Question about Tally LA650 Matrix Printer
How i import data in excel from tally7.2
How i import data in excel from tally 7.2
YOU NEED TO MIGRATE YOUR TALLY 7.2 TO TALLY 9 FOR EXPORTING DATA FROM TALLY
Posted on May 27, 2010
How to export in tally 7.2
This applies to Tally 7.2 and above.
1. You can export only registers and not masters
2. In any view register mode the export / import option becomes availble.
3. Click export.
4. Tally prompts you for a file name. The default name is always Tally.txt.
5. Pl rename the file to represent the ledger you are exporting else Tally will over write an existing file.
6. Tally will always save the file in the same drive / folder where Tally data resides. You cannot change this.
7. The file saved is the CSV file.
8. Open this file with Excel and map the fields.
Jan 20, 2015 | Tally Office Equipment & Supplies
How to export tally 9 to excel sheet
Great question and there are two way export date. Please follow step by step instruction.
  1. In the Balance sheet screen click E : Export or press Alt+E.
  2. Select the required language from the list of Languages displayed.
  3. Select a format from the list of Formats displayed.
  4. By default, the exported file will be stored in C:\Program Files\Tally.ERP 9 for Windows 7 and C:\Tally.ERP 9 for Windows XP operating systems
  5. Press Enter to accept the default Output Filename or type the filename of your choice in order to save the file with a different name.
  6. Press Enter to accept the default Output Sheet Name.
  7. To update the existing file select Yes in Update Existing File.
  8. To format the contents of the file select Yes in Excel (Spreadsheet) formatting.
  9. Select Yes for the Field with Colour, to retain the background colour in the exported file.
And Second:
selecting the ASCII (Comma Delimited) format, the user can export all the reports or data from Tally.ERP 9. The data exported is converted to plain text separated with commas and stored in a file with the extension .txt. This file format is widely used for emailing and used for importing data into another company using Tally.ERP 9
More information please visit this link.
http://www.tallysolutions.com/website/CHM/TallyERP9/Data_Management/Export_Formats.htm
Thanks,
Jun 10, 2014 | HP Office Equipment & Supplies
How to import data from excel to tally
Please follow the below link for your problem
http://www.rtslink.com/import-data-from-multiple-excel-sheets.html
thanking you
davevipul197
Dec 17, 2010 | Singer CE-200 Quantum Futura Computerized...
How can i export the data tally to excel
There are 2 ways to do it..
Step 1
You can export as text and import it back to excel using the text file you created.
Or
You can select HTML and give the file name as eg-XYZ.xls
Step 2
You can export all reports and statements. For this a separate export button is provided in right hand button bar. To do this go to any report e.g. day book you to export or any statement e.g. balance sheet. You would see export button on top right hand side on button bar. Press it and a screen would pop up with export related options.
The first option is format of data to be exported namely ASCII, HTML, SDF, and XML. Which ever application you are importing this data in would decide in which format you should export the data.
For statements like balance sheets and trial balance which we use to send and import file in word and excel etc. HTML format is good. We need minimum formatting in this format while using it in MS Word and MS Excel.
certain applications accept continuous data where we have defined field length. Then ASCII format is better.
For application which accept SDF and XML format these formats can be chosen.
Give a file name and the exported file is saved in the parent Tally directory on your computer. You can now use that file to import its contents into another program, send it as it is (say if it is HTML file) to a colleague or view it using a browser.
Step 3
Consider exporting day-book.Go to day book press export button or use shot cut key Alt+E. Exporting screen will displayed.
Press Back space on your keyboard. And select Format as ASCII (comma delimited). Now give output File Name as Daybook.csv, now select some other option you want to export from the bottom of the screen.
Press enter to accept screen. Day book is exported in to tally program folder. Check program folder for file daybook.csv,
Double click on it, the file will open in excel program. If you want it in excel work sheet file, use the option Saveas, and save it in Microsoft excel workbook (*.xls) format.
Hope this is helpful. Let us know if the issue is resolved.
*Rating and Comments are invited for this solution
Nov 24, 2010 | Tally T2245 Matrix Printer
Export the data from excel to tally
  1. make a sale entry in tally
  2. Export the voucher from tally in xml format (this is to give u how the xml looks)
  3. Open the excel file where all the data is ther.
  4. open a word file, so that we can prepare the xml for mutiple vouchers. For this we will use Mail Merge facility
  5. in the XML which we did in step two, copy the data from "<TALLYMESSAGE xmlns:UDF="TallyUDF">" till the </TALLYMESSAGE>
  6. Now open the word file, go to mail merger, select the fields which needs to be changed, that is the Debtors and the amount (for normal sale entries) which should change for every sale voucher.
  7. create the mail merge.
  8. copy the data what you got in word file to a note pad and name it as sample.
  9. open again the step 2 - copy data from " <ENVELOPE> to <REQUESTDATA>" and paste in the begining of the notepad sample
  10. go the end of the notepad sample and copy the data from first file -"step 2" from " </REQUESTDATA> to </ENVELOPE>" and save the file
  11. Open tally
  12. go to import vocuhers
  13. specify the path of the notepad sample and yes ur data got imported.
Apr 21, 2010 | Microsoft Windows XP Professional
How to automatically import data from tally to excel. Want to display auto imported data in sharepoint.
Import TALLY Data / Export TALLY Data
Tally allows users to Import data from other software's as well as Export data from Tally to other software's. Tally allows users to Import and Export in ASCII, SDF and XML formats. XML is now the most widely used format of exporting data in the world. Any transactions can be exported from Tally and imported in other software after suitably altering the current structures to accept Tally data structure. The reverse is also possible by writing a small TDL program to accept the data from other software's. The data that is to be imported into Tally can be in either XML or DBF format. Easy Tally data transfer or Tally data migration from Tally 4.5 & Tally 5.4 to Tally 6.3 , Tally 7.2 , etc.
ODBC COMPLIANCE ALLOWS OTHER PROGRAMS TO USE DATA FROM TALLY DIRECTLY. E.G. : MS-EXCEL :
ODBC - OPEN DATABASE CONNECTIVITY
Tally is now ODBC compliant. Hence, any program like MS-Excel, Oracle etc that is ODBC compliant can use data from Tally. Here, data connectivity is dynamic i.e. any new updation in Tally is reflected in other ODBC Compliant Software immediately. Now, with ODBC facility the user can extract data out of Tally and design his own report formats in other ODBC compliant software's.
Procedure :
Now, Load Company -> specify period -> minimize Tally -> Open a new Excel file -> select data -> select 'Get External Data' -> select New database query -> choose Data Source
Tally connects to data source and displays Tally Wizard query screen -> select the columns you would want to include in the query.
Once all the columns are selected, the user returns to excel and excel displays all the columns selected
Graphical Analysis of Tally Data
Sometimes, pictures can say better than figures. Tally also provides graphical (Bar graph) analysis of data. The user can do a graphical analysis reports like Sales register, Purchase register, Ledgers, Funds flow, Cash flow, Item registers etc. This helps the user in deeper analysis of data. In Tally, a graphical analysis can also show month wise graphs for the year in comparison with any other period. This will help the management in quickly locating the highs and lean periods in a financial year and hence be better prepared for difficult times.
Web Enabled
Tally ees 6.3 is now Web enabled. This will help the user in reducing his paper work further. Now, report in Tally can be e-mailed directly from Tally. It is not just reports, but even invoices and purchase orders can also be e-mailed directly from Tally. Hence, the user does not have to send printed invoice or purchase orders from Tally.
Procedure :
Select any report (e.g. Balance sheet) -> select Alt+M (E-mail) -> specify all details as required by Tally
Ability to Publish Reports and Documents on the Internet
Now, Tally allows users to upload reports on the web site directly from Tally. So companies that would want to publish reports on the web site can do so directly from Tally. Many companies would also like to publish their price list on their websites along with the product they deal with.
Procedure :
Select any report (Profit and Loss A/C) -> select Upload (Alt + O) -> specify all details as required by Tally.
Direct Internet Access
Tally now offers direct Internet access. A Tally user while working on Tally can directly log on to tally website get details of all the facilities offered by Tally. The user can also download the latest releases of Tally 6.3 as and when available. Tally website also offers a facility of Tally Chat. Any user can now chat with a Tally representative and get any information regarding Tally.
Procedure :
Start Tally -> now, from any screen select Web Browser (Alt+W). Tally now takes you to the Tally Web site.
Print Preview
Any user would ideally like to view format of reports / Invoices / Vouchers before printing the same. Tally now offers a facility of print preview. Now any report can be viewed before printing or before it is mailed. Once Tally shows the preview the user can either opt to print or mail the same.
Apr 15, 2010 | Microsoft Office Excel 2007
Export tally data to excel
tally data to excel converting . i have some data export to excel but no excel formating you have some tally data to excel spred sheet software
Aug 27, 2009 | Tally T2245 Matrix Printer
Add a excel format in tally
Sir,
What to Export ?
Tally has a facility to export its data to other applications like spreadsheets, word processing software and other database software. Export of data is provided mainly for summaries and statement reports like Trial Balance, Stock Summary, etc. You can export it to another company using Tally that will import it directly.
How to Export?
Thanks
Good Luck
Aug 14, 2009 | Adaptec Computers & Internet
How can i export Tally Data to Excel
when u give the print commant u get an export button on the right side. Press that button and then then selest the rewuired format. XML is the genaralised format used these days. Then import the data in tally
Apr 30, 2009 | Tally T2245 Matrix Printer
Export tally data to excel format
Select ASCII. Give output file name Eg:d:/exp Open the file using EXcel.Select Delimite  nexxt comma finish.Export is completed
Jan 02, 2008 | Tally T2245 Matrix Printer
Tally LA650 Matrix Printer Logo
192 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
