Shack 250 Watt PA Amplifier...
I have the Alpine MRP-M1000 amp. I want to use 2 subs with this amp. Which Alpine subs would work best with this amp?
this amp is rated at 600w at 4 ohms and 1000w at 2 ohm so as long as you calculate your speakers to match the ohm specs of the amp you can hook up
parallel = pos to pos and neg to neg of the 2 speakres
2 - 8 ohm speakers in parallel = 4 omhs
2 - 4 ohm speakers in parallel = 2 ohms
series = pos to neg of the 2 speakers
2 - 1 ohm speakers in series = 2 ohms
2 - 2 ohm speakers in series = 4 ohms
Feb 22, 2011 | Alpine MRP-M1000 Car Audio Amplifier
Need help wiring 2 ohm L7's optimally please!
It depends on how long you plan on running your amp when you listen to your music. If you like it loud for a long time, I would kep our speaker load at 2 ohms to keep your amp cooler. If its for car audio competitions where it wont play for so long, ! ohm would give you higher output but heat up your amp faster. Are the subs 2 ohms at each voice coil or 4 ohms? Bridge your voice coils together in parallel then bridge the 2 speakers together in series. That should work fine for you.
Feb 24, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
IF THE WOOFERS HAVE 2 VOC.COIL EACH HOW DO YOU CONNECT WITH THE AMP THAT HAS ONE CHANNEL WITH TWO + AND TWO -.
it depends on the load you want to present to the amp. un 12, 2009 - If woofers are 2 coil, then you definately need to know the impedance of the coils (are they dual 2 ohm, or dual 4 ohm?). For dual 4 ohm speakers you will only be able to acheive a summed load of 1 or 4 ohms. If your amp can handle 1 ohm, then connect this way: 1 ohm: Connect both the positives and the negatives together on each speaker. This puts them in paralell which will result in a 2 ohm load per speaker. After you connect the two 2 ohm loads to the amp, it will see 1 ohm as it's load. If your amp can handle this, this is usually the lowest configuration capable by consumer stuff, (if you are not doing competition or some crazy thing), and few amps are rated for 1 ohm so it's not really recommended and may heat up or blow your amp. 4 ohm: Connect one negative to one positive terminal on one speaker. Drive the other open terminals with the amp. This places coils in series and results in an 8 ohm load per speaker. After connecting both speakers to the amp, the amp will see a 4 ohm load. In both cases, the rates power of the amp (at that load) will be divided equally between the speakers. Jun 12, 2009 - For dual 2 ohm speakers, the only loads you can achieve are .5 ohm (1/2 ohm), and 2 ohm. The connections are the same as above, and this results in: ...If coils for each speaker are wired in paralell, the results are 1 ohm per speaker, and after connection, the amp sees 1/2 an ohm. (.5 ohm) ...If coils are wired in series, the result is 4 ohms per speaker, and the amp will see 2 ohms after both are connected.
Jun 12, 2009 | Volfenhag ZX-4712 Car Subwoofer
Amp Turns off after 30 seconds of song play
Since the unit recovers once it has powered down. I suspect that the internal protection circuit is kicking in. Check the wiring and be sure that there are no crossed wires anywhere. These amps are designed to work with 2 ohm loads and can take a direct short for a short period of time. If the wires appear ok, measure the speakers with an ohm meter. If the speakers are 4 ohm rated, they should measure just under 3 ohms with the meter, If they measure less than 2 ohms, there is a problem with the speakers.
Also, does the amp shutdown regardless of the volume level or just when played loud?
Thanks,
Dan
Apr 15, 2009 | Kenwood 1000W Class D Bridgeable Mono...
Sony xplod xm-1652z amp
You probably have the output bridged at 2 ohms. This amp is not a 2 ohm bridged stable amp. It is 2 ohm stable only in stereo. That means each channel can be 2 ohms, buts not bridged at 2 ohms.
If you have two 4 ohm speakers that are wired in parallel and then you bridge them, you have a 2 ohm load.
They only safe way to use two 4 ohm speakers is to run one speaker to each channel and then you have a stereo 4 ohm load.
When you use a 2 ohm load you get twice the current draw thru the amplifier as you would with a 4 ohm load. That means that the fuse you are using, the rating the amplifier is designed for, will blow any time you have a big bass hit.
If you are not using a 2 ohm bridged load, and you are using a 4 ohm bridged or something the amplifier is rated for, and you still have this problem, you may have a bad speaker. Even a speaker that will play can sometimes be on the brink of shorting out and causing the amplifier to draw lots more current than it is rated for.
If this is the case, you should go and get your speakers checked and see if they are still measuring at 4 ohms or at least close to it. Most speakers will measure a little lower than what the are rated. It is not unusual for a 4 ohm speaker to measure at 3.5 ohms, but if it is less than that, you problem is the speaker. Even if the speaker still plays.
I hope this was helpful for you, if you require any further help just ask.
If you did find that this was helpful in solving your problem, I would really appreciate a good rating.
Thanks and have a great day,
Dave
Jun 19, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
12 w 3 v3 2 cut off
Again as I have stated in my other answer to you. You can not wire two SVC 2 ohm subs to acheive a 2 ohm load. more than likely you are running your amp at 1 ohm mono and this is why it is clipping and shutting off.
Jun 19, 2008 | Jl Audio 12W3 Car Subwoofer
Sony Xplod Car Audio Amplifier
When the protect mode is activated,always be the audio amplifiers IC's damaged you gotta change them.
Jun 05, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Operate amp @ 2 ohm
what is the output impedance of the unit - factory specs? use calculations for resistances in series or parallel to get what you want. for example if the amps output is 8 ohms and you have two 4 ohm speakers wire the speakers in series. if your output is 4 ohms and you have two 8 ohm speakers, wire them in parallel to get 4 ohms. another way is if you have one 8 ohm speaker and you want it across the 4 ohm output, find a wirewound resistor that'll take the wattage rated at 8 ohms and put it in parallel so the output sees a 4 ohm load.
Aug 23, 2007 | DHD NTX-2009 Car Audio Amplifier
Krell Showcase 5 5-Channel Amplifier Logo
77 people viewed this question
Top Krell Audio Players & Recorders Experts
80stech
Josh Whitehead
Josh Whitehead
 Grubhead
Grubhead
Are you a Krell Audio Player and Recorder Expert? Answer questions, earn points and help others
