Question about Sanyo DS27930 27" TV
Sanyo I have a Sanyo and on one channel a black screen appears (not full screen) until you press the volume botton and or channel botton, only to appear again?? Any suggestions? Thank you. We where thinking to clean it from the dust in back?
  • Anonymous Jan 02, 2009
    my tv is doing the same thing a black screen appears and we have to power it on & then off only for the screen to pop up again.....
  • 218 Answers
Go into the setup menu and turn off closed captioning. The black box is a text box for CC. Some stations are sending the signal which triggers the box, but are not actually sending any text.
Posted on Feb 16, 2009
Have Sanyo model DP19648. Screen is black, sound works. Powers on and off, green(power)light works with tv power button on set and both remotes. Set stays on with sound until powered off.
I would try a new Tcon board, they aren't all that expensive, only other thing to do is check the LVDS and flat cables to be sure they are plugged in ok between the main and panel to and from the Tcon
Nov 08, 2017 | Sanyo Televison & Video
Can tune in new stations
press the menu botton on the remote go to onscreen menu , find the auto tune section ( volume and channel selectors on the remote)and press auto tune
allow it to run its course and all channels will appear
Mar 01, 2016 | Televison & Video
I need the codes to a sanyo tv and i have a brightstar br100z remote
The Sanyo codes appear to be 620, 801, 931 . Turn on the TV, press and hold Set-up until the light comes on and enter the three digit code. Check if the TV responds (volume, channel). If not try the next code.
To search all codes: turn on the TV, press and hold the Set-up button. Then press Channel + slowly but repeatedly until the channel changes. Press Enter (if you overshoot, press Channel - to before pressing enter.) To record the code, turn on the TV, press and hold Set-up, then press Set-up again and type 0-9 individually until the indicator light blinks. That is digit 1, repeat the search from 0-9 for the other two digits.
If your TV was released ~6 months before the remote was programmed or is newer than the remote, then the code you need may not be in the remote's programming. In that case, you need a newer remote, one of the remotes that is programmable (USB to a computer), or a remote specific to your TV (try remotes.com and search on the TV model - leave off the brand name).
I hope this helps.
Sep 26, 2010 | Televison & Video
Tune in channels
Switch TV on
Press “MENU” on remote until 3 blue arrows appear
Press “VOLUME” keys to tune up or down (shown on blue bar)
When required programme is tuned, input required Channel number (appears on 2 green lines at top) e.g. 02 or 14
Carry on tuning and allocating channel numbers
Select “MENU” to clear or wait until it clears by itself
Channels should now be tuned to allocated numbers
Feb 21, 2010 | Televison & Video
The volume of sony wega kv-sw29m61 set always to maximum when it turned on
On your remote control (with tv off)
1. press Display, channel 5, Volume Up and then Power
this brings up the service mode (you will see some green text on your screen)
2. Press channel 2 to scroll through options until you see "Micro" in the upper left of your screen
(channel 2 cycles up through the options, channel 5 cycles down)
3. Press channel 1 to scroll through suboptions until you see "DIOF" appear under "Micro"
(channel 1 cycles up through the suboptions, channel 4 cycles down)
4. Press channel six until the default value (12:60) changes to 12:40
(channel 3 increases the value, channel 6 decreases the value)
5. Once the value has been changed to 12:40, press Muting and you should see red text in the upper right hand corner that says "Write"
6. Simply turn the power off and back on for the change to take effect. Your volume problems should now be fixed.
Jan 16, 2010 | Televison & Video
At random a black retangular box appears on the screen
Go into the TV's closed-caption settings and turn off captioning. You'll find it's set for "text" mode right now. What's happening is that in text mode, the set blanks out the part of the screen where the text will go but there isn't any. On channels or programs where captions aren't being broadcast you don't see anything. With the captions turned off the box will go away.
Apr 10, 2009 | Toshiba 20AF41 20" TV
Sony DSC W40 , screen appearing black
ther should be a small button below the menu botton try pressing this a few times this a energy saving device .hope this helps.
Dec 04, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony FD Trinitron WEGA TV Model Number KD27FS170 volume problem
my sony trinitron is blinking six blinks and I cannot turn it on, please help
Nov 22, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony KLV-S23A10 takes approx 30 minutes to warm up
OFF YOUR TV WITH POWER BOTTON, THEN PRESS IN REMORE CONTROL DISPLAY BOTTON # 5 BOTTONVOL + BOTTON AND POWER BOTTON.( DISPLAY--5--VOL+--POWER)
May 04, 2008 | Sony KLV-S23A10 23 in. LCD HDTV
Black box on screen
go into menu find
cc settings and
change setting to off
(make note of the one thats
causing the problem)
Dec 02, 2007 | Sansui DTV2760 27" TV
Sanyo DS27930 27" TV Logo
136 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
