Question about Magic Chef 7 cu. ft. / 198 liter Chest Freezer CFC0735GRW
Why is the Temperature Indicator Light on in my Majic Chef modle number MCCF7W, what dose it mean?
  • 2,272 Answers
The “POWER” light (Green) indicates that the freezer is properly connected to the electrical power.
The light indicates power supply, and will glow even if the temperature control dial is turned to “OFF”,
or the compressor has failed to work and the compartment is not being cooled.
The “Temperature Indicator Light (Red)” will not illuminate when the unit is operating below freezing.
The “Temperature Indicator Light” will illuminate when the temperature inside the unit increases above
freezing. Please be advised that the “Temperature Indicator Light” may come on for a period of time
when the lid is opened, when new items are stored inside the unit or when the lid is forced open by
irregular contents.
Do not call for service unless the “Temperature Indicator Light” has remained on for 6 hours or more.
If this light stays on continuously for a period of 6 hours, please contact our Customer Service Dept.
to consult with a representative at 888 775-0202.
Temperature Control
• Your freezer has one control for regulating the
temperature. The temperature control is located on the
lower right hand corner.
• The first time you turn the unit on, switch on the Fast
Freeze switch (orange light) and run for at least 2 hours
before putting frozen foods inside. This will ensure the
cabinet is thoroughly chilled before food is put in.
• Turn off the Fast Freeze switch.
• The range of the temperature control is from position" 1"
the warmest to "6" the coldest. Adjust the temperature
control to the setting that best suits your needs. The setting of “4” should be appropriate for home To turn the freezer off, turn the temperature control to "OFF".
NOTE;
• Turning the temperature control to “ OFF” position stops the cooling cycle but does not shut off the power to the freezer.
• If the unit is unplugged, loses power, or turned off; you must wait 3 to 5 minutes
before restarting the unit. If you attempt to restart before this time delay, the freezer will not start.
• Large amounts of food will lower the cooling efficiency of the appliance.
• If you choose to change the thermostat setting, adjust thermostat control by one numerical increment at a time. Allow several hours for temperature to stabilize between adjustments.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jun 10, 2010
What is the green light on my majic chef freezer
Probably an indicator that it is working
Nov 02, 2016 | Freezers
What does the red warning light by the triangle mean on a blomberg
Under normal operating conditions, the internal
temperature of the freezer will ensure the longterm
conservation of the stored food.
When such temperature rises above a certain
level (-12 °C), the appliance will trigger an
acoustic and light alarm. The light alarm is a
blink red light (Red Alarm Indicator Light), while
the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing
the Acoustic Signal Stop Switch once.
When switching on the freezer for the first
time, the Red Alarm Indicator Light will
blink until the internal temperature has reached
a level required for the safe conservation of frozen
food.
Dado
May 28, 2014 | Zanussi 10.31 cu. ft. / 292 liter Chest...
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
Magic Chef Chest Freezer MCCF5WBX is not getting power, green light not on
Check your outlet with something else that will work, like a radio. If the green light does not come on, then check the wiring. The green light should be on even if the freezer has reached it's temperature. That is simply a light to indicate that power is at the receptacle.
Jan 27, 2013 | Magic Chef Chest Freezer MCCF5WBX
Magic chef freezer temperature indicator light on, not usually on?
Is it a red light? If so it's not reaching temperature (the alarm is about -12c) If it's a yellow light, you've accidentally switched on "fast freeze". If it's a green light it's just the power supply light.
May 08, 2012 | Magic Chef 5 cu. ft. / 142 liter Chest...
What's your problem?
Look around for where the unit receives temp input. Maybe the sensor is iced over and reading incorrectly.
Jan 05, 2012 | Magic Chef Freezers
Magic Chief Freezer MCCF7W power light is flickering, but no problems with temperature
Most likely loose connections at the light. Try removing and checking. Usually can pry loose with a flatblade screwdriver.
Oct 15, 2011 | Avanti 5.3 cu. ft. / 150 liter Chest...
I have this majic chef freezer about 7 cubic ft. 3 years old turned it off to defrost and when turning it back on it won't get cold?? Compresser is hot so I believe it is working and lights on in front...
I'd let it dry out totally then try it again, some of the electronics may have gotten wet when you defrosted it. Give it a week somewhere warm and dry like a garage. If you didn't attack built up ice in the freezer with a knife while defrosting it it should work after it dries out. Most people end up killing freezers by accidently poking holes in the evap coil while trying to remove built up ice.
Aug 14, 2011 | Magic Chef Chest Freezer MCCF5WBX
WHAT IS THE PRICE OF THIS MCCFFW CHEST FREEZER
spacer.gif 5.5 Cu. Ft. Chest Freezer bbd4a981-a436-4ad6-b98a-7249ef5d1d1a_300.jpg Click to Enlarge Lowest price:$179.00Description:
Food storage will be a snap with this roomy 5.5 cu. ft. chest freezer, featuring up-front temperature control, storage basket and defrost water drain.
Brand: Magic Chef
Category:
Appliances > Refrigerators & Freezers > Freezers > Chest
UPC: 665679002023
Model Number: MCCF5WBX
Dec 16, 2010 | Magic Chef Chest Freezer MCCF5WBX
MCCF7W Runs, but won't freeze....
Sounds like the refrigeratnt has leaked out. It is not worth repairing. The only other possibility is the cold control but I would not buy one until a servicer has looked at it.
Sep 05, 2009 | Magic Chef Chest Freezer MCCF5WBX
Magic Chef 7 cu. ft. / 198 liter Chest Freezer CFC0735GRW Logo
147 people viewed this question
Top Magic Chef Freezers Experts
Dan Webster
Dan Webster
Offbelay
Level 1 Expert
john mabry
Are you a Magic Chef Freezer Expert? Answer questions, earn points and help others
