Question about Actiontec (GT704WG) Router
Trying to wire 2nd computer to internet router & 1st computer...
Here goes,
I've connected a 2nd computer to our internet gateway - 2nd computer recognizes connection, but I'm not able to access internet with it, or network with the 1st computer.
And that was all one breath, too...
The 2nd computer was our main piece until about a year ago, when we purchased a new, shiny computer. Since then, it's been alone in a room, basically an unconnected word processor. No internet connection, no network, no nothing. Now I'm trying to network it in with the New computer. Both Computer #1 (New shiny) and Computer #2 (old faithful) have a lot of the same specs:
- Both run Windows XP
- Both have MSN Premium as the main Internet Program
I've run a 25' Cat5e Ethernet Cable from our Actiontec (GT704WG) router to the back of #2. The Actiontec router has 4 open slots for Ethernet Cables. Computer #1 is connected to the first slot, Computer #2 to the second, and the other two are empty. We have 2 laptops and an Ipod Touch that access the wireless connection without any trouble.
Anyways, the Status bar in the bottom right corner of the screen on #2 says "Local Area Connection 3, speed: 100 Mbps, status: Connected". However, I am unable to access the internet on that computer, by any means - I've tried Internet Explorer, Opera, and MSN, to no avail.
Here're a few things that confuse me...
1) The connection status bar on computer #1 says "Local Area Connection", not "Local Area Connection 3". I don't know if this is a problem...
2) I AM able to access the Actiontec gateway setup site on computer #2, (http://192.168.0.1), but nothing else, not even the MSN website. The information there is updated in realtime, so I know I'm connected to something, somehow... I just don't know what, how, or why...
3) I've run the Network Setup Wizard a couple of times, in a vain attempt to fuse the two systems (maybe that was stupid.) I've tried it 2 or 3 times each from both sides of the connection: I've finished the checklist as closely as I was able, and I've been consistent in naming computers and networks, though I haven't noticed any difference.
4) I have the WAN IP Address, Subnet Mask, LAN IP Address, Net Mask, MAC Address, and PPPoA Username and Password (all readily available at the Actiontec Set-up Site). They sounded pretty technological and important, so I wrote them down. In fact, I think I might start reciting them when next conversing with a technically minded person, in order to sound slightly less Techno-plegic.
I would like to network these two computers together, as a LAN line between them would be most triumphant. However, internet on computer #2 is crucial, so my priority list goes as follows:
- Get Computer #2 connected to internet, preferably through the use of the 25' cat5e cable I've already purchased...
- Network 'New Shiny' with 'Old Faithful', so i can share printers, files, *internet*, and multiplayer games with my kids.
I hope you can help me: I'm stumped. Computer Technology is not my strong point...
Thanks,
  • cmeonbroadwa May 16, 2010
    not quite... that didn't work for me.
    no, I've already visited that sight, sorry. dang!
    President:
  • 1,851 Answers
First of all, let's get the computer #2 connected to the internet. Check that IP adress, Mailgate and DNS server settings are set to auto for your connection (the full way you have to go is : start>settings>network connections>local connection#3 - don't worry with the number - TCP/IP Protocol>properties) After you set up the setings to auto (maybe a restart is asked) you maust get connected to the internet.
Verify me that so far so good, in order to continue.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 16, 2010
    Genius:
  • 1,354 Answers
Hi
thank you for using Fixya
it diffecut to explene with text just go to folowing link you will get all the soulution for your networking at home
http://www.ust.hk/itsc/ResNet/setup_wXP.html
  • 12,061 Answers
OK, well first do this go START>>RUN>>services.msc (enter) This will bring up the services window, scroll down to DHCP, and set to OFF & Disable, then also go to wireless zero configuration, and do the same , then reboot. Do this on BOTH PC's. Now BOTH PC's MUST have an Individual Name, Also MUST have a Login Name & Password, Also MUST be part of same Workgroup. Now in the Router DHCP MUST be set to ON. Now that's about it. The Router, hands out the address to the PC's, To connect, it most likely now will simply connect, but if it doesn't simply run the connect to internet Wizard, chose connect via a Gateway, which is the Router/Modem unit. It works like this, The PC your using, broadcasts out that it is here, then the PC talks backwards and forwards to the router, and the router says, here is your address, your PC, says. great, now, I want www.bla bla bla, address, and the Router, then sends out a request on the internet for that address, it obtains that address if valid, and then routes it to your PC. So, if it's NOT working it is a simple matter to troubleshoot.
Now if you have screwed up you IP Stack, Winsock, then I also include a XP program that will reset all that back to how it first was, and should be. It is called WinsockXP. DO NOT just run it unless you are sure you need to, and all else has failed, as it will reset everything back to default. So if that's what you want to do, then fine.
http://windowsxp.mvps.org/winsock.htm
Now you connect the router/modem to the net, the Ethernet cable into say 1 & 2 Ethernet sockets, connect to the internet from each one. Also always get at least two browsers of differing sorts, say, Firefox, IE, and Chrome, is a good choice, as if it will not work with some, it may with another browser.
Can I run 2 laptops off the same modem
There are several ways. Windows XP & Vista & 7 have 'ICS' ("Internet Connection Sharing") that allows you to connect the second computer to the first computer, and the first computer to the modem, so that the first computer is a "gateway" to the Internet for the second computer.
Or, buy a "router" -- connect the modem to the "uplink" port on the router,
and connect (wired or wirelessly) multiple computers to the "LAN" ports on the router.
The router acts as a "gateway" to the Internet for all the computers on the LAN.
May 25, 2011 | Computers & Internet
I'm trying to get online for my ps3 and i can't get a wireless connection. so i decided to just do a wired connection from the computers internet connection.how can i do that without messing with the...
1st you need a 4 port router or a modem/router combo 1 that has more than 1 port.
2nd you need to have enough CAT5 cable to get it to 1 of the empty ports on the router.
So basically the way you would hook it up if you are going to use 2 individual components is:
1. Unplug the CAT5 and power supply from your modem the one that goes to your puter.
2. Put the new router under or the side or underneath the modem.
3. The Ethernet cable that comes out of the modem plugs into the corresponding port on the router that doesn't have a number.
4. Now depending on how many ports you have I always put my puter in port 1 and then anything else goes in the other ports, you don't have to do it numerically.
Feb 19, 2011 | Sony Playstation 3 (PS3) Console
DGN2000 router problem. I have 2 pc connected on the router and only the main one has access to the internet. Am i doing something wrong with the settings or does my router has a problem? Is it true that...
I'm not aware of any problem with the DGN2000 that only lets you connect 1 computer (If it was I dont think they would sell many and EVERYBODY would know about it)
Anyway - try swapping the network leads over (remember which port is the "live" one) does the other PC now have internet access and the 1st one not?
if the 2nd pc DOES have internet access the yes you have a suspect router.
if the 1st computer DOESN'T have Internet access you have suspect router.
if the 2nd pc DOESN't have internet access but the 1st pc DOES - then the problem is something on the 2nd pc.
Hope this helps.
Jan 30, 2011 | NetGear DGN2000-100NAS Router
I got into my Coolmax external hard drive on my computer, via internet cable and router. I got into the hard dirve OK. I am trying to get another 2nd computer recognized on the hard drive. The Coolmax...
Indeed, it sounds like a sharing problem. But, based on your explanation, I'm not sure what your issue is as your terminology is not standardized.
Example: you said, "I am trying to get another 2nd computer recognized on the hard drive." What would be more accurate, is that you are trying to get the 2nd computer to recognize the 1st computer so you can access the 2nd computer's hard drive.
On the other hand, you said the hard drive uses a network interface, and you have it connected to the router. So does it have some kind of web based interface? No, if what I read about it says that it uses USB 2.0 and eSATA, which means it is directly connected to the 1st computer, and so it would have to be shared to the 2nd computer via the 1st computer.
I also note you don't specify any operating system, which is absolutely required. Because, for example: Windows 10 has sharing problems; I'm a professional, and I haven't bothered till they fix it.
You said: "I registered the ID and password", which does sound like you're using Windows to set up a share. But then you say, "Did Run //storage/person" which means nothing to me. As that's not any way to set up a share that I'm aware of. (Maybe I'll learn something ;-)) And then you say, "2nd computer's hard drive was not recognized" and that's confusing, because I thought you were trying to see the Coolmax which is on the 1st computer, right? Or is it on the 2nd computer. So it's really not clear what you're doing, or what you think you're trying to do. If you clear this up, I'd be happy to see what I could do to help.
How to set up File Sharing on Windows 10
Jul 04, 2017 | Coolmax HD-211-eSATA Hard Drive
How do i connect a 2nd' computer to my internet connection
you can connect to your router using wired (LAN cable) connection or using the wireless capability of your machine (WIFI)
Mar 28, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Connection issue
Hi! I believe your having some issue with your router and I will be more than glad to assist you in this concern..Time warner cable is your isp and if the computer is connected directly to the modem, you have a perfect internet connection but if you are going to connect the cable from your modem to the router and you connect your computer to port 1 to 4 of your router it will not give u an internet connection. This is what we are going to do.
1. connect your computer that can get an internet connecttion thru time warner cable to the router on port1.
2. pull up a browser and type in the default gateway of the router, to check the default gateway of the router, right click the network icon on the lower right of the task bar and click status and it will show the ip address, subnet and default gateway, ex the default gateway is 192.168.1.1, u are going to type in the default gateway ip address to the url of the browser.
3. It will ask u for the username and password, by default the username is admin and the password is 1234 or just leave it blank.
4. It will pop up the setup page of the router and you have to look for the setting for doing a mac clone, you need to clone the mac address of your pc that can connect to the internet thru time warner cable modem.
5. once its done, save the settings and on the internet connection settings, manualy configured it to auto-dhcp. save the settings.
6. once its done..unplg the power of the computer, router and modem.
7. cable connection should be, cable from the modem goes to the WAN port of the router and connect cable on port 1 of the router to your computer on the lan port.
8. Plug in 1st the power of the cable modem, once all lights are lit then plug in the power of the router, once all lights are solid on the router, like the power, WAN, u will notice that there is no light on the port1, computer is still off, once the computer is on port1 will lit, then power on the computer..once computer is completely boot up, pull up a browser and it should gives u an internet connection.
9. Once you have an internet connection, u can access again the setup page of the router to setup the wireless connection settings.
10. If you are going to connect another to the existing router that is conneted to the time warner cable. that is possible, but before u connect the 2nd router to the 1st router..
a. connect the 2nd router to a computer to set it up..you have to access the setup page of the 2nd router.
b. once you access the setup page, there is a menu for the lan settings that is for the router side. u need to change the 3 octet of the ip address of the 2nd router. ex your 1st router ip address is 192.168.1.1 and the 2nd router ip address is 192.168.1.1 to change the 3 octet of the 2nd route, the 2nd router ip address should be 192.168.2.1. then save the settings..
c. the router will reboot and need to access the setup page of the router by using the 192.168.2.1 and u can set the wireless connection settings.. once its done..
d. cable connection should be---cable from the time warner cable goes to the WAN port of the 1st router, connect a cable to port 4 of the 1st router going to the WAN port of the 2nd router.. this process is called cascading two routers on a network.. this should work.. good luck
Aug 16, 2009 | ViewSonic (DHWMG120) Router
Wanting to connect 2nd computer to internet, have router
If it is by wirless you will need to adjust the wirless adapter setings by going to your network conecsions click on the wirless conecsion and confiqir it to use stronger setings it should have a descripsion for all stings. I hope this will help you. Also do not forget to vote.
Jan 17, 2009 | Gateway Cable/DSL Router - 4Port [ Belkin...
Set up 2 wireless routers, 1st for printer, 2nd for internet
You should only need one wireless router for everything. The purpose of the router is to "route" multiple devices together. Your set-up should be something like this:
Modem connected to wireless router via Ethernet cable.
Wireless router broadcasting wireless internet connection.
Computer(s) connected to wireless router via cable or wireless adapter.
Computer with network printer sharing enabled.
Turn on wireless printer.
You should be able to detect the printer via Windows.
Sep 05, 2008 | Office Equipment & Supplies
I HAVE A COMPUTER UPSTAIRS & CONNECTED TO INTERNET, I WANT 2ND COMPUTER (W/C IS IN THE GARAGE) TO GET CONNECTED ALSO IN THE INTERNET. I HAVE A BELKIN WIRELESS ROUTER BUT IT SEEMS I CANNOT GET IT...
ok is the one upstairs hard wired if so log into your router and set your wireless to enable others to see make sure you set wep for incription and remember code you use save and log out then go to start / run type cmd then enter black screen white writing type ipconfig and note ip add subnet & def gateway this way you can set other pc to a simular ip add but same subnet and gateway, if you have problems and are in uk post back with phone number to contact will give you a bell
Regards
Brian
Jul 16, 2008 | Belkin Computers & Internet
Actiontec (GT704WG) Router Logo
35 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
